Rewrite Rules from Apache to Caddy
I need help converting a site i have on apache to caddy. how would i write these directives in my Caddyfile?
RewriteCond %{REQUEST_URI} !^/index.php$
RewriteCond %{REQUEST_URI} "!^/resource/"
RewriteRule ^(.*)$ /index.php?url=$1 [NC,L]
Please fill out the help topic template, as per the forum rules.
1. Output of caddy version:
v2.5.1 h1:bAWwslD1jNeCzDa+jDCNwb8M3UJ2tPa8UZFFzPVmGKs=
Ubuntu Server 22.04, caddy from default apt repo
systemctl start caddy
Type=notify
beta.evertek.com {
	root * /var/www/Evertek
	php_fastcgi * unix//run/php/php7.4-fpm.sock
        rewrite {
            to {path} /index.php?url={path}
no error messages, just redirecting still in /resource
Ive tried using rewrite already in my config file, but i dont know the relevant config options to not rewrite if the url is in the /resource/ folder
That’s not valid, that’s Caddy v1 syntax and isn’t supported in v2.
The way to do this in v2 is to adjust the try_files subdirective of php_fastcgi. See the docs for the directive, and read the explanation of the expanded form to understand how it works.
I don’t think the /resources condition matters though, unless you also have PHP files in that directory. Requests to files that do exist on disk will not be rewritten because of the {path} part.
FWIW, I recommend changing your PHP app to not use the query to read the original URI, but instead read from the REQUEST_URI server variable. That’s the standard/modern way of doing it. Rewriting to add something to the query is janky and not recommended.
