A super simple docker-compose and caddyfile setup will not work when I try to curl it, even though my 2 files are ripped nearly straight from Caddy’s docs and tutorials.
This is what I get when I run curl https://localhost
(after running docker-compose up --build
curl: (60) SSL certificate problem: unable to get local issuer certificate
how to fix it, please visit the web page mentioned above.
Caddy is running on a docker container on a fresh Ubuntu 22.04 LTS server.
This is my docker compose:
version: "3.7"
image: caddy:latest
cap_add:
- NET_ADMIN
- "443:443/udp"
- "8443:8443"
- "8443:8443/udp"
- caddy_data:/data
- caddy_config:/config
And this is my caddyfile:
localhost
respond "Hello, world!"
