Rewrite, templates and Content-Type
I’m trying to process some template files, saved on disk as blah.gohtml
The files are served by Caddy literally, so the template functionality isn’t invoked
caddy:2-alpine
podman
macOs something
podman run --rm -v ./htdocs:/usr/share/caddy -v ./Caddyfile.test:/etc/caddy/Caddyfile -p 8080:80 caddy:2-alpine
  root /usr/share/caddy
  #templates *.gohtml
  templates {
    mime_types application/octet-stream
  encode zstd gzip
  @gohtmlgohtml path *.gohtml
  header @gohtml Content-Type text/html
  #rewrite /articles/* /article.gohtml
  rewrite /index.gohtml
  route {
    header *.gohtml Content-Type text/html
    templates
# i’ve tried a lot of variants here
I see the content-type matching is… basic
ct := header.Get(“Content-Type”)
  for _, mt := range t.MIMETypes {
    if strings.Contains(ct, mt) {
      return true
so there’s no chance of matching “text/*” or even text/plain; charset="UTF=8"
which goat do i need to sacrifice to convince Caddy to process my files as templates
:goat: :dagger: :drop_of_blood: :pleading_face:
Here is a quick example you can adjust as needed:
test.gohtml
<!DOCTYPE html>
<html>
<body>
<pre>
Method         : {{ .Req.Method }}
URI            : {{ .Req.RequestURI }}
Protocol       : {{ .Req.Proto }}
Remote Address : {{ .Req.RemoteAddr }}
Server         : {{ .Req.Host }}
Connection     : {{ if .Req.TLS }}HTTPS{{ else }}HTTP{{ end }}
Timestamp      : {{ now | date "2006-01-02 15:04:05 UTC" }}
</pre>
</body>
</html>
Caddyfile
example.com {
	tls internal
	root * /var/www/html
	@gohtml path *.gohtml
	templates @gohtml {
		mime text/html
Test result:
$ curl https://example.com/test.gohtml -I
HTTP/2 200
alt-svc: h3=":443"; ma=2592000
content-type: text/html
server: Caddy
vary: Accept-Encoding
content-length: 0
date: Fri, 06 Feb 2026 18:51:11 GMT
<!DOCTYPE html>
<html>
<body>
<pre>
Method         : GET
URI            : /test.gohtml
Protocol       : HTTP/2.0
Remote Address : 127.0.0.1:65461
Server         : example.com
Connection     : HTTPS
Timestamp      : 2026-02-06 10:51:23 UTC
</pre>
</body>
</html>
In other words, things happen in this order.
  1. header sets the Content-Type for *.gohtml
  2. The response from *.gohtml is now text/html
  3. The templates handler sees a matching MIME type
  4. templates executes
The mime directive inside templates is not really needed here, since text/html is already the default. I included it only to highlight that templates runs based on the MIME type when the response is about to be sent to the client.
In your configuration, you were limiting templates to only process application/octet-stream:
  templates {
If that is the MIME type you actually want to send, then you need to adjust your config:
	header @gohtml Content-Type application/octet-stream
	templates @gohtml {
		mime application/octet-stream
Test result:
HTTP/2 200
content-type: application/octet-stream
server: Caddy
content-length: 0
date: Fri, 06 Feb 2026 18:59:08 GMT
<!DOCTYPE html>
<html>
<body>
<pre>
Method         : GET
URI            : /test.gohtml
Protocol       : HTTP/2.0
Remote Address : 127.0.0.1:50024
Connection     : HTTPS
Timestamp      : 2026-02-06 10:59:09 UTC
</pre>
</body>
</html>
Keep in mind that application/octet-stream will cause most browsers to download the file instead of displaying it.
Sorry, I missed this one:
	header @gohtml Content-Type "text/plain; charset=\"UTF=8\""
	templates @gohtml {
		mime text/html text/plain
Again, mime text/html text/plain is not needed here, because that’s the default value.
Test result:
HTTP/2 200
content-type: text/plain; charset="UTF=8"
server: Caddy
content-length: 0
date: Fri, 06 Feb 2026 19:19:36 GMT
<!DOCTYPE html>
<html>
<body>
<pre>
Method         : GET
URI            : /test.gohtml
Protocol       : HTTP/2.0
Remote Address : 127.0.0.1:53198
Connection     : HTTPS
Timestamp      : 2026-02-06 11:19:46 UTC
</pre>
</body>
</html>
There actually is :slight_smile: The important part here is Contains:
This effectively reads as “if the Content Type string contains the MIME string”. Because of that, something like text/* can easily be achieved by matching mime on text/.
For example:
	header @gohtml Content-Type "text/foo; charset=\"UTF=8\""
	templates @gohtml {
		mime text/
Test result:
HTTP/2 200
content-type: text/foo; charset="UTF=8"
server: Caddy
content-length: 0
date: Fri, 06 Feb 2026 20:34:11 GMT
<!DOCTYPE html>
<html>
<body>
<pre>
Method         : GET
URI            : /test.gohtml
Protocol       : HTTP/2.0
Remote Address : 127.0.0.1:65375
Connection     : HTTPS
Timestamp      : 2026-02-06 12:34:25 UTC
</pre>
</body>
</html>
