Fyhong_Ng
(Fyhong Ng)
1
1. My Caddy version (caddy version
caddy2
./caddy run
centos 7
mysite.com {
tls ./fullchain.pem ./privkey.pem
matcher a {
path /apv1
matcher b {
path /apv2
rewrite match:a /apv1 /
rewrite match:b /apv2 /
reverse_proxy match:a localhost:8080
reverse_proxy match:b localhost:81
run: adapting config using caddyfile: Caddyfile:3: unrecognized directive: matcher
A few versions ago, matcher syntax changed to:
@a {
path /apv1
rewrite @a /apv1 /
Also since you’re just using a simple path matcher, you can just change your Caddyfile to something like this, I think:
mysite.com {
route /apv1/* {
strip_prefix apv1/
reverse_proxy localhost:8080
route /apv2/* {
strip_prefix apv2/
reverse_proxy localhost:81
See route (Caddyfile directive) — Caddy Documentation for an example of this
Fyhong_Ng
(Fyhong Ng)
3
Thanks for the quick answer!
system
(system)
Closed
4
