): v2.3.0
Via docker on Google’s Container Optimized OS, caddy:2-alpine image.
I don’t have the original docker run command I used but it was something like
docker run --name=caddy --volume=/var/data/caddy/Caddyfile:/etc/caddy/Caddyfile -p 443:443 -p 80:80 caddy:2-alpine
none
email xxxxxxxx
db.xxxxxxxx {
@adminlogin {
path /admin/login/*
query password=*
handle @adminlogin {
request_header +Authorization "Basic XXXXXXXX"
rewrite * /admins/_design/admin/_update/login/{path}
reverse_proxy couchdb:5984
Hello there.
I’m trying to expose a couple of endpoints from a CouchDB database that requires Basic HTTP authentication. This works perfectly for every endpoint that doesn’t have any parameters appended to the URL.
For this specific case, I need for the URL https://db.xxxxxxxx/admin/login/some_id
that includes a query param password
to be rewrited to https://db.xxxxxxxx/admins/_design/admin/_update/login/some_id
, keeping the query parameters and adding the basic authentication header with the token hardcoded.
I think the only thing is not working is appending the some_id
param to the rewrite destination.
Thank you so much!
No errors.
