I have a rather simple question even though it might seem obvious for most. I am currently trying to set the correct cache control headers for a gatsby website I’m deploying. The rules are pretty straightforward:
Nothing should be cached besides CSS, JS and /static/ files. Currently I’m trying to do it like this:
This works fine for /static/ and for the rest of the site but it does ignore the *.js and *.css part, which makes sense now that I’ve read a bit more about request matchers and the doc about the header directive, but I can’t seem to figure out the proper way to achieve this.
If anyone could give me some pointers, that would be great.
See the syntax docs for request matchers. Inline path matchers must start with a / otherwise they aren’t considered to be a matcher.
For path matchers that don’t start with / then you need to use a named matcher.
The reason you didn’t get a config error is because header directive allows for 3 arguments, in which case the first argument would be the header name, the second would be a search string for the header value, and the third would be the replacement.
Will do! My ansible playbook should do that automatically but for some reason it doesn’t.
Oh okay! I guess I missed that line in the documentation. So replacing *.js with /*.js should do the trick if I understand correctly? I just tried and it seems to work fine.
That’ll work if the .js file is at the top level, but * as a glob in the middle of the path matcher will not cross / boundaries. So /app.js will match, but /js/app.js won’t.
Instead you should use a named matcher to make a path matcher that uses a suffix match. Like this:
