Route both websocket and https
I have a caddyfile ok with basic auth on https requests for port 12345.
now I have a service running websocket on port 23456, how to add it into the caddyfile?
Ubuntu22.04
sudo caddy fmt Caddyfile --overwrite
sudo caddy reload Caddyfile
The original caddyfile that works:
this_is_the_doman_name.xyz {
        basicauth {
                admin secret
        reverse_proxy 127.0.0.1:12345
        handle_errors {
                respond "{http.error.status_code} {http.error.status_text}"
        # Log startup messages
                output file /var/log/caddy/vitalik.log
                format json
Now I modify it to
    @port12345 {
        host this_is_the_doman_name.xyz
        header Host ":12345"
    route @port12345 {
        basicauth {
            admin1 secret
    # Route for WebSocket requests on port 23456
    @port23456 {
        header Host ":23456"
    route @port23456 {
        basicauth {
            admin2 secret
        reverse_proxy 127.0.0.1:23456
        handle_errors {
                format json
Now both routes not responding.
Please upgrade to the latest version, v2.7.4.
Your Caddyfile is listening on port 80 and 443, not on port 12345. That doesn’t make sense, your config doesn’t match what you say.
You can use the same port, and use a matcher to match websocket requests.
example.com {
	@websockets `header({'Connection':'*Upgrade*','Upgrade':'websocket'})`
	handle @websockets {
thank you ser! i also find it in the matcher document.
now i have the caddyfile:
ws.example.com {
tp.example.com {
after setting this, i am confused about how to establish ws connection.
simple test program:
import asyncio
import json
import websockets
async def hello():
    async with websockets.connect('ws://localhost:23456') as websocket:
        payload = somethng
        await websocket.send(payload)
        response = await websocket.recv()
        print(f"< {response}")
asyncio.get_event_loop().run_until_complete(hello())
if i am on my server environment, i can simply run this.
but if i am not in the server environment, which mean i should replace ws://localhost:23456 with ws://ws.example.com , it’s not working. it reports:
websockets.exceptions.RedirectHandshake: redirect to https://ws.example.com/
You need to use wss:// (i.e. websockets + TLS). And also you don’t need a separate subdomain, you can put both in the same site block.
