v2.4.6
i ran it via docker using official caddy image
Official Docker Image
docker-compose up
version: '3.9'
file:
image: maxime1907/filegator
restart: always
- 2233:443
- $PWD/web:/data
PUID: 33
GUID: 33
php:
build: .
restart: always
- $PWD/web:/app/public
- $PWD/php.ini:/usr/local/etc/php/php.ini
image: caddy
restart: always
- 443:443
depends_on:
- db
- php
- file
http_port 80
https_port 443
localhost {
handle_errors {
respond "{http.error.status_code} {http.error.status_text}"
redir /filegator /filegator/ permanent
route /filegator/* {
uri strip_prefix /filegator/
reverse_proxy * 172.18.0.1:2233
root * /app/public/
php_fastcgi php:9000
so i have filegator on port 2222 for http and 2233 for https and it works fine when i access these ports.
But when i want to to reverse proxy port 2233 to subdir https://localhost/**filegator** it returned status 400 check screenshot bellow
Here are some Header Detal from [curl --head]:
localhost:2222 (http)
HTTP/1.1 200 OK
Server: nginx/1.18.0
Content-Type: text/html; charset=UTF-8
Connection: keep-alive
X-Powered-By: PHP/7.3.32
Set-Cookie: filegator=mg40jq7c9e43kguhmdh6tl9ode; path=/; HttpOnly; SameSite=Lax
Cache-Control: no-cache, private
Date: Mon, 13 Jun 2022 08:19:04 GMT
X-CSRF-Token: awKSb4hb3iW4YTktHbsmpSsQSbsohfj3nT6d7IPT2P8
X-Frame-Options: sameorigin
Content-Security-Policy: frame-ancestors 'self'
localhost:2222 (https)
curl: (35) error:1408F10B:SSL routines:ssl3_get_record:wrong version number
localhost:2233 (http)
HTTP/1.1 400 Bad Request
Date: Mon, 13 Jun 2022 08:21:18 GMT
Content-Length: 255
Connection: close
localhost:2233 (https)
HTTP/1.1 200 OK
Set-Cookie: filegator=pikhmpk40bbv0dj6fq50nvmk31; path=/; HttpOnly; SameSite=Lax
Date: Mon, 13 Jun 2022 08:21:39 GMT
X-CSRF-Token: qw0O6gExfusDP4kw_1fVefsfi5ofijVXzfRXwMl9J6E
and last this is the screenshot when i try to access https://localhost/filegator/
to be honest, nothing at all. idk anything about this
