I’ve created a simple Python 3 example on how to use the FastCGI transport in Caddy.
The relative links make more sense on GitHub:
https://github.com/tonyallan/python3-experiments/tree/main/caddy-server-fastcgi
Setup
This example assumes Caddy v2.5.1 or later.
Install the fastcgi dependancy:
pip install fastcgi
Use following Caddyfile:
fastcgi.localhost {
reverse_proxy unix/caddy-server-fastcgi/fcgi.sock {
transport fastcgi
Start Caddy:
cd ~/GitHub/python3-experiments
./caddy run --config caddy-server-fastcgi/Caddyfile
The test is very simple (see test.py):
import json
from fastcgi import *
import os
print('starting', file=sys.stderr)
@fastcgi()
def hello():
query = os.environ["QUERY_STRING"]
path = os.environ["PATH_INFO"]
environ = '\n' + json.dumps(os.environ, indent=2)
content = sys.stdin.read()
print(f'request {path}', file=sys.stderr)
sys.stdout.write(f"Content-type: text/html\r\n\r\n")
sys.stdout.write(f"""
<h1>FastCGI Test</h1>
<pre>
\nos.environ =
{environ}
</pre>\r\n
Start the app in a separate terminal:
cd ~/GitHub/python3-experiments/caddy-server-fastcgi
python3 test.py
This creates a unix socket file fcgi.sock with a filename that matches the Caddyfile.
GUI file managers hide UNIX socket files so use ls in the terminal.
Use your browser to view:
