Routing wildcard subdomains to appropriate publicly accessible S3 buckets
I’m trying to set up a Caddy server that handles both wildcard subdomains and root domain requests, serving static files from appropriate publicly accessible S3 buckets
Example Scenario:
If someone visits https://blog.example.com, it should serve files from https://mys3bucket.com/blog/ If someone visits https://example.com, it should serve from a mys3bucket.com/home/ bucket
Fedora 40
dnf install 'dnf-command(copr)'
dnf copr enable @caddy/caddy
dnf install caddy
c. My complete Caddy config:
    admin off
http://*.example.com {
    reverse_proxy https://myS3bucket.com/{labels.2}
reverse_proxy doesn’t take a path as the upstream address. It’s only a host and port, with an optional scheme as a shortcut for transport config. See reverse_proxy (Caddyfile directive) — Caddy Documentation
You need to rewrite the URL before proxying.
Also if you’re proxying over HTTPS, you likely need to override the Host header to match the domain the upstream expects reverse_proxy (Caddyfile directive) — Caddy Documentation
	rewrite * /{labels.2}{uri}
	reverse_proxy https://myS3bucket.com {
