I’m trying to have my single codebase serve two domains, but when one domain is served, its simply treated the same as the other domain, but as if the requestor had asked for a certain prefixed path. E.g.
domain1.mydomain.com
- served as nomraldomain2.mydomain.com
- serves the same as if the user had gone todomain1.mydomain.com/my-subfolder
The other key factor is that I’m trying to do this without the user noticing. E.g. their browser still shows domain2.mydomain.com
instead of sending them to domain1.mydomain.com/my-subfolder
. Hence a simple redirect is not possible.
The reason for this is that the two sites share one codebase, and the entire second domain can simply be handled in Slim using the group
as shown below:
$app = AppFactory::create();
$app->addRoutingMiddleware();
$app->addErrorMiddleware(true, true, true);
// Set the routes
$app->get('/', function (Request $request, Response $response, $args) {
$body = $response->getBody();
$body->write('On the main page...'); // returns number of bytes written
$newResponse = $response->withBody($body);
return $newResponse;
// second domain routes here
$app->group('/my-subfolder', function (RouteCollectorProxy $app) {
$app->get('', function (Request $request, Response $response, $args) {
$body->write('On the sub-site page...');
// Run app
$app->run();
I have had various attempts with using uri
to try and change the URI before passing it to php_fastcgi, but that appears to have no effect. I have also had no success so far with reverse proxying.
My latest Caddyfile configuration is currently:
# global options
# Disable the automatic management of TLS certs with Let's Encrypt
# https://caddyserver.com/docs/caddyfile/options#auto-https
auto_https disable_certs
*.programster.org {
tls /ssl/fullchain.pem /ssl/privkey.pem
@foo host domain2.programster.org
handle @foo {
root * /var/www/site/public_html
#rewrite * /my-subfolder/{uri}
uri path_regexp .* /my-subfolder{uri}
php_fastcgi 127.0.0.1:9000
@bar host domain1.programster.org
handle @bar {
At the moment, I’m not getting an error message. It just serves the content from the original domain (domain1.programster.org), instead of the rewritten path. The output from caddy (in my docker container) is:
demo | {"level":"debug","ts":1712335895.1677234,"logger":"http.handlers.rewrite","msg":"rewrote request","request":{"remote_ip":"172.20.0.1","remote_port":"37088","client_ip":"172.20.0.1","proto":"HTTP/2.0","method":"GET","host":"domain2.programster.org","uri":"/","headers":{"Te":["trailers"],"User-Agent":["Mozilla/5.0 (X11; Linux x86_64; rv:124.0) Gecko/20100101 Firefox/124.0"],"Accept":["text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,*/*;q=0.8"],"Accept-Language":["en-GB,en;q=0.5"],"Accept-Encoding":["gzip, deflate, br"],"Sec-Fetch-Mode":["navigate"],"Dnt":["1"],"Sec-Fetch-User":["?1"],"Pragma":["no-cache"],"Cookie":[],"Upgrade-Insecure-Requests":["1"],"Sec-Gpc":["1"],"Sec-Fetch-Dest":["document"],"Sec-Fetch-Site":["none"],"Cache-Control":["no-cache"]},"tls":{"resumed":true,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"domain2.programster.org"}},"method":"GET","uri":"/my-subfolder/"}
demo | {"level":"debug","ts":1712335895.1677845,"logger":"http.handlers.rewrite","msg":"rewrote request","request":{"remote_ip":"172.20.0.1","remote_port":"37088","client_ip":"172.20.0.1","proto":"HTTP/2.0","method":"GET","host":"domain2.programster.org","uri":"/my-subfolder/","headers":{"Sec-Fetch-User":["?1"],"Pragma":["no-cache"],"Sec-Gpc":["1"],"Cookie":[],"Upgrade-Insecure-Requests":["1"],"Cache-Control":["no-cache"],"Sec-Fetch-Dest":["document"],"Sec-Fetch-Site":["none"],"Accept-Language":["en-GB,en;q=0.5"],"Accept-Encoding":["gzip, deflate, br"],"Sec-Fetch-Mode":["navigate"],"Dnt":["1"],"Te":["trailers"],"User-Agent":["Mozilla/5.0 (X11; Linux x86_64; rv:124.0) Gecko/20100101 Firefox/124.0"],"Accept":["text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,*/*;q=0.8"]},"tls":{"resumed":true,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"domain2.programster.org"}},"method":"GET","uri":"/index.php"}
demo | {"level":"debug","ts":1712335895.1677997,"logger":"http.handlers.reverse_proxy","msg":"selected upstream","dial":"127.0.0.1:9000","total_upstreams":1}
demo | {"level":"debug","ts":1712335895.1678524,"logger":"http.reverse_proxy.transport.fastcgi","msg":"roundtrip","request":{"remote_ip":"172.20.0.1","remote_port":"37088","client_ip":"172.20.0.1","proto":"HTTP/2.0","method":"GET","host":"domain2.programster.org","uri":"/index.php","headers":{"Sec-Fetch-Dest":["document"],"Dnt":["1"],"Pragma":["no-cache"],"Te":["trailers"],"Sec-Fetch-User":["?1"],"X-Forwarded-For":["172.20.0.1"],"Cookie":[],"Accept-Encoding":["gzip, deflate, br"],"Sec-Fetch-Mode":["navigate"],"X-Forwarded-Proto":["https"],"X-Forwarded-Host":["domain2.programster.org"],"Accept-Language":["en-GB,en;q=0.5"],"Upgrade-Insecure-Requests":["1"],"Sec-Gpc":["1"],"Sec-Fetch-Site":["none"],"Cache-Control":["no-cache"],"User-Agent":["Mozilla/5.0 (X11; Linux x86_64; rv:124.0) Gecko/20100101 Firefox/124.0"],"Accept":["text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,*/*;q=0.8"]},"tls":{"resumed":true,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"domain2.programster.org"}},"env":{"REQUEST_METHOD":"GET","SERVER_NAME":"domain2.programster.org","SERVER_SOFTWARE":"Caddy/v2.7.6","DOCUMENT_ROOT":"/var/www/site/public_html","HTTPS":"on","SSL_CIPHER":"TLS_AES_128_GCM_SHA256","HTTP_COOKIE":"","CONTENT_TYPE":"","CONTENT_LENGTH":"","HTTP_X_FORWARDED_FOR":"172.20.0.1","HTTP_X_FORWARDED_PROTO":"https","HTTP_ACCEPT_LANGUAGE":"en-GB,en;q=0.5","HTTP_SEC_GPC":"1","HTTP_SEC_FETCH_SITE":"none","HTTP_CACHE_CONTROL":"no-cache","GATEWAY_INTERFACE":"CGI/1.1","HTTP_USER_AGENT":"Mozilla/5.0 (X11; Linux x86_64; rv:124.0) Gecko/20100101 Firefox/124.0","REQUEST_URI":"/","HTTP_DNT":"1","HTTP_PRAGMA":"no-cache","SERVER_PROTOCOL":"HTTP/2.0","REMOTE_HOST":"172.20.0.1","REMOTE_USER":"","SCRIPT_NAME":"/index.php","REMOTE_IDENT":"","SSL_PROTOCOL":"TLSv1.3","SCRIPT_FILENAME":"/var/www/site/public_html/index.php","DOCUMENT_URI":"/index.php","HTTP_HOST":"domain2.programster.org","HTTP_ACCEPT_ENCODING":"gzip, deflate, br","HTTP_SEC_FETCH_MODE":"navigate","HTTP_ACCEPT":"text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,*/*;q=0.8","REMOTE_PORT":"37088","PATH_INFO":"","REQUEST_SCHEME":"https","HTTP_SEC_FETCH_DEST":"document","HTTP_TE":"trailers","HTTP_SEC_FETCH_USER":"?1","HTTP_X_FORWARDED_HOST":"domain2.programster.org","HTTP_UPGRADE_INSECURE_REQUESTS":"1","AUTH_TYPE":"","REMOTE_ADDR":"172.20.0.1","SERVER_PORT":"443","QUERY_STRING":""},"dial":"127.0.0.1:9000","env":{"HTTP_SEC_GPC":"1","HTTP_SEC_FETCH_SITE":"none","HTTP_CACHE_CONTROL":"no-cache","GATEWAY_INTERFACE":"CGI/1.1","CONTENT_LENGTH":"","HTTP_X_FORWARDED_FOR":"172.20.0.1","HTTP_X_FORWARDED_PROTO":"https","HTTP_ACCEPT_LANGUAGE":"en-GB,en;q=0.5","HTTP_USER_AGENT":"Mozilla/5.0 (X11; Linux x86_64; rv:124.0) Gecko/20100101 Firefox/124.0","SERVER_PROTOCOL":"HTTP/2.0","REQUEST_URI":"/","HTTP_DNT":"1","HTTP_PRAGMA":"no-cache","REMOTE_IDENT":"","REMOTE_HOST":"172.20.0.1","REMOTE_USER":"","SCRIPT_NAME":"/index.php","SCRIPT_FILENAME":"/var/www/site/public_html/index.php","SSL_PROTOCOL":"TLSv1.3","HTTP_ACCEPT":"text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,*/*;q=0.8","REMOTE_PORT":"37088","DOCUMENT_URI":"/index.php","HTTP_HOST":"domain2.programster.org","HTTP_ACCEPT_ENCODING":"gzip, deflate, br","HTTP_SEC_FETCH_MODE":"navigate","HTTP_SEC_FETCH_USER":"?1","HTTP_X_FORWARDED_HOST":"domain2.programster.org","HTTP_UPGRADE_INSECURE_REQUESTS":"1","AUTH_TYPE":"","PATH_INFO":"","REQUEST_SCHEME":"https","HTTP_SEC_FETCH_DEST":"document","HTTP_TE":"trailers","QUERY_STRING":"","REMOTE_ADDR":"172.20.0.1","SERVER_PORT":"443","HTTPS":"on","SSL_CIPHER":"TLS_AES_128_GCM_SHA256","HTTP_COOKIE":"","CONTENT_TYPE":"","REQUEST_METHOD":"GET","SERVER_NAME":"domain2.programster.org","SERVER_SOFTWARE":"Caddy/v2.7.6","DOCUMENT_ROOT":"/var/www/site/public_html"},"request":{"remote_ip":"172.20.0.1","remote_port":"37088","client_ip":"172.20.0.1","proto":"HTTP/2.0","method":"GET","host":"domain2.programster.org","uri":"/index.php","headers":{"Cookie":[],"Accept-Encoding":["gzip, deflate, br"],"Sec-Fetch-Mode":["navigate"],"X-Forwarded-Proto":["https"],"X-Forwarded-Host":["domain2.programster.org"],"Accept-Language":["en-GB,en;q=0.5"],"Upgrade-Insecure-Requests":["1"],"Sec-Gpc":["1"],"Sec-Fetch-Site":["none"],"Cache-Control":["no-cache"],"User-Agent":["Mozilla/5.0 (X11; Linux x86_64; rv:124.0) Gecko/20100101 Firefox/124.0"],"Accept":["text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,*/*;q=0.8"],"Sec-Fetch-Dest":["document"],"Dnt":["1"],"Pragma":["no-cache"],"Te":["trailers"],"Sec-Fetch-User":["?1"],"X-Forwarded-For":["172.20.0.1"]},"tls":{"resumed":true,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"domain2.programster.org"}}}
demo | {"level":"debug","ts":1712335895.170236,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip","upstream":"127.0.0.1:9000","duration":0.00241281,"request":{"remote_ip":"172.20.0.1","remote_port":"37088","client_ip":"172.20.0.1","proto":"HTTP/2.0","method":"GET","host":"domain2.programster.org","uri":"/index.php","headers":{"X-Forwarded-For":["172.20.0.1"],"Te":["trailers"],"Sec-Fetch-User":["?1"],"Sec-Fetch-Mode":["navigate"],"X-Forwarded-Proto":["https"],"X-Forwarded-Host":["domain2.programster.org"],"Cookie":[],"Accept-Encoding":["gzip, deflate, br"],"Sec-Fetch-Site":["none"],"Cache-Control":["no-cache"],"User-Agent":["Mozilla/5.0 (X11; Linux x86_64; rv:124.0) Gecko/20100101 Firefox/124.0"],"Accept":["text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,*/*;q=0.8"],"Accept-Language":["en-GB,en;q=0.5"],"Upgrade-Insecure-Requests":["1"],"Sec-Gpc":["1"],"Pragma":["no-cache"],"Sec-Fetch-Dest":["document"],"Dnt":["1"]},"tls":{"resumed":true,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"domain2.programster.org"}},"headers":{"Content-Type":["text/html; charset=UTF-8"]},"status":200}
demo | {"level":"debug","ts":1712335895.1977758,"logger":"http.handlers.rewrite","msg":"rewrote request","request":{"remote_ip":"172.20.0.1","remote_port":"37088","client_ip":"172.20.0.1","proto":"HTTP/2.0","method":"GET","host":"domain2.programster.org","uri":"/favicon.ico","headers":{"Sec-Fetch-Mode":["no-cors"],"Dnt":["1"],"Pragma":["no-cache"],"Te":["trailers"],"User-Agent":["Mozilla/5.0 (X11; Linux x86_64; rv:124.0) Gecko/20100101 Firefox/124.0"],"Accept":["image/avif,image/webp,*/*"],"Sec-Fetch-Dest":["image"],"Sec-Fetch-Site":["same-origin"],"Cache-Control":["no-cache"],"Sec-Gpc":["1"],"Accept-Encoding":["gzip, deflate, br"],"Referer":["https://domain2.programster.org/"],"Cookie":[],"Accept-Language":["en-GB,en;q=0.5"]},"tls":{"resumed":true,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"domain2.programster.org"}},"method":"GET","uri":"/my-subfolder/favicon.ico"}
demo | {"level":"debug","ts":1712335895.1978335,"logger":"http.handlers.rewrite","msg":"rewrote request","request":{"remote_ip":"172.20.0.1","remote_port":"37088","client_ip":"172.20.0.1","proto":"HTTP/2.0","method":"GET","host":"domain2.programster.org","uri":"/my-subfolder/favicon.ico","headers":{"Sec-Fetch-Site":["same-origin"],"Cache-Control":["no-cache"],"Accept-Encoding":["gzip, deflate, br"],"Referer":["https://domain2.programster.org/"],"Cookie":[],"Sec-Gpc":["1"],"Accept-Language":["en-GB,en;q=0.5"],"Dnt":["1"],"Pragma":["no-cache"],"Te":["trailers"],"User-Agent":["Mozilla/5.0 (X11; Linux x86_64; rv:124.0) Gecko/20100101 Firefox/124.0"],"Accept":["image/avif,image/webp,*/*"],"Sec-Fetch-Dest":["image"],"Sec-Fetch-Mode":["no-cors"]},"tls":{"resumed":true,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"domain2.programster.org"}},"method":"GET","uri":"/index.php"}
demo | {"level":"debug","ts":1712335895.197854,"logger":"http.handlers.reverse_proxy","msg":"selected upstream","dial":"127.0.0.1:9000","total_upstreams":1}
demo | {"level":"debug","ts":1712335895.1979272,"logger":"http.reverse_proxy.transport.fastcgi","msg":"roundtrip","request":{"remote_ip":"172.20.0.1","remote_port":"37088","client_ip":"172.20.0.1","proto":"HTTP/2.0","method":"GET","host":"domain2.programster.org","uri":"/index.php","headers":{"Accept":["image/avif,image/webp,*/*"],"Dnt":["1"],"Sec-Gpc":["1"],"Accept-Language":["en-GB,en;q=0.5"],"X-Forwarded-Proto":["https"],"Sec-Fetch-Site":["same-origin"],"Referer":["https://domain2.programster.org/"],"Sec-Fetch-Dest":["image"],"Sec-Fetch-Mode":["no-cors"],"Te":["trailers"],"User-Agent":["Mozilla/5.0 (X11; Linux x86_64; rv:124.0) Gecko/20100101 Firefox/124.0"],"Cookie":[],"Accept-Encoding":["gzip, deflate, br"],"Pragma":["no-cache"],"Cache-Control":["no-cache"],"X-Forwarded-For":["172.20.0.1"],"X-Forwarded-Host":["domain2.programster.org"]},"tls":{"resumed":true,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"domain2.programster.org"}},"env":{"REMOTE_USER":"","SERVER_NAME":"domain2.programster.org","REQUEST_URI":"/favicon.ico","SERVER_PORT":"443","HTTPS":"on","HTTP_TE":"trailers","HTTP_USER_AGENT":"Mozilla/5.0 (X11; Linux x86_64; rv:124.0) Gecko/20100101 Firefox/124.0","HTTP_PRAGMA":"no-cache","AUTH_TYPE":"","GATEWAY_INTERFACE":"CGI/1.1","REMOTE_HOST":"172.20.0.1","DOCUMENT_ROOT":"/var/www/site/public_html","HTTP_HOST":"domain2.programster.org","HTTP_CACHE_CONTROL":"no-cache","HTTP_ACCEPT":"image/avif,image/webp,*/*","HTTP_DNT":"1","DOCUMENT_URI":"/index.php","SSL_PROTOCOL":"TLSv1.3","HTTP_SEC_FETCH_MODE":"no-cors","HTTP_REFERER":"https://domain2.programster.org/","SSL_CIPHER":"TLS_AES_128_GCM_SHA256","HTTP_ACCEPT_ENCODING":"gzip, deflate, br","HTTP_X_FORWARDED_FOR":"172.20.0.1","CONTENT_LENGTH":"","REMOTE_PORT":"37088","SERVER_PROTOCOL":"HTTP/2.0","SERVER_SOFTWARE":"Caddy/v2.7.6","SCRIPT_FILENAME":"/var/www/site/public_html/index.php","HTTP_X_FORWARDED_HOST":"domain2.programster.org","QUERY_STRING":"","HTTP_SEC_FETCH_DEST":"image","HTTP_COOKIE":"","CONTENT_TYPE":"","PATH_INFO":"","REQUEST_SCHEME":"https","HTTP_X_FORWARDED_PROTO":"https","HTTP_SEC_GPC":"1","HTTP_SEC_FETCH_SITE":"same-origin","REMOTE_IDENT":"","REMOTE_ADDR":"172.20.0.1","REQUEST_METHOD":"GET","SCRIPT_NAME":"/index.php","HTTP_ACCEPT_LANGUAGE":"en-GB,en;q=0.5"},"dial":"127.0.0.1:9000","env":{"SERVER_NAME":"domain2.programster.org","REQUEST_URI":"/favicon.ico","SERVER_PORT":"443","HTTPS":"on","REMOTE_USER":"","GATEWAY_INTERFACE":"CGI/1.1","REMOTE_HOST":"172.20.0.1","DOCUMENT_ROOT":"/var/www/site/public_html","HTTP_HOST":"domain2.programster.org","HTTP_TE":"trailers","HTTP_USER_AGENT":"Mozilla/5.0 (X11; Linux x86_64; rv:124.0) Gecko/20100101 Firefox/124.0","HTTP_PRAGMA":"no-cache","AUTH_TYPE":"","HTTP_ACCEPT":"image/avif,image/webp,*/*","HTTP_DNT":"1","HTTP_CACHE_CONTROL":"no-cache","SSL_PROTOCOL":"TLSv1.3","HTTP_SEC_FETCH_MODE":"no-cors","HTTP_REFERER":"https://domain2.programster.org/","DOCUMENT_URI":"/index.php","REMOTE_PORT":"37088","SERVER_PROTOCOL":"HTTP/2.0","SERVER_SOFTWARE":"Caddy/v2.7.6","SCRIPT_FILENAME":"/var/www/site/public_html/index.php","SSL_CIPHER":"TLS_AES_128_GCM_SHA256","HTTP_ACCEPT_ENCODING":"gzip, deflate, br","HTTP_X_FORWARDED_FOR":"172.20.0.1","CONTENT_LENGTH":"","HTTP_X_FORWARDED_HOST":"domain2.programster.org","HTTP_SEC_FETCH_DEST":"image","HTTP_COOKIE":"","QUERY_STRING":"","PATH_INFO":"","REQUEST_SCHEME":"https","HTTP_X_FORWARDED_PROTO":"https","CONTENT_TYPE":"","HTTP_SEC_FETCH_SITE":"same-origin","HTTP_SEC_GPC":"1","REMOTE_ADDR":"172.20.0.1","REQUEST_METHOD":"GET","SCRIPT_NAME":"/index.php","HTTP_ACCEPT_LANGUAGE":"en-GB,en;q=0.5","REMOTE_IDENT":""},"request":{"remote_ip":"172.20.0.1","remote_port":"37088","client_ip":"172.20.0.1","proto":"HTTP/2.0","method":"GET","host":"domain2.programster.org","uri":"/index.php","headers":{"Cache-Control":["no-cache"],"X-Forwarded-For":["172.20.0.1"],"X-Forwarded-Host":["domain2.programster.org"],"Pragma":["no-cache"],"Dnt":["1"],"Sec-Gpc":["1"],"Accept-Language":["en-GB,en;q=0.5"],"X-Forwarded-Proto":["https"],"Accept":["image/avif,image/webp,*/*"],"Referer":["https://domain2.programster.org/"],"Sec-Fetch-Site":["same-origin"],"Sec-Fetch-Mode":["no-cors"],"Te":["trailers"],"User-Agent":["Mozilla/5.0 (X11; Linux x86_64; rv:124.0) Gecko/20100101 Firefox/124.0"],"Cookie":[],"Accept-Encoding":["gzip, deflate, br"],"Sec-Fetch-Dest":["image"]},"tls":{"resumed":true,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"domain2.programster.org"}}}
demo | {"level":"debug","ts":1712335895.2011986,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip","upstream":"127.0.0.1:9000","duration":0.003314738,"request":{"remote_ip":"172.20.0.1","remote_port":"37088","client_ip":"172.20.0.1","proto":"HTTP/2.0","method":"GET","host":"domain2.programster.org","uri":"/index.php","headers":{"Accept":["image/avif,image/webp,*/*"],"Dnt":["1"],"Sec-Gpc":["1"],"Accept-Language":["en-GB,en;q=0.5"],"X-Forwarded-Proto":["https"],"Sec-Fetch-Site":["same-origin"],"Referer":["https://domain2.programster.org/"],"Sec-Fetch-Dest":["image"],"Sec-Fetch-Mode":["no-cors"],"Te":["trailers"],"User-Agent":["Mozilla/5.0 (X11; Linux x86_64; rv:124.0) Gecko/20100101 Firefox/124.0"],"Cookie":[],"Accept-Encoding":["gzip, deflate, br"],"Pragma":["no-cache"],"Cache-Control":["no-cache"],"X-Forwarded-For":["172.20.0.1"],"X-Forwarded-Host":["domain2.programster.org"]},"tls":{"resumed":true,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"domain2.programster.org"}},"headers":{"Status":["404 Not Found"],"Content-Type":["text/html;charset=UTF-8"]},"status":404}
I’m running Caddy v2.7.6 h1:w0NymbG2m9PcvKWsrXO6EEkY9Ru4FJK8uQbYcev1p3A=
I installed Caddy in a Docker container on Debian 12 with the following beginning of my Dockerfile:
FROM debian:12
RUN apt-get update && apt-get dist-upgrade -y
# Install the relevant packages
RUN apt-get install -y php-fpm curl php8.2-curl php8.2-xml php8.2-mbstring php8.2-bcmath git unzip php8.2-zip \
supervisor cron curl composer vim
# Install caddy webserver
RUN apt-get install -y debian-keyring debian-archive-keyring apt-transport-https curl -y \
&& curl -1sLf 'https://dl.cloudsmith.io/public/caddy/stable/gpg.key' | gpg --dearmor -o /usr/share/keyrings/caddy-stable-archive-keyring.gpg \
&& curl -1sLf 'https://dl.cloudsmith.io/public/caddy/stable/debian.deb.txt' | tee /etc/apt/sources.list.d/caddy-stable.list \
&& apt-get update \
&& apt-get install caddy -y
It runs caddy on startup as the foreground process with:
/usr/bin/caddy run --config=/etc/caddy/Caddyfile
No commands manually run
I’m running caddy inside my app, rather than as a separate container, but just in-case you need my docker-compose.yaml file:
app:
build:
context: .
dockerfile: Dockerfile
container_name: demo
image: demo
- ./site:/var/www/site
- ./ssl:/ssl
# global options
*.programster.org {
handle @foo {
handle @bar {
