Running Wordpress in a VM with Caddy Reverse Proxy
1. Output of caddy version:
Not relevant
Windows 10
./caddy run --config ./Caddyfile
Caddyfile
home.movies4you.stream {
root * C:\Tools\OrganizrV2\www\organizr\html
php_fastcgi localhost:9000
rewrite /api/v2/* /api/v2/index.php?{query}
        dns cloudflare (cloudflare key)
requests.movies4you.stream {
    reverse_proxy 127.0.0.1:5055
accounts.movies4you.stream {
    reverse_proxy 127.0.0.1:8056
tv.movies4you.stream {
    reverse_proxy 127.0.0.1:8096
deluge.movies4you.stream {
    reverse_proxy 127.0.0.1:8112
adg.ittechnut.com {
    reverse_proxy 192.168.1.111:3000
photos.movies4you.stream {
    reverse_proxy 127.0.0.1:2342
ha.movies4you.stream {
    reverse_proxy 192.168.1.126:8123
ittechnut.com {
    reverse_proxy 192.168.1.128
hey so quick question. Im running wordpress in a vm on hyper-v using this iso WordPress | TurnKey GNU/Linux when i type in local 192.168.1.128 it brings me to my wordpress site. I want to reverse proxy it. my caddy is running on 192.168.1.111. I have other webapps running like so in a reverse proxy
I saw this example but do not know how this will work for me since my wp is on a different ip than my caddy but i do have apache running on this turnkey vm. Any help would be greatly apprecaited.
example.com {
    root * /home/illuminate/php_sites/wordpress
    php_fastcgi unix//run/php/php8.0-fpm.sock
    @disallowed {
        path /xmlrpc.php
        path *.sql
        path /wp-content/uploads/*.php
    rewrite @disallowed '/index.php'
would this work
newdomain.com {
FYI you can make this a lot less annoying by using a Caddyfile snippet to copy this into each site:
Yes, that should work. Did you try it?
yes it works but it is really messed up something graphically
That implies the CSS files aren’t loading. Check your browser’s network tab and see what you can find out.
Also, turn on the debug global option in Caddy and check you logs, see what it shows for some of these requests.
i see this issue which is exactly what I am dealing with but it is nginx. Is there a way to do this with caddy
Go down 3/4 of the way down the page
That’s not a change in Caddy that they’re talking about, it’s a change in a WordPress config file.
for anyone else who is having this issue follow this tutorial
edit your
/var/www/(wordpress-dir)/wp-config.php
i have since fixed the issue
