Rewrite a url based on folder path
Hi, I am trying to convert the following nginx code
 location / {
      auth_basic "Restricted Content";
      auth_basic_user_file /var/www/.htpasswd;
      if (!-e $request_filename){
          rewrite ^(/)?customer/.*$ /customer/index.php;
          rewrite ^(/)?backend/.*$ /backend/index.php;
          rewrite ^(.*)$ /index.php;
      index  index.html index.htm index.php;
      # try_files $uri $uri/ /index.php$is_args$args;
to a caddy equivalent.
Here is the .htaccess code for it
#php_value default_charset UTF-8
#AddDefaultCharset UTF-8
#make sure nothing can be seen inside!
deny from all
RewriteEngine On
RewriteCond %{REQUEST_FILENAME} !-f
RewriteCond %{REQUEST_FILENAME} !-d
RewriteRule ^(.*)$ /index.php?/$1 [L]
I tried doing
    root /var/www
    fastcgi / php-fpm:9000 php {
        index index.php
    # To handle .html extensions with laravel change ext to
    # ext / .html
    gzip
    browse
    log /var/log/caddy/access.log
    errors /var/log/caddy/error.log
    # Uncomment to enable TLS (HTTPS)
    # Change the first list to listen on port 443 when enabling TLS
    tls mymail@gmail.com
    # To use Lets encrpt tls with a DNS provider uncomment these
    # lines and change the provider as required
    #tls {
    #  dns cloudflare
But It brought up a lot of errors for them.
The nginx code looks awfully difficult to parse, but the htaccess seems much simpler. It looks like it’s simply running through these checks:
  1. Is it a file? Serve the request normally. Else…
  2. Is it a directory? Serve the request normally. Else…
  3. Serve the root index (and append the URI as a query).
Something like this would be equivalent:
rewrite {
  to {path} {path}/ /?{uri}
Hi, I have tried the following so far
    root /var/www
        index index.php
    # ext / .html
    rewrite {
        regexp ^/(.*)$
        to {path} {path} /index.php?q={1}
    rewrite {
        regexp ^/(.*)?cliente/.*$
        to {path} {path} /customer/index.php?q={1}
    rewrite {
        regexp ^/(.*)?backend/.*$
        to {path} {path} /backend/index.php?q={1}
but i get a 400 error since its not able to find the /backend and the /cliente routes. I have also also tried using the same config with
rewrite /routename {
But no luck so far.
It might be because you’re rewriting to {path} {path} instead of to {path} {path}/ in each rewrite? That could cause it to miss certain directory requests. Might also be because of regex misses.
The static file server will issue canonical index redirects if it ever gets a chance to serve an index file. The best way to refer to a directory index is using the directory itself, not the index file.
Also, you can ditch the regex, they’re slow. Placeholders are much faster.
rewrite {
  to {path} {path}/ /?q={uri}
rewrite /cliente {
  to {path} {path}/ /cliente/?q={uri}
rewrite /backend {
  to {path} {path}/ /backend/?q={uri}
