When I create a special file on disk I want to show a (maintenance) message instead of passing requests on to a reverse_proxy.
The provided config should work but I am wondering:
Could I deliver the content of the file “message.html” for (all requests) and still return a 503?
What is the performance impact of the file check? Will it check on disk for every request?
Or is there a better way of doing this?
NA
$ caddy version
2.7.6
NixOS via systemd
/nix/store/1cvy9h1k8lfc9na97g8fx6iy6sr5i3dz-caddy-2.7.6/bin/caddy run --config /etc/caddy/caddy_config --adapter caddyfile
NixOS, arm
NA
NA
level ERROR
echo1.vafer.com {
output file /var/log/caddy/access-echo1.vafer.com.log
# if file "message.html" exist on disk show it
root * /etc/caddy/message
@exists {
file message.html
handle @exists {
respond "We will be back shortly" 503 {
close
# otherwise pass on to proxy
reverse_proxy echo1.default.svc.cluster.local:80
tls internal
