1. Output of caddy version:
I run Caddy on Azure for two sites, and a subdomain. Klabo.blog, lnbits.klabo.blog, and satoshis.lol. They are all reverse proxied to services for each site.
Ubuntu 18.04
sudo run caddy
(logging) {
output file /home/azureuser/logs/caddy.log
lnbits.klabo.blog {
import logging
reverse_proxy 0.0.0.0:8000
spark.klabo.blog {
import logging
reverse_proxy http://0.0.0.0:9737
klabo.blog {
import logging
root * /home/azureuser/klabo-blog/_site/
satoshis.lol {
import logging
route /.well-known/nostr.json {
rewrite * /nostrnip5/api/v1/domain/GjxYKGTjwDVawdPBLSLPsr/nostr.json
reverse_proxy https://lnbits.klabo.blog
reverse_proxy 0.0.0.0:17422
I am attempting to handle GET requests to satoshis.lol/.well-known/nostr.json and proxy them to lnbits.klabo.blog with the path /nostrnip5/api/v1/domain/GjxYKGTjwDVawdPBLSLPsr/nostr.json.
When I try this I get a 404 from the satoshis.lol service. redirect doesn’t work here b/c I need the request to appear to be getting returned from satoshis.lol with HTTPS etc.
I’m not an expert at in this type of configuration so forgive me if I’m not explaining well. This is the nginx example I’m attempting to replicate:
## Proxy Server Caching
proxy_cache_path /tmp/nginx_cache keys_zone=nip5_cache:5m levels=1:2 inactive=300s max_size=100m use_temp_path=off;
location /.well-known/nostr.json {
proxy_pass https://{your_lnbits}/nostrnip5/api/v1/domain/{domain_id}/nostr.json;
proxy_set_header Host {your_lnbits};
proxy_ssl_server_name on;
expires 5m;
add_header Cache-Control "public, no-transform";
proxy_cache nip5_cache;
proxy_cache_lock on;
proxy_cache_valid 200 300s;
proxy_cache_use_stale error timeout invalid_header updating http_500 http_502 http_503 http_504;
2023/01/08 17:56:40.181 error http.log.access.log3 handled request {"request": {"remote_ip": "73.170.190.23", "remote_port": "54732", "proto": "HTTP/2.0", "method": "GET", "host": "satoshis.lol", "uri": "/.well-known/nostr.json", "headers": {"Accept": ["text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8"], "Accept-Language": ["en-US,en;q=0.9"], "Accept-Encoding": ["gzip, deflate, br"], "User-Agent": ["Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/16.1 Safari/605.1.15"]}, "tls": {"resumed": false, "version": 772, "cipher_suite": 4865, "proto": "h2", "server_name": "satoshis.lol"}}, "user_id": "", "duration": 0.251674802, "size": 19, "status": 404, "resp_headers": {"Content-Type": ["text/plain; charset=utf-8"], "Date": ["Sun, 08 Jan 2023 17:56:40 GMT"], "Server": ["Caddy", "Caddy"], "Alt-Svc": ["h3=\":443\"; ma=2592000"], "Vary": ["Origin"], "X-Content-Type-Options": ["nosniff"], "Content-Length": ["19"]}}
I tried redirect, and also handle instead of route
Link to the guide explaining how to set up with nginx here: https://github.com/lnbits/lnbits/tree/main/lnbits/extensions/nostrnip5#installation
