Simplifying my Caddyfile
Skipping the template because I think my question is fairly easily explained.
Basically I have a primary domain and a bunch of subdomains. Right now for each domain (primary+all subs) I have the following info in an effort to secure things up:
tls my_email {
        request_header -Referer
        header_upstream X-Forwarded-For {>CF-Connecting-IP}
        X-Frame-Options DENY
        X-XSS-Protection 1
but is this necessary to put in every entry, or can I just define these items for the primary domain and the others will inherit automatically? I want to clean up my caddyfile :slight_smile:
The feature you’re looking for is Caddyfile snippets.
