aiozufh
(Caddy'Fellow)
April 19, 2025, 7:12am
1
I’m trying to send a 403 code while rewriting the reponse of a proxy when a condition is met.
Here is my configuration:
reverse_proxy {
to {args[0]}
trusted_proxies 10.0.0.0/8 {args[1]} {args[2]}
@auth header X-Auth-Status 403
handle_response @auth {
root * /usr/local/share/html
@fr header Accept-Language *fr*
handle @fr {
rewrite * /403-fr.html
rewrite * /403.html
Problem is that, if i add a simple error 403
under handle_response
, the 403
is sent, but i loose the custom page. Probably I’m not doing the right thing here
Unrelated
aiozufh
(Caddy'Fellow)
April 19, 2025, 7:28am
2
I think I’ve fixed it:
reverse_proxy {
to {args[0]}
handle @fr {
file_server {
status 403
rewrite * /403.html
file_server {
status 403
Is this correct?
Mohammed90
(Mohammed Al Sahaf)
April 19, 2025, 8:14pm
3
I think it’s best if you use error
then serve the custom page in handle_errors
aiozufh
(Caddy'Fellow)
April 20, 2025, 6:25am
4
But that would server custom page to all 403, no? It should be only if X-Auth-Status reports 403.
reverse_proxy {
to {args[0]}
error 403
handle_errors {
handle @fr {
rewrite * /403.html
Mohammed90
(Mohammed Al Sahaf)
April 21, 2025, 8:24pm
5
Yes, you’re right. I thought you want to do the same for all 403. In that case, your earlier solution should work. Doesn’t it?
By the way, trusted_proxies
is no longer supported in reverse_proxy
and is now a server option.
Also, you don’t need to do this this way:
The *
in rewrite
is a matcher. Use it with the named matcher.
aiozufh
(Caddy'Fellow)
April 22, 2025, 5:42am
6
Thanks, I’ve simplified to:
reverse_proxy {
to {args[0]}
rewrite @fr /403-fr.html
rewrite * /403.html
file_server {
status 403
system
(system)
Closed
May 22, 2025, 5:43am
7
