2.4.6
Docker
sudo docker-compose up -d
image: caddy
- 443:443
- data:/data
- config:/config
data:
config:
default:
cloud.haddock.cc {
reverse_proxy nextcloud:9000
I’m trying to reverse proxy the official Nextcloud Docker image, and I’m just getting a grey screen when I go to my Nextcloud URL.
Caddy log
{"level":"info","ts":1641859477.4185688,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":"caddyfile"}
{"level":"warn","ts":1641859477.4193442,"msg":"input is not formatted with 'caddy fmt'","adapter":"caddyfile","file":"/etc/caddy/Caddyfile","line":2}
{"level":"info","ts":1641859477.4202936,"logger":"admin","msg":"admin endpoint started","address":"tcp/localhost:2019","enforce_origin":false,"origins":["localhost:2019","[::1]:2019","127.0.0.1:2019"]}
{"level":"info","ts":1641859477.420507,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc000273c70"}
{"level":"info","ts":1641859477.420574,"logger":"http","msg":"server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS","server_name":"srv0","https_port":443}
{"level":"info","ts":1641859477.420765,"logger":"http","msg":"enabling automatic HTTP->HTTPS redirects","server_name":"srv0"}
{"level":"debug","ts":1641859477.4210703,"logger":"http","msg":"starting server loop","address":"[::]:443","http3":false,"tls":true}
{"level":"debug","ts":1641859477.421109,"logger":"http","msg":"starting server loop","address":"[::]:80","http3":false,"tls":false}
{"level":"info","ts":1641859477.4211152,"logger":"http","msg":"enabling automatic TLS certificate management","domains":["cloud.haddock.cc"]}
{"level":"debug","ts":1641859477.421389,"logger":"tls","msg":"loading managed certificate","domain":"cloud.haddock.cc","expiration":1649631219,"issuer_key":"acme-v02.api.letsencrypt.org-directory","storage":"FileStorage:/data/caddy"}
{"level":"debug","ts":1641859477.4216433,"logger":"tls.cache","msg":"added certificate to cache","subjects":["cloud.haddock.cc"],"expiration":1649631219,"managed":true,"issuer_key":"acme-v02.api.letsencrypt.org-directory","hash":"9338001c64c614abd47df3c501224d332ec4d172048a6f364a59456f24681747","cache_size":1,"cache_capacity":10000}
{"level":"info","ts":1641859477.4217043,"logger":"tls","msg":"cleaning storage unit","description":"FileStorage:/data/caddy"}
{"level":"info","ts":1641859477.4217923,"msg":"autosaved config (load with --resume flag)","file":"/config/caddy/autosave.json"}
{"level":"info","ts":1641859477.4218013,"msg":"serving initial configuration"}
{"level":"info","ts":1641859477.4220183,"logger":"tls","msg":"finished cleaning storage units"}
{"level":"debug","ts":1641859495.819337,"logger":"tls.handshake","msg":"choosing certificate","identifier":"cloud.haddock.cc","num_choices":1}
{"level":"debug","ts":1641859495.8193774,"logger":"tls.handshake","msg":"default certificate selection results","identifier":"cloud.haddock.cc","subjects":["cloud.haddock.cc"],"managed":true,"issuer_key":"acme-v02.api.letsencrypt.org-directory","hash":"9338001c64c614abd47df3c501224d332ec4d172048a6f364a59456f24681747"}
{"level":"debug","ts":1641859495.8193889,"logger":"tls.handshake","msg":"matched certificate in cache","subjects":["cloud.haddock.cc"],"managed":true,"expiration":1649631219,"hash":"9338001c64c614abd47df3c501224d332ec4d172048a6f364a59456f24681747"}
{"level":"debug","ts":1641859495.8281877,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip","upstream":"nextcloud:9000","duration":0.000762923,"request":{"remote_addr":"192.168.1.1:33922","proto":"HTTP/2.0","method":"GET","host":"cloud.haddock.cc","uri":"/","headers":{"Sec-Fetch-User":["?1"],"User-Agent":["Mozilla/5.0 (X11; Linux x86_64; rv:95.0) Gecko/20100101 Firefox/95.0"],"Accept":["text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,*/*;q=0.8"],"Accept-Encoding":["gzip, deflate, br"],"Cookie":["__Host-nc_sameSiteCookielax=true; __Host-nc_sameSiteCookiestrict=true; nc_username=admin; nc_token=b3wn452GKGDlOXPMVO49q%2B92KTgdL1tp; nc_session_id=5cfbvtei9hjkqf5mj2p5fs4vm1; authelia_session=P89I5i*u7XsMeVx9OiIm*asEXRUKHw%y; i18next=en-US; oc6mbe5vxaa7=hnb90f9hh1lktfn44p50i0h1cg; oc_sessionPassphrase=VbZci9j0godFQ6BfBYVN83%2FR3bluY6iAjlFl4AAcGtD60y9tDOUYmKBrRXM4SsH6Tx85wfo8DKcW8hk9VgwARg4V2oJlkkK0ZsrnYakZSUtqMaz4sIta3xR5qHr%2BNR7b; ocgiijrqfwz6=dcs7g46bg9v8e4hr46rllduv6m; oclw7focx2b5=76fr8dlilnsq1hcdfnhvdditgv;oc7q59qugbbx=8g9co5gasf4vb7eujj56tanffs; ocr4joi5lllq=stjojcb7qo143u2nphqes8clta; ockb818hs8g0=r5bnge13pire30oskojc6fqv4i; oc5xvram9n0w=5cfbvtei9hjkqf5mj2p5fs4vm1"],"Sec-Fetch-Dest":["document"],"Sec-Fetch-Site":["none"],"Accept-Language":["en-US,en;q=0.5"],"Upgrade-Insecure-Requests":["1"],"Sec-Fetch-Mode":["navigate"],"Te":["trailers"],"X-Forwarded-For":["192.168.1.1"],"X-Forwarded-Proto":["https"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","proto_mutual":true,"server_name":"cloud.haddock.cc"}},"error":"dial tcp 172.21.0.4:9000: connect: connection refused"}
{"level":"error","ts":1641859495.828301,"logger":"http.log.error","msg":"dial tcp 172.21.0.4:9000: connect: connection refused","request":{"remote_addr":"192.168.1.1:33922","proto":"HTTP/2.0","method":"GET","host":"cloud.haddock.cc","uri":"/","headers":{"Sec-Fetch-Dest":["document"],"Sec-Fetch-Site":["none"],"Sec-Fetch-User":["?1"],"User-Agent":["Mozilla/5.0 (X11; Linux x86_64; rv:95.0) Gecko/20100101 Firefox/95.0"],"Accept":["text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,*/*;q=0.8"],"Accept-Encoding":["gzip, deflate, br"],"Cookie":["__Host-nc_sameSiteCookielax=true; __Host-nc_sameSiteCookiestrict=true; nc_username=admin; nc_token=b3wn452GKGDlOXPMVO49q%2B92KTgdL1tp; nc_session_id=5cfbvtei9hjkqf5mj2p5fs4vm1; authelia_session=P89I5i*u7XsMeVx9OiIm*asEXRUKHw%y; i18next=en-US; oc6mbe5vxaa7=hnb90f9hh1lktfn44p50i0h1cg; oc_sessionPassphrase=VbZci9j0godFQ6BfBYVN83%2FR3bluY6iAjlFl4AAcGtD60y9tDOUYmKBrRXM4SsH6Tx85wfo8DKcW8hk9VgwARg4V2oJlkkK0ZsrnYakZSUtqMaz4sIta3xR5qHr%2BNR7b; ocgiijrqfwz6=dcs7g46bg9v8e4hr46rllduv6m; oclw7focx2b5=76fr8dlilnsq1hcdfnhvdditgv; oc7q59qugbbx=8g9co5gasf4vb7eujj56tanffs; ocr4joi5lllq=stjojcb7qo143u2nphqes8clta; ockb818hs8g0=r5bnge13pire30oskojc6fqv4i; oc5xvram9n0w=5cfbvtei9hjkqf5mj2p5fs4vm1"],"Accept-Language":["en-US,en;q=0.5"],"Upgrade-Insecure-Requests":["1"],"Sec-Fetch-Mode":["navigate"],"Te":["trailers"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","proto_mutual":true,"server_name":"cloud.haddock.cc"}},"duration":0.00100219,"status":502,"err_id":"9ymnxyyb5","err_trace":"reverseproxy.statusError (reverseproxy.go:886)"}
curl -v
output
* Trying 71.212.165.162:80...
* Connected to cloud.haddock.cc (71.212.165.162) port 80 (#0)
> GET / HTTP/1.1
> Host: cloud.haddock.cc
> User-Agent: curl/7.81.0
< Connection: close
< Location: https://cloud.haddock.cc/
< Server: Caddy
< Date: Mon, 10 Jan 2022 23:56:41 GMT
< Content-Length: 0
* Closing connection 0
I tried using the FPM version of Nextcloud and using Caddy as a webserver, but every config file I found for doing that was outdated, or I wasn’t doing something right.
Nextcloud Docker image: Docker Hub
