ubuntu
caddy start
Not using anything
email lucas.goldner@googlemail.com
carlos.lucas-goldner.com {
reverse_proxy http://127.0.0.1:5500
I have configured the subdomain to redirect to carlos.lucas-goldner.com to redirect to the server at the IP: 49.12.231.186. I have a express server running there on the port 5500. Now I am trying to set up an express server so I can serve the express server at https://carlos.lucas-goldner.com.
I have an endpoint to test this at http://49.12.231.186:5500/online. But this works only on http and not on https. Any ideas on how to fix it ?. My domain is hosted on gandi.net btw.
root@carlosserver:/home/CarlosServer/CarlosServer# caddy run
2021/11/27 14:50:05.272 INFO using adjacent Caddyfile
run: loading initial config: loading new config: starting caddy administration endpoint: listen tcp 127.0.0.1:2019: bind: address already in use
root@carlosserver:/home/CarlosServer/CarlosServer# caddy start
2021/11/27 14:50:55.675 INFO using adjacent Caddyfile
start: caddy process exited with error: exit status 1
root@carlosserver:/home/CarlosServer/CarlosServer# caddy stop
2021/11/27 14:51:02.007 INFO using adjacent Caddyfile
2021/11/27 14:51:02.013 INFO admin admin endpoint started {"address": "tcp/localhost:2019", "enforce_origin": false, "origins": ["localhost:2019", "[::1]:2019", "127.0.0.1:2019"]}
2021/11/27 14:51:02.014 INFO http server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS {"server_name": "srv0", "https_port": 443}
2021/11/27 14:51:02.014 INFO http enabling automatic HTTP->HTTPS redirects {"server_name": "srv0"}
2021/11/27 14:51:02.015 INFO http enabling automatic TLS certificate management {"domains": ["carlos.lucas-goldner.com"]}
2021/11/27 14:51:02.015 INFO autosaved config (load with --resume flag) {"file": "/root/.config/caddy/autosave.json"}
2021/11/27 14:51:02.015 INFO serving initial configuration
2021/11/27 14:51:02.016 INFO tls cleaning storage unit {"description": "FileStorage:/root/.local/share/caddy"}
2021/11/27 14:51:02.017 INFO tls finished cleaning storage units
2021/11/27 14:51:02.017 INFO tls.cache.maintenance started background certificate maintenance {"cache": "0xc00053bce0"}
2021/11/27 14:51:02.018 INFO tls.obtain acquiring lock {"identifier": "carlos.lucas-goldner.com"}
2021/11/27 14:51:02.020 INFO tls.obtain lock acquired {"identifier": "carlos.lucas-goldner.com"}
Successfully started Caddy (pid=2711383) - Caddy is running in the background
root@carlosserver:/home/CarlosServer/CarlosServer# 2021/11/27 14:51:02.968 INFO tls.issuance.acme waiting on internal rate limiter {"identifiers": ["carlos.lucas-goldner.com"], "ca": "https://acme-v02.api.letsencrypt.org/directory", "account": "lucas.goldner@googlemail.com"}
2021/11/27 14:51:02.970 INFO tls.issuance.acme done waiting on internal rate limiter {"identifiers": ["carlos.lucas-goldner.com"], "ca": "https://acme-v02.api.letsencrypt.org/directory", "account": "lucas.goldner@googlemail.com"}
2021/11/27 14:51:03.425 INFO tls.issuance.acme.acme_client trying to solve challenge {"identifier": "carlos.lucas-goldner.com", "challenge_type": "http-01", "ca": "https://acme-v02.api.letsencrypt.org/directory"}
2021/11/27 14:51:04.871 ERROR tls.issuance.acme.acme_client challenge failed {"identifier": "carlos.lucas-goldner.com", "challenge_type": "http-01", "problem": {"type": "urn:ietf:params:acme:error:connection", "title": "", "detail": "Fetching http://carlos.lucas-goldner.com/.well-known/acme-challenge/E-Lx7iVNS6lXr5Vvr8552H59BnStOQxnDJpTi7FsDrI: Error getting validation data", "instance": "", "subproblems": []}}
2021/11/27 14:51:04.872 ERROR tls.issuance.acme.acme_client validating authorization {"identifier": "carlos.lucas-goldner.com", "problem": {"type": "urn:ietf:params:acme:error:connection", "title": "", "detail": "Fetching http://carlos.lucas-goldner.com/.well-known/acme-challenge/E-Lx7iVNS6lXr5Vvr8552H59BnStOQxnDJpTi7FsDrI: Error getting validation data", "instance": "", "subproblems": []}, "order": "https://acme-v02.api.letsencrypt.org/acme/order/297785050/42907116700", "attempt": 1, "max_attempts": 3}
2021/11/27 14:51:06.258 INFO tls.issuance.acme.acme_client trying to solve challenge {"identifier": "carlos.lucas-goldner.com", "challenge_type": "tls-alpn-01", "ca": "https://acme-v02.api.letsencrypt.org/directory"}
2021/11/27 14:51:07.713 ERROR tls.issuance.acme.acme_client challenge failed {"identifier": "carlos.lucas-goldner.com", "challenge_type": "tls-alpn-01", "problem": {"type": "urn:ietf:params:acme:error:unauthorized", "title": "", "detail": "Cannot negotiate ALPN protocol \"acme-tls/1\" for tls-alpn-01 challenge", "instance": "", "subproblems": []}}
2021/11/27 14:51:07.713 ERROR tls.issuance.acme.acme_client validating authorization {"identifier": "carlos.lucas-goldner.com", "problem": {"type": "urn:ietf:params:acme:error:unauthorized", "title": "", "detail": "Cannot negotiate ALPN protocol \"acme-tls/1\" for tls-alpn-01 challenge", "instance": "", "subproblems": []}, "order": "https://acme-v02.api.letsencrypt.org/acme/order/297785050/42907132260", "attempt": 2, "max_attempts": 3}
2021/11/27 14:51:09.239 ERROR tls.obtain could not get certificate from issuer {"identifier": "carlos.lucas-goldner.com", "issuer": "acme-v02.api.letsencrypt.org-directory", "error": "[carlos.lucas-goldner.com] solving challenges: carlos.lucas-goldner.com: no solvers available for remaining challenges (configured=[http-01 tls-alpn-01] offered=[http-01 dns-01 tls-alpn-01] remaining=[dns-01]) (order=https://acme-v02.api.letsencrypt.org/acme/order/297785050/42907141380) (ca=https://acme-v02.api.letsencrypt.org/directory)"}
2021/11/27 14:51:10.425 INFO tls.issuance.zerossl generated EAB credentials {"key_id": "9WkWiv9fA6MLDV7aGZJ_Kg"}
2021/11/27 14:51:14.261 INFO tls.issuance.acme waiting on internal rate limiter {"identifiers": ["carlos.lucas-goldner.com"], "ca": "https://acme.zerossl.com/v2/DV90", "account": "lucas.goldner@googlemail.com"}
2021/11/27 14:51:14.262 INFO tls.issuance.acme done waiting on internal rate limiter {"identifiers": ["carlos.lucas-goldner.com"], "ca": "https://acme.zerossl.com/v2/DV90", "account": "lucas.goldner@googlemail.com"}
2021/11/27 14:51:16.381 INFO tls.issuance.acme.acme_client trying to solve challenge {"identifier": "carlos.lucas-goldner.com", "challenge_type": "http-01", "ca": "https://acme.zerossl.com/v2/DV90"}
