I often use gnuboard which is used a lot in Korea.
It is a situation where rewrite is required to make a long address short.
Here are the rewrite rules for apache and for nginx.
#### gnuboard5 apache rewrite BEGIN #####
<IfModule mod_rewrite.c>
RewriteEngine On
RewriteBase /
RewriteCond %{REQUEST_FILENAME} -f [OR]
RewriteCond %{REQUEST_FILENAME} -d
RewriteRule ^ - [L]
RewriteRule ^content/([0-9a-zA-Z_]+)$ bbs/content.php?co_id=$1&rewrite=1 [QSA,L]
RewriteRule ^content/([^/]+)/$ bbs/content.php?co_seo_title=$1&rewrite=1 [QSA,L]
RewriteRule ^rss/([0-9a-zA-Z_]+)$ bbs/rss.php?bo_table=$1 [QSA,L]
RewriteRule ^([0-9a-zA-Z_]+)$ bbs/board.php?bo_table=$1&rewrite=1 [QSA,L]
RewriteRule ^([0-9a-zA-Z_]+)/([^/]+)/$ bbs/board.php?bo_table=$1&wr_seo_title=$2&rewrite=1 [QSA,L]
RewriteRule ^([0-9a-zA-Z_]+)/write$ bbs/write.php?bo_table=$1&rewrite=1 [QSA,L]
RewriteRule ^([0-9a-zA-Z_]+)/([0-9]+)$ bbs/board.php?bo_table=$1&wr_id=$2&rewrite=1 [QSA,L]
</IfModule>
#### gnuboard5 rewrite END #####
#### gnuboard5 nginx rules BEGIN #####
if (!-e $request_filename){
rewrite ^/content/([0-9a-zA-Z_]+)$ /bbs/content.php?co_id=$1&rewrite=1 break;
rewrite ^/content/([^/]+)/$ /bbs/content.php?co_seo_title=$1&rewrite=1 break;
rewrite ^/rss/([0-9a-zA-Z_]+)$ /bbs/rss.php?bo_table=$1 break;
rewrite ^/([0-9a-zA-Z_]+)$ /bbs/board.php?bo_table=$1&rewrite=1 break;
rewrite ^/([0-9a-zA-Z_]+)/write$ /bbs/write.php?bo_table=$1&rewrite=1 break;
rewrite ^/([0-9a-zA-Z_]+)/([^/]+)/$ /bbs/board.php?bo_table=$1&wr_seo_title=$2&rewrite=1 break;
rewrite ^/([0-9a-zA-Z_]+)/([0-9]+)$ /bbs/board.php?bo_table=$1&wr_id=$2&rewrite=1 break;
#### gnuboard5 nginx rules END #####
Caddy 2 for gnuboard rewrite rule
@content path_regexp content ^/content/([0-9a-zA-Z_]+)$
rewrite @content /bbs/content.php?co_id={re.content.1}&rewrite=1
@title path_regexp title ^/content/([^/]+)/$
rewrite @title /bbs/content.php?co_seo_title={re.title.1}&rewrite=1
@rss path_regexp rss ^rss/([0-9a-zA-Z_]+)$
rewrite @rss /bbs/rss.php?bo_table={re.rss.1}
@board path_regexp board ^/([0-9a-zA-Z_]+)$
rewrite @board /bbs/board.php?bo_table={re.board.1}&rewrite=1
@write path_regexp write ^/([0-9a-zA-Z_]+)/write$
rewrite @write /bbs/write.php?bo_table={re.write.1}&{query}
@seo path_regexp seo ^/([0-9a-zA-Z_]+)/([^/]+)/$
rewrite @seo /bbs/board.php?bo_table={re.seo.1}&wr_seo_title={re.seo.2}&rewrite=1
@id path_regexp id ^/([0-9a-zA-Z_]+)/([0-9]+)$
rewrite @id /bbs/board.php?bo_table={re.id.1}&wr_id={re.id.2}&rewrite=1
matt
(Matt Holt)
July 9, 2020, 4:54pm
2
Hi, thanks for letting us know your use for Caddy!
What have you tried so far?
If you’re using the Caddyfile, the rewrite directive docs are here: rewrite (Caddyfile directive) — Caddy Documentation
For the conditions, you can use matchers: Request matchers (Caddyfile) — Caddy Documentation
I read all the links you gave me. But since I am a beginner in the web, it is almost impossible to fully understand. So I haven’t even figured out how to start. If you give me some examples, I’ll try to fix it.
This is the general idea:
@content path_regexp content ^content/([0-9a-zA-Z_]+)$
So you have a named matcher @content which defines a regular expression on the request path, and using content as the name for the regexp so the result can be used later.
Then we have a rewrite that only applies if the @content matcher matches which rewrites the path using the regexp result with a placeholder {re.content.1} where content is the regexp name from before, and 1 is the index of the match group in the regexp (the stuff wrapped in () parentheses).
I think you should be able to figure out the rest. Feel free to follow up with more specific questions!
One note I realized - Caddy has its paths typically prefixed with / so the ^ in the regexp not being followed by / will probably cause it not to match. Just something you may need to experiment with.
I changed it!
# gnuboard rewrite rules
rewrite @write /bbs/write.php?bo_table={re.write.1}&rewrite=1
Is it alright?
matt
(Matt Holt)
July 9, 2020, 6:04pm
9
Awesome, glad you figured it out. If your config works for other gnuboard users too, then consider posting a guide in our wiki!
Unfortunately the first line doesn’t seem to work.
I’m looking at the log, but it’s harder because I don’t see any bugs.
Caddy is rewriting to the exact short address, but it is not linked to the content.
I think it’s cause of this:
Add a / between ^ and content, I think.
Last question.
This is a url to edit posts that have already been made.
How can I rewrite url
from
https://example.com/free/write?w=u&wr_id=28&page=
to
https://example.com/bbs/write.php?w=u&bo_table=free&wr_id=28&page=
As you can see this code does not work.
Now I’ve entered the final chapter of gnuboard, but it’s too hard.
Plz help me.
It’s done.
Final Code
These are perfect codes for gnuboard 5.4.
WoosungChoi:
{http.request.uri.query}
You can actually use {query} which is the Caddyfile shortcut for that placeholder:
Great detective work! Happy to see you figured it all out
Thank you for your information. I will change it.
rewrite @content /bbs/content.php?co_id={re.content.1}&{query}
rewrite @title /bbs/content.php?co_seo_title={re.title.1}&{query}
rewrite @board /bbs/board.php?bo_table={re.board.1}&{query}
rewrite @seo /bbs/board.php?bo_table={re.seo.1}&wr_seo_title={re.seo.2}&{query}
rewrite @id /bbs/board.php?bo_table={re.id.1}&wr_id={re.id.2}&{query}
change from rewrite=1 to {query}
