2.4.3
I want to run Caddy as Reverse Proxy with Varnish 6.6 and Magento 2.4.2
Ubuntu 20.04 Focal ( Digitalocean droplet )
systemctl start caddy
Type=notify
# Caddyfile
admin 0.0.0.0:2020
https://mysite.com {
root * /var/www/mysite
reverse_proxy /pub/* 127.0.0.1:8443
Hi guys,
1- can someone help me to get config file ( Caddyfile or Json ) to run Caddy2 with Varnish >6.0lts and Magento 2.4.2, and use Caddy as Reverse proxy with Aytomatic Https or LetsEncrypt.
PS: my ports config
Apache2 listening = 8080
Apache2 TCP6 listening = 443
Varnish listening = 80
Varnish listening = 8443
Varnish TCP6 listening = 80
Caddy listening = 80
thank you in advance
-------------------( curl -I mysite.com )
HTTP/1.1 301 Moved Permanently
Date: Wed, 01 Sep 2021 18:00:53 GMT
Server: Apache/2.4.41 (Ubuntu)
Content-Length: 297
Content-Type: text/html; charset=iso-8859-1
X-Varnish: 32907
Via: 1.1 varnish (Varnish/6.6)
Connection: keep-alive
-------------------( journalctl -u caddy --no-pager | less )
Sep 01 18:26:48 myhost systemd[1]: Started Caddy.
Sep 01 18:26:48 myhost caddy[816]: caddy.HomeDir=/var/lib/caddy
Sep 01 18:26:48 myhost caddy[816]: caddy.AppDataDir=/var/lib/caddy/.local/share/caddy
Sep 01 18:26:48 myhost caddy[816]: caddy.AppConfigDir=/var/lib/caddy/.config/caddy
Sep 01 18:26:48 myhost caddy[816]: caddy.ConfigAutosavePath=/var/lib/caddy/.config/caddy/autosave.json
Sep 01 18:26:48 myhost caddy[816]: caddy.Version=v2.4.3 h1:Y1FaV2N4WO3rBqxSYA8UZsZTQdN+PwcoOcAiZTM8C0I=
Sep 01 18:26:48 myhost caddy[816]: runtime.GOOS=linux
Sep 01 18:26:48 myhost caddy[816]: runtime.GOARCH=amd64
Sep 01 18:26:48 myhost caddy[816]: runtime.Compiler=gc
Sep 01 18:26:48 myhost caddy[816]: runtime.NumCPU=2
Sep 01 18:26:48 myhost caddy[816]: runtime.GOMAXPROCS=2
Sep 01 18:26:48 myhost caddy[816]: runtime.Version=go1.16.5
Sep 01 18:26:48 myhost caddy[816]: os.Getwd=/
Sep 01 18:26:48 myhost caddy[816]: LANG=C.UTF-8
Sep 01 18:26:48 myhost caddy[816]: PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/snap/bin
Sep 01 18:26:48 myhost caddy[816]: HOME=/var/lib/caddy
Sep 01 18:26:48 myhost caddy[816]: LOGNAME=caddy
Sep 01 18:26:48 myhost caddy[816]: USER=caddy
Sep 01 18:26:48 myhost caddy[816]: INVOCATION_ID=448b04d13cbf44cf84212bd4d4d3b5e6
Sep 01 18:26:48 myhost caddy[816]: JOURNAL_STREAM=9:25575
Sep 01 18:26:48 myhost caddy[816]: {"level":"info","ts":1630520808.8303964,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":""}
Sep 01 18:26:48 myhost caddy[816]: {"level":"warn","ts":1630520808.8375862,"msg":"input is not formatted with 'caddy fmt'","adapter":"caddyfile","file":"/etc/caddy/Caddyfile","line":3}
Sep 01 18:26:48 myhost caddy[816]: {"level":"info","ts":1630520808.8609362,"logger":"admin","msg":"admin endpoint started","address":"tcp/0.0.0.0:2020","enforce_origin":false,"origins":["0.0.0.0:2020"]}
Sep 01 18:26:48 myhost caddy[816]: {"level":"warn","ts":1630520808.8609786,"logger":"admin","msg":"admin endpoint on open interface; host checking disabled","address":"tcp/0.0.0.0:2020"}
Sep 01 18:26:48 myhost caddy[816]: {"level":"info","ts":1630520808.8707194,"logger":"http","msg":"server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS","server_name":"srv0","https_port":443}
Sep 01 18:26:48 myhost caddy[816]: {"level":"info","ts":1630520808.8707848,"logger":"http","msg":"enabling automatic HTTP->HTTPS redirects","server_name":"srv0"}
Sep 01 18:26:48 myhost caddy[816]: {"level":"info","ts":1630520808.8711464,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc00026caf0"}
Sep 01 18:26:48 myhost caddy[816]: {"level":"info","ts":1630520808.8786216,"logger":"tls","msg":"cleaning storage unit","description":"FileStorage:/var/lib/caddy/.local/share/caddy"}
Sep 01 18:26:48 myhost caddy[816]: {"level":"info","ts":1630520808.8786795,"logger":"tls","msg":"finished cleaning storage units"}
Sep 01 18:26:48 myhost caddy[816]: {"level":"info","ts":1630520808.8787818,"logger":"tls.cache.maintenance","msg":"stopped background certificate maintenance","cache":"0xc00026caf0"}
Sep 01 18:26:48 myhost caddy[816]: run: loading initial config: loading new config: http app module: start: tcp: listening on :443: listen tcp :443: bind: address already in use
Sep 01 18:26:48 myhost systemd[1]: caddy.service: Main process exited, code=exited, status=1/FAILURE
Sep 01 18:26:48 myhost systemd[1]: caddy.service: Failed with result 'exit-code'.
