Rewrite subdomain to subdirectory of another docker container via reverse proxy
(Docker image: caddy/latest)
I run Caddy as one of the containers via docker-compose. It serves as the reverse proxy for my PHP-apache container.
  • macOS v10.15.5
  • Docker Engine 20.10.2
N/A
version: "3.9"
# User Defined Network
  static-host:
    driver: bridge
    ipam:
      driver: default
      config:
        - subnet: 172.10.0.0/24
# Service Containers
  # Caddy2
    hostname: caddy
    image: caddy:latest
      static-host:
        ipv4_address: 172.10.0.10
      - $PWD/data/caddy/data:/data
      - $PWD/data/caddy/config:/config
      - $PWD/data/caddy/Caddyfile:/etc/caddy/Caddyfile:ro
  # Web Server (Apache2 + PHP)
  php-apache:
    hostname: php-apache
    build:
      context: $PWD/build/php-apache
      static-host:
        ipv4_address: 172.10.0.11
      - "8080:80"
      - $PWD/data/php-apache/www:/var/www
(mkcert) {
	tls /data/certs/wildcard.localhost.pem /data/certs/wildcard.localhost-key.pem
# PHP-Apache
www.localhost {
	import mkcert
	reverse_proxy php-apache:80
portfolio.www.localhost {
	import mkcert
	rewrite / /portfolio_web/{uri}
	reverse_proxy php-apache:80 {
		header_up Host portfolio.www.localhost
		header_up X-Forwarded-Proto https
  • I would like to serve the website https://portfolio.www.localhost/* under the root of /var/www/html/portfolio_web/ of PHP-apache container via reverse proxy, without the subdirectory in URL.
  • The default root for PHP-apache container is /var/www/html for https://www.localhost/
N/A
I tried rewrite, redir and route directives but failed to achieve what I want.
The above attempts changed the URL from https://portfolio.www.localhost/* to https://www.localhost/portfolio_web/*.
N/A
Please upgrade to Caddy v2.3.0!
These lines shouldn’t be necessary, Caddy already does this by default:
I think you’re looking for this:
rewrite * /portfolio_web{uri}
Your existing matcher of / only matches exactly / (i.e. requests to the root) but nothing else. Path matching is exact in Caddy. Also, {uri} will always include the leading / so you would be doubling it up by adding it before the placerholder.
Have you considered cutting out apache altogether? Caddy can serve PHP sites fastcgi (php-fpm), with the php_fastcgi directive.
Hi Francis, thank you for your prompt response!
Seems it causes an infinite redirect loop, e.g.
https://portfolio.www.localhost/assets/lib.min.js is redirect to https://portfolio.www.localhost/portfolio_web/assets/lib.min.js >> https://portfolio.www.localhost/portfolio_web/portfolio_web/assets/lib.min.js (keeps appending portfolio_web/ to the subdirectory in URL). Did I miss anything?
I will definitely consider this in future projects. Due to legacy production environment, I stick to apache for this website.
Apache must be triggering the redirects, there’s nothing in Caddy that would cause this to happen.
