Running Next.js with next-ws for websockets on Caddy
Hi! I’m running a Next.js application using Caddy for reverse proxy:
placemat.veryroundbird.house {
        reverse_proxy localhost:3501
This works almost entirely fine, except that I’m serving a websocket from an API route (/api/streamMessages/[username]) using next-ws, and something about the way Caddy handles that isn’t producing the right set of response headers, I think. (The reason I suspect this is that just running it off a port on my local machine works just fine.)
Specifically, these are the headers I get on the websocket connection on my local machine using next run dev:
Connection: Upgrade
Sec-Websocket-Accept: 5BizIpU0OhKb5KA3qY4KO041E4w=
Upgrade: websocket
Whereas what I get returned on the Caddy server is:
Alt-Svc: h3=“:443”; ma=2592000
Date: Sat, 31 May 2025 04:05:55 GMT
Server: Caddy
So that’s the mystery! Why is it doing this.
n/a (there are no server errors, it’s just not doing the right thing)
I’m pretty sure I just installed it per the Debian/Ubuntu/Raspbian instructions in the install guide.
Ubuntu 24.04.1 LTS (GNU/Linux 6.8.0-60-generic x86_64)
caddy start
n/a
blotter.veryroundbird.house {
        root * /var/www/html/blotter/public
        try_files {path} {path}.html {path}/ =404
        handle_errors {
                rewrite * /{err.status_code}.html
        # php_fastcgi localhost:9000
spoverlay.veryroundbird.house {
        root * /var/www/html/streamplace-overlay
spoverlayapi.veryroundbird.house {
smallbird.live {
        root * /var/www/html/smallbirdlive
        root * /var/www/html/at
dev.placemat.veryroundbird.house {
        reverse_proxy localhost:3001
listmatcher.veryroundbird.house {
        root * /var/www/html/listmatcher
realized I can’t edit but possibly this will help for context? this is the application I’m working on
