Rewrite file not found & migrate problems
v2.4.3
Ubuntu
Once I’ve done
caddy start
And now I use this for update config
caddy adapt --config /etc/caddy/Caddyfile > caddy.json
curl localhost:2019/load -X POST -H "Content-Type: application/json" -d @caddy.json
domain.com {
    root * /var/www/domain.com/public
    php_fastcgi unix//run/php/php7.0-fpm.sock
    @webhook path_regexp ^/webhook/([0-9a-zA-Z_]+)$
    rewrite @webhook /folder/{re.webhook.1}/script.php?{path}
Navigate to domain.com/webhook/SomePoint returns 404 and “File not found.”
Expected open like domain.com/folder/SomePoint/script.php
I don’t know how to enable debug logs
I set
        level DEBUG
        output file /data/log/caddy_test.log {
           roll_size 10MiB
           roll_keep 10
           roll_keep_for 336h
but i don’t see debug logs about this error.
All I want to do, migrate
rewrite /webhook {
 	r  ^/(\w+)/?$
 	to /folder/{1}/script.php?{query}
to new version
Thanks for any help
I’ll figured out
@webhook {
path_regexp webhook ^/webhook/([0-9a-zA-Z_]+)$
Add this at the top of your Caddyfile:
I think you probably wanted {query} rather than {path} as per your v1 example.
You can shorten this slightly by making it a one liner:
@webhook path_regexp webhook ^/webhook/([0-9a-zA-Z_]+)$
Glad you figured it out!
