Running Caddy for same domain name using separate servers
I have two vms both of which use the same domain name. One of these hosts a Foundry VTT server, the other hosts a Matrix server. The Foundry server predates the Matrix one and I used Caddy to allow me to use my domain name instead of the IP address of the server. I’m now trying to use the Caddy instance on the Foundry server to reverse-proxy the well-known files from the base domain’s server to the Matrix server as directed in this setup guide matrix-docker-ansible-deploy/docs/configuring-well-known.md at master · spantaleev/matrix-docker-ansible-deploy · GitHub. However, when I navigate to https://songofstone.com/.well-known/matrix/server I get an error of “Cannot GET /.wellknown/matrix/server”.
Caddy is not issuing any error messages.
v2.11.1
I installed Caddy via apt install caddy
OS: Ubuntu 24.04 Minimal aarch64
Architecture: Ampere Altra ARM-based processor VM.Standard.A1.Flex
The VM is running on OCI
I just use caddy reload?
songofstone.com {
    reverse_proxy localhost:30000
    reverse_proxy /.well-known/matrix/* https://matrix.songofstone.com {
    encode zstd gzip
https:// {
        tls internal {
                on_demand
        encode zstd gzip
I’m following the steps at matrix-docker-ansible-deploy/docs/configuring-well-known.md at master · spantaleev/matrix-docker-ansible-deploy · GitHub
