v2.4.5 h1:P1mRs6V2cMcagSPn+NWpD+OEYUYLIf6ecOa48cFGeUg=
- Installed from cloudsmith.io
- Local root cert created using
caddy trust
- Started via std systemd service file
- Raspberry Pi OS, 2022-01-28 release, (based on debian bullseye)
Type=notify
admin off
auto_https disable_redirects
on_demand_tls {
ask http://localhost:8081/ip-ok
:443 {
# where to look for files
root * /opt/sensorgnome/web-portal/public
# if path is / and file need_init exists then rewrite to config.html
# so the user gets the initial configuration stuff
@start_init {
path /
file need_init
rewrite @start_init /init/config
# handle initial configuration paths
handle_path /init/* {
# if the request doesn't match a file, try an action
@init_action not file {path}
reverse_proxy @init_action localhost:8081
# else serve file
# handle captive portal magic
redir /generate_204 /
redir /gen_204 /
redir /blank.html /
redir /mobile/status.php /
redir /hotspot-detect.html /
@captive_ua header User-Agent *CaptiveNetworkSupport*
redir @captive_ua /init/apple-hotspot.html
# error if we need init and nothing above handles the request
@need_init file need_init
respond @need_init 404
# normal sg-control app only if init is done
reverse_proxy localhost:8080
# ensure we get automatic certs and redirect from HTTP
tls internal {
on_demand
rewrite * /redirect
reverse_proxy localhost:8081
3. The problem Iâm having:
In general, the self-signed certificates work well and as expected, except that theyâre not trusted after 24 hours, i.e. after renewal. Any suggestions to avoid this?
Specifically:
- Access the site with a specific browser&laptop
- Jump through the browserâs hoops to accept the certificate
- Enjoy the site, then go away
- Come back 24hrs later, after the certificate has expired and access the site again using the same browser&laptop
- Observe that you have to jump through the hoops all over again, why? I assume because the browser marks the end certificate as trusted, not the intermediate or root cert?
Background:
- Iâm rebuilding software for an IoT device to be used for scientific data collection in the field with over 1000 devices deployed
- About half will have an internet connection on some random network, the other half will not (only accessed through hotspot provided by the device)
- The devices will be installed by their users, many at gov agencies or non-profits, most donât have any network knowledge
- Any proper HTTPS cert (non self-signed) would require accessing devices using something like
device-1234.example.com
with a domain I host, would require updating that domain as devices get new DHCP leases and thus change IP addresses, and would require the use of ACME-DNS for cert renewal, and all that really only works for the devices that are connected (which can be accessed more easily through a central management siteâŚ)
Itâs quite appalling that browsers donât support any user-friendly HTTPS option for disconnected IoT devicesâŚ
Is there a set-up that lets users trust a deviceâs self-signed cert once and not every day? (This would also be more secure 'cause it would flag if someone were to try impersonating a device.)
4. Steps to reproduce
- Start caddy with auto-https self-signed certs
- Access site with web browser (chrome and firefox on linux are what I tested), click through warnings to trust the certificate
- Terminate browser process completely
- Restart browser, access the site again, observe that the self-signed cert remains trusted (no warning)
- Terminate browser process again
- Delete caddyâs certificates (in my case
rm -rf /var/lib/caddy/.local/share/caddy/certificates/local/192.168.0.92
) - Restart caddy
- Restart browser, access the site yet again, observe that the new self-signed cert is no longer trusted
The logs after restarting caddy indicate that the root cert did not get changed by caddy, only the site cert:
Feb 06 16:05:39 SG-1BA7RPI47F3A caddy[19953]: {"level":"info","ts":1644181539.6719332,"logger":"pki.ca.local","msg":"root certificate is already trusted by system","path":"storage:pki/authorities/local/root.crt"}
Feb 06 16:05:39 SG-1BA7RPI47F3A caddy[19953]: {"level":"info","ts":1644181539.6724877,"logger":"tls","msg":"cleaning storage unit","description":"FileStorage:/var/lib/caddy/.local/share/caddy"}
Feb 06 16:05:41 SG-1BA7RPI47F3A caddy[19953]: {"level":"info","ts":1644181541.199466,"logger":"tls.on_demand","msg":"obtaining new certificate","server_name":"192.168.0.92"}
Feb 06 16:05:41 SG-1BA7RPI47F3A caddy[19953]: {"level":"info","ts":1644181541.2016525,"logger":"tls.obtain","msg":"acquiring lock","identifier":"192.168.0.92"}
Feb 06 16:05:41 SG-1BA7RPI47F3A caddy[19953]: {"level":"info","ts":1644181541.216271,"logger":"tls.obtain","msg":"lock acquired","identifier":"192.168.0.92"}
Feb 06 16:05:41 SG-1BA7RPI47F3A caddy[19953]: {"level":"info","ts":1644181541.2304127,"logger":"tls.obtain","msg":"certificate obtained successfully","identifier":"192.168.0.92"}
Feb 06 16:05:41 SG-1BA7RPI47F3A caddy[19953]: {"level":"info","ts":1644181541.230971,"logger":"tls.obtain","msg":"releasing lock","identifier":"192.168.0.92"}
Feb 06 16:05:41 SG-1BA7RPI47F3A caddy[19953]: {"level":"warn","ts":1644181541.23515,"logger":"tls","msg":"stapling OCSP","error":"no OCSP stapling for [192.168.0.92]: no OCSP server specified in certificate"}
