Running caddy in docker on local, fronted by ngrok
I wanted to run a simple web server on local. So I ran caddy in a docker on my mac and started ngrok, to make the web server available to the world.
My problem is, although the Caddyfile had a named block for port 80 (and 443), it didn’t return 200. Instead it looked like it was redirected to 443. Shouldn’t it return 200 with message “Im healthy”?
richardchou@Richards-MacBook-Pro caddy_cluster % docker run -p 443:443 -p 80:80 caddy-cluster
{"level":"info","ts":1688693601.6755793,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":""}
{"level":"warn","ts":1688693601.6761997,"msg":"Caddyfile input is not formatted; run the 'caddy fmt' command to fix inconsistencies","adapter":"caddyfile","file":"/etc/caddy/Caddyfile","line":2}
{"level":"info","ts":1688693601.677662,"logger":"admin","msg":"admin endpoint started","address":"localhost:2019","enforce_origin":false,"origins":["//localhost:2019","//[::1]:2019","//127.0.0.1:2019"]}
{"level":"info","ts":1688693601.6778586,"logger":"http","msg":"server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS","server_name":"srv0","https_port":443}
{"level":"info","ts":1688693601.6778708,"logger":"http","msg":"enabling automatic HTTP->HTTPS redirects","server_name":"srv0"}
{"level":"warn","ts":1688693601.6778777,"logger":"http","msg":"server is listening only on the HTTP port, so no automatic HTTPS will be applied to this server","server_name":"srv1","http_port":80}
{"level":"info","ts":1688693601.6780093,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0x400007cd90"}
{"level":"info","ts":1688693601.678052,"logger":"http","msg":"enabling HTTP/3 listener","addr":":443"}
{"level":"info","ts":1688693601.678093,"msg":"failed to sufficiently increase receive buffer size (was: 208 kiB, wanted: 2048 kiB, got: 416 kiB). See https://github.com/quic-go/quic-go/wiki/UDP-Receive-Buffer-Size for details."}
{"level":"debug","ts":1688693601.6781404,"logger":"http","msg":"starting server loop","address":"[::]:443","tls":true,"http3":true}
{"level":"info","ts":1688693601.678162,"logger":"http.log","msg":"server running","name":"srv0","protocols":["h1","h2","h3"]}
{"level":"debug","ts":1688693601.6781754,"logger":"http","msg":"starting server loop","address":"[::]:80","tls":false,"http3":false}
{"level":"info","ts":1688693601.6781783,"logger":"http.log","msg":"server running","name":"srv1","protocols":["h1","h2","h3"]}
{"level":"info","ts":1688693601.6783762,"logger":"tls","msg":"cleaning storage unit","description":"FileStorage:/data/caddy"}
{"level":"info","ts":1688693601.6794465,"msg":"autosaved config (load with --resume flag)","file":"/config/caddy/autosave.json"}
{"level":"info","ts":1688693601.6794589,"msg":"serving initial configuration"}
{"level":"info","ts":1688693601.6821163,"logger":"tls","msg":"finished cleaning storage units"}
{"level":"debug","ts":1688694307.5788047,"logger":"events","msg":"event","name":"tls_get_certificate","id":"d065ce19-4254-4b16-94d7-88d0cbcd775f","origin":"tls","data":{"client_hello":{"CipherSuites":[49199,49200,49195,49196,52392,52393,49171,49161,49172,49162,156,157,47,53,49170,10,4865,4867,4866],"ServerName":"localhost","SupportedCurves":[29,23,24,25],"SupportedPoints":"AA==","SignatureSchemes":[2052,1027,2055,2053,2054,1025,1281,1537,1283,1539,513,515],"SupportedProtos":null,"SupportedVersions":[772,771,770,769],"Conn":{}}}}
{"level":"debug","ts":1688694307.5859387,"logger":"tls.handshake","msg":"no matching certificates and no custom selection logic","identifier":"localhost"}
{"level":"debug","ts":1688694307.5867674,"logger":"tls.handshake","msg":"no matching certificates and no custom selection logic","identifier":"*"}
{"level":"debug","ts":1688694307.5867815,"logger":"tls.handshake","msg":"all external certificate managers yielded no certificates and no errors","remote_ip":"172.17.0.1","remote_port":"59162","sni":"localhost"}
{"level":"debug","ts":1688694307.9071097,"logger":"tls","msg":"response from ask endpoint","domain":"localhost","url":"https://ezyraise.ap.ngrok.io?domain=localhost","status":404}
{"level":"debug","ts":1688694307.9083111,"logger":"http.stdlib","msg":"http: TLS handshake error from 172.17.0.1:59162: localhost: certificate not allowed by ask endpoint https://ezyraise.ap.ngrok.io - non-2xx status code 404"}
MacOS Apple M1
Docker Desktop
Building docker image
docker build -t caddy-cluster .
Starting container
docker run -p 80:80 -p 443:443 caddy-cluster
Starting ngrok
./ngrok http -subdomain=ezyraise -region au 443
Session Status                online
Account                       ezyraise (Plan: Pro)
Version                       2.3.41
Region                        Australia (au)
Web Interface                 http://127.0.0.1:4040
Forwarding                    http://ezyraise.au.ngrok.io -> https://localhost:443
Forwarding                    https://ezyraise.au.ngrok.io -> https://localhost:443
curl port 80
curl -vL http://ezyraise.au.ngrok.io/health
and it returned error 404
Dockerfile
FROM caddy:2.6.4-alpine
EXPOSE 80
EXPOSE 443
CMD ["caddy", "run", "--config", "/etc/caddy/Caddyfile"]
Caddyfile
    on_demand_tls {
        ask https://ezyraise.ap.ngrok.io
        burst 5
        interval 2m
    respond /health "Im healthy" 200
:443 {
        on_demand
    reverse_proxy https://tictactoeonrails.tamsui.xyz {
        header_down Strict-Transport-Security max-age=31536000
        header_up Host {host}
You can remove these lines from your Dockerfile, they’re redundant.
You can remove these as well, they’re also redundant. Caddy passes through X-Forwarded-For already.
The problem is that HTTP->HTTPS redirects take precedence over catch-all :80 sites. If you use a hostname instead of simply :80 then it will work. Or you can set auto_https disable_redirects to remove the redirects and let it through to your catch-all, but then you’d need to re-add HTTP->HTTPS redirects to your config yourself if you want them (easy with the redir directive though, one-liner).
Thank you, appreciate it
