Hi there,
I am trying to setup a proxy to a (Java based) https service that requires mutual authentication of the client connected to it. I have generated the certificates and signed with a CA (self signed though) and followed the procedures to setup the keystores and trustores required by the java server process.
Doing a request using curl in the command line, gives back a successfully response:
curl -k --cert client-cloud.certificate.pem --key client-cloud.key https:/java-server-process:8081
{"success":"true"}
Now I am trying to wire this service using a web page that is served with Caddy. Here is an except of Cockpit configuration:
0.0.0.0:3030
tls client-cloud.certificate.pem client-cloud.key
log stdout
errors stdout
root /var/www
proxy /api https://java-server-process:8081 {
without /api
insecure_skip_verify
Unfortunately, when trying to access the /api endpoint, Caddy responses back with http error: 502
In essence, what Is the proper way to implement mutual authentication to a proxied https service?
I am newcomer to SSL mutual authentication and possible missing something, so I will be grateful if someone helps shed some light on it.
Regards,
-Christos
