2.5.1
Docker containers on AWS behind a load balancer.
Docker containers on AWS.
na
na
admin off
auto_https off
:80
root * /srv
@blob_path {
path_regexp ^/[0-9a-f]{8}-([0-9a-f]{4}-){3}[0-9a-f]{12}$
handle @blob_path
route {
try_files {path} /
handle /api/* {
Access-Control-Allow-Origin "*"
Access-Control-Allow-Methods "POST, GET, OPTIONS"
Access-Control-Allow-Headers "Content-Type"
reverse_proxy http://api:80
Not a problem per se.
The above config is working.
I just don’t understand exactly why it’s working, even after reading the docs. I arrived at this solution after reading the docs, trying to understand them as best I could, and some trial and error.
Background:
Our Caddy serves a static Angular SPA at index.html
which calls an api route (another container), and delivers up a randomly-generated blob: file via javascript. The file has a guid-like name, for example:
blob:https://example.com/10c40926-3202-4060-ae97-fe9769d7fa16
The blob file is generated randomly, so it should be handled separately from the SPA (e.g., not routed to index.html
), which I why I created a named matcher @blob_path
My main question is why I need a separate handler and route for the root page at /
in addition to the other handle
directives.
route {
try_files {path} /
na
My initial understanding was that handle
blocks make them mutually-exclusive from each other.
Based on this assumption, with the other 2 handlers in place I tried using no handler for /
, simply:
try_files {path} /
This worked for the SPA, but did not work for the blob: files since they seemed to be routed to /
, even with the other @blob_path
handler.
I also tried giving /
it’s own handle
, with no route
, in an attempt to give it some exclusivity:
try_files {path} /
This caused the site to not load at all.
Neither of these two approaches allow the site to be served as a normal SPA, and allow the blob: file to bypass index.html
Maybe I am not understanding something fundamental about the handler chain/order but any insight would be most welcome.
https://caddyserver.com/docs/caddyfile/directives/route Serving SPA with exception for certain paths
