Self Signed Cert Reverse Proxy
OpenWrt 19.07.0, r10860-a3ffeb413b (x64)
cat /etc/rc.local
exit0
www.mydomain.cc {
reverse_proxy * 10.0.0.1:8888
sub1.mydomain.cc {
reverse_proxy * 10.0.0.1:8082
sub2.mydomain.cc {
reverse_proxy * 10.0.0.2:1880
sub3.mydomain.cc {
reverse_proxy * 10.0.0.2:81
sub4.mydomain.cc {
reverse_proxy * 10.0.0.3:8081
sub5.mydomain.cc {
reverse_proxy https://10.0.0.3:8443
insecure_skip_verify
I am attempting to reverse proxy one server that only serves HTTPS with a self signed certificate. There is no option to just have the server use HTTP.
The rest of the subdomains work as they are with no other configuration required.
What are the correct directives and syntax to reverse proxy this single server? Caddy v1 was able to use the insecure_skip_verify whereas now I am no longer able to do so. I have searched for four weeks without finding a full working example or a complete syntax guide for the Caddyfile.
Basically I expect Caddy2 to be able to insecurely interact with the backend for sub5.mydomain.cc and be able to reverse proxy as if it were a simple HTTP server. (Inclusive of grabbing ACME certs for the domain.)
2020/05/12 15:08:24.323 INFO using adjacent Caddyfile
reload: adapting config using caddyfile: Caddyfile:18: unrecognized directive: insecure_skip_verify
See above.
https://kbeflo.github.io/2019/05/25/OpenWrt-self-signed-certificate/
the directive is not
but
tls_insecure_skip_verify
and it is used inside a transport http directive, e.g.
sub5.mydomain.cc {
  reverse_proxy https://10.0.0.3:8443 {
      tls
FYI if you specify https:// on your proxy upstream, you can omit the tls transport subdirective (but you’ll still need tls_insecure_skip_verify in your case if you can’t trust the upstream)
Thank you. This is functional first try.
