Rutorrent + reverse proxy
Docker (compose)
Docker on Ubuntu 20.04.1
Docker: 19.03.12 (API: 1.40)
n/a - docker compose
        image: caddy
            - $CONFIG/caddy:/config
            - /home/user/Caddyfile:/etc/caddy/Caddyfile
            - caddy_data:/data
            - web
    rutorrent:
        image: linuxserver/rutorrent
        container_name: rutorrent
        depends_on:
            - mergerfs
            - $CONFIG/rutorrent:/config
            - $DOWNLOADS:/downloads
            - PUID=1000
            - PGID=1000
            - web
            - "8888:80"
my.web.site
rewrite /torrent /torrent/
reverse_proxy /torrent/* rutorrent:80
Upon visiting my.web.site/torrent I am presented with a nginx 404 error, so it is connecting to the contained successfully but assume there is additional config in the caddyfile required. Extensive googling has come up dry!
404 Not Found
nginx/1.18.0
Unsure what other config I can add to the caddyfile to get this working, any help appreciated!
I think you might be running into this:
It’s possible that rutorrent doesn’t allow for being served in a subfolder.
I recommend using a subdomain instead typically, it avoids most of the issues described in that article.
Right you are, subdomain worked like a charm - appreciate it!
