See memory usage?
How can I see the memory usage of caddy when in use? I’ve been looking into the telemetry but keep hitting a brick wall with the 502 error.
I’ve used Apache before, is there anything like the scoreboard for caddy?
Cheers
Josh
Hi @Joshua_Sears,
Caddy doesn’t have any outputs like the scoreboard.
Your best bet to get an understanding of Caddy’s memory usage would probably be ps aux on a *nix- or BSD-like system, or the Task Manager on Windows.
Okay, thanks @Whitestrake
Task manager will have to do!
