Run organizr locally with caddy v2
caddy v2.0.0
i run caddy to access jellyfin and ombi on the internet with cloudflare
windows 10
use windows as a service
systemd
paste full file contents here
jellyfin.mydomain.com {
		output file C:\caddy_2.0.0\logs\Jellyfin_access.log {
			roll true				# Rotate logs, enabled by default
			roll_size_mb 5			# Set max size 5 MB
			roll_gzip true			# Whether to compress rolled files
			roll_local_time true	# Use localhost time
			roll_keep 2				# Keep at most 2 log files
			roll_keep_days 7		# Keep log files for 7 days
	reverse_proxy localhost:8096
		dns cloudflare ##
ombi.mydomain.com {
		output file C:\caddy_2.0.0\logs\ombi_access.log {
	reverse_proxy localhost:5000
		dns cloudflare ###
does anybody in this forum use organizr with caddy v2? i am not sure how to make it work. the organizr will tell you to install it automatically with nginx but i am already using caddy for everything so i do not want to keep both or use nginx so can anybody help me with the configuration for organizr in caddy? i would not want to access it outside my network just inside but i am not sure how to make caddy to run the organizr so i can access it locally..
try different things without luck.. right now i do not have anything in place at all.
i tried installing it with nginx and then try to copy some of the caddy v2 examples from here but nothing works i guess i am not sure how to connect php with organizr and where to put organizr as in nginx everything goes inside that folder
Organizr is a PHP app, so I think you’ll need to install and run PHP for Caddy to be able to execute it via the php_fastcgi directive. There’s been a few threads on the forums about it, feel free to search for those to get an idea.
Also, I recommend upgrading to the latest version of Caddy (current stable is 2.1.1), there’s plenty of fixes that may help things along for you.
