I’m struggling to understand the documentation surrounding URI redirection.
I’d like for:
https://artisanadaptations.com/staging/
to serve
/home/username/artisanadaptations.com/src/public/
and I would like
to serve
/home/username/artisanadaptations.com/srv/
The reason I’d like for this so I can quickly preview changes in a very simple Hugo website without having to commit each change to what people will find on logging into the base URL.
It is possible to do that, but your site in the subpath needs to be aware of being in a subpath, and all the links in the HTML need to have /staging as a prefix.
Since you’re using Hugo, there’s likely a way to configure it to generate URLs with a prefix everywhere. I think there’s a baseURL option you can configure.
That said, a subdomain is certainly the easiest solution.
That’s a pretty old version at this point. Please upgrade to the latest version, 2.7.5.
