1. Output of caddy version:
v2.6.1 h1:EDqo59TyYWhXQnfde93Mmv4FJfYe00dO60zMiEt+pzo=
I installed Cddy using sudo apt install caddy on my Ubuntu server, and I run it as a systemctl service.
OS: Ubuntu 22.04 x64
systemctl reload caddy
/etc/caddy/example.com
example.com {
root * /var/www/html/example.com
# 404 errors
handle_errors {
@404 {
expression {http.error.status_code} == 404
rewrite @404 /404.html
www.example.com {
redir https://example.com{uri} permanent
/etc/caddy/tools.example.com
tools.example.com {
reverse_proxy 127.0.0.1:4000
/etc/caddy/Caddyfile
root * /usr/share/caddy
# php_fastcgi localhost:9000
# example.com
import ./example.com
# tools.example.com
import ./tools.example.com
So I have a static website hosted at example.com and a NodeJS app with a reverse proxy on tools.example.com (see above Caddyfiles).
I want that if someone visits example.com/tools, they are shown the tools.example.com site, without changing the URL (so not a redirect).
I’ve tried rewrite /tools to https://tools.example.com and rewrite /tools to 127.0.0.1:4000
