Hi,
I’m not good at either Golang or encryption.
Just wondering, for self_signed tsl, is it possible to generate the cert with a seed? So that you don’t have to go through adding exception for the dev site every time you restart caddy?
Thanks,
Po
Hi,
Thanks,
Po
Hey Po, if you use Chrome, you can use the #allow-insecure-localhost flag to disable certificate warnings on localhost.
Otherwise no, there’s not a way (right now?) to do that. Just keeping things simple.
Is there any equivalent solution for firefox?
Thank you for your help!
Quick google search led me to this: http://stackoverflow.com/questions/20088/is-there-a-way-to-make-firefox-ignore-invalid-ssl-certificates
