What are you trying to do?
Get caddy working on Mac with all browsers using localhost and localhost subdomain.
caddyfile
Caddyfile
email xxx@gmail.com
output stdout
format console
level DEBUG
admin :2019
https://localhost
localhost {
file_server {
root {$CADDY_RUN_VAR_BROWSE_PATH}
browse
https://hello.localhost
hello.localhost {
respond “Hello world!”
https://app.localhost
app.localhost {
reverse_proxy {$CADDY_RUN_VAR_PROXY_PATH_PORT}
https://wasm.localhost
wasm.localhost {
respond “Hello world wasm !”
What isn’t working?
Safari is not working. FF and Chrome always works.
When I use the cafe wifi, safari subdomains fail.
When I use my iPhone for the wifi, safari works.
Under all conditions FF and chrome works.
curl -vL https://app.localhost works always.
master off GitHub.
darwin, arm64
go build -tags=nobadger,nomysql,nopgx -trimpath -ldflags=“-w -s” -v
latest Mac.
caddy run --config /Users/apple/workspace/go/src/github.com/gedw99/kanka-cloudflare/modules/cadd-try/infogulch__xtemplate/…/…/.dep/caddy_config_caddyfile --adapter caddyfile --watch
not using docker.
I need a way to work out why being on the wifi screws up caddy with Safari.
My end users run caddy on their Desktops as an edge network, and I need a way to diagnose what it is about the network that screws it up for Safari.
