chartjes
(Chris Hartjes)
May 4, 2018, 4:05pm
1
I am trying to create a Caddyfile for OpenCFP, a open source PHP project that I am the main developer for. I have been unable to figure out what the rewrite rule should look like. Here is what I have so far (for local dev right now)
localhost:8080
root /Users/chartjes/Sites/opencfp/web
fastcgi / /Users/chartjes/.valet/valet.sock php
rewrite to {path} {path}/ /index.php/{path}
log access.log
errors error.log
The front page of the application loads just fine, but if I try to go to any other URL’s I am getting a 404
ie /ideas
If I use the URL
/index.php/ideas
it works just fine.
The directions for the project have a sample nginx configuration file over at GitHub - opencfp/opencfp: Repo for OpenCFP project, a PHP-based conference talk submission system
Thanks in advance for any help with what the rewrite rule should look like
abiosoft
(Abiola Ibrahim)
May 4, 2018, 6:36pm
2
I can’t seem to find the nginx config file in the repo, you may want to link to it.
But I have fixed the obvious error from the config you shared which is with rewrite.
localhost:8080
rewrite / {path} {path}/ /index.php/{path}
log access.log
errors error.log
Note: The rewrite syntax was introduced in 0.10.14
, I assume you are on the latest version.
chartjes
(Chris Hartjes)
May 4, 2018, 6:58pm
3
Hi abiosoft.
After updating to the latest version of caddy (I was on 0.10.11) your suggested changes work. Thank you so much for the help!
abiosoft
(Abiola Ibrahim)
May 4, 2018, 8:55pm
4
I know this is not the use case for many but it is good to see a fully functional setup with (php) fastcgi, rewrite and logs without any braces and just 6 lines of config.
@abiosoft is the one-line rewrite
form still an exact-match from ?
The docs still specify it’s exact, in which case the braced form would be needed to catch-all, right? e.g.
rewrite {
abiosoft
(Abiola Ibrahim)
May 5, 2018, 6:25am
6
The one-liner is not exact match anymore, it is now a regex match. Yeah, the doc needs to be updated.
system
(system)
Closed
August 3, 2018, 6:25am
7
