Rewrite index.langhere.html
i have index.en.html and index.fr.html
in /
and in /foo/
and in /foo/baz/
want to serve correct file based on users language specified by browser, when they visit / or foo/ or foo/baz/
i read Content Negotiation - #2 by Whitestrake and did not understand how to achieve what i wanted
for now i have config posted in previous topic, it has no rewrite
hope you can assist with a working example
thank you very much
Howdy @gryL24!
I should point out that that thread concerns Caddy v1 and none of the configuration in that thread will be applicable to Caddy v2.
Could you do us a favour and post your current config here in this thread as well, just so it’s all in one place for us to have a look at and provide advice?
Generally, you’ll want to write a named matcher (see: https://caddyserver.com/docs/caddyfile/matchers#named-matchers) that matches a Header value (Accept-Language) and a set of paths (/, /foo/, and /foo/baz/). When you get a de in the Accept-Language you can rewrite (rewrite (Caddyfile directive) — Caddy Documentation) to your language-specific index file. (Or maybe you want de to be the default and rewrite to en when found.)
