Rewrite / Proxy
Hi Everyone,
Thanks for the really cool project, and it is really nice that JSON is now the main language for Caddy configuration.
I have been trying to setup a simple file_server with some basic proxy rules and I am currently stuck in the following proxy rule that I cannot map to the JSON configuration
The following webpack rule
	proxy: {
          '/api/*': {
	    target: 'http://0.0.0.0:9999/loadBalancer/',
	      	pathRewrite: { '^/api': '' }
Note that the target is a different machine. From what I read on some posts is that we cannot
proxy to a http://0.0.0.0/PATH ?
My current configuration is
  "admin": {
    "disabled": false,
    "listen": "0.0.0.0:9066"
  "apps": {
    "http": {
      "http_port": 9065,
      "servers": {
        "srp16154lx": {
          "listen": [
            "0.0.0.0:9065"
          "routes": [
              "handle": [
                  "handler": "file_server",
                  "root": "./test_root",
                  "hide": [
                    "config"
I have been looking at JSON Config Structure - Caddy Documentation
but without an example it is a bit tricky
Thanks in advance,
Lucas
The easiest thing to get started is to start from Caddyfile config and use the caddy adapt command to get the underlying JSON config if you need it.
I think what you need is this:
:9065 {
	handle_path /api* {
		rewrite * /loadBalancer{uri}
		reverse_proxy localhost:9999
Which gets you this JSON:
  "apps": {
    "http": {
      "servers": {
        "srv0": {
          "listen": [
            ":9065"
          "routes": [
              "match": [
                  "path": [
                    "/api*"
              "handle": [
                  "handler": "subroute",
                  "routes": [
                      "handle": [
                          "handler": "rewrite",
                          "strip_path_prefix": "/api"
                      "group": "group0",
                      "handle": [
                          "uri": "/loadBalancer{http.request.uri}"
                      "handle": [
                          "handler": "reverse_proxy",
                          "upstreams": [
                              "dial": "localhost:9999"
Thanks that worked.
