reverseproxy.statusError (reverseproxy.go:1269)
encountered an error today, works fine before
2024-10-04 15:42:56 {"level":"error","ts":1728027776.6026268,"logger":"http.log.error","msg":"EOF","request":{"remote_ip":"192.168.xx.1","remote_port":"55796","client_ip":"192.168.xx.1","proto":"HTTP/1.1","method":"POST","host":"xxx.75.xx.116:9080","uri":"/moment/getMomentList","headers":{"Content-Length":["4"],"Authorizationtoken":["eyJhbGciOiJIUzI1IlVzZXJJZCI6MTYzNzcyMzY2MTU3MTk4NTQwOCwiVXNlcm5hbWUiOiIiLCJQbGF0Zm9ybSI6Mn0sImlzcyI6ImNydXZpZSIsImV4cCI6MTczMTcwNjM5MCwibmJmIjoxNzI2NTIyMzkwLCJpYXQiOjE3MjY1MjIzOTB9.yTQN_lMPUS8h3PcJDoOC3kgPpPJ64-ObqrSgYHB_r6Q"],"User-Agent":["Dart/3.5 (dart:io)"],"Content-Type":["application/protobuf"],"Accept-Encoding":["gzip"]}},"duration":0.009962583,"status":502,"err_id":"37822zh1t","err_trace":"reverseproxy.statusError (reverseproxy.go:1269)"}
docker-compose
macos 15
Docker Engine v27.2.0
  ss-caddy:
    image: caddy:latest
    container_name: ss-caddy
      - "9080:9080"
      - ./caddy/caddy_data:/data
      - ./caddy/caddy_config:/config
:9080 {
	reverse_proxy /xx/* host.docker.internal:8757
    reverse_proxy /mxxx/* host.docker.internal:8758
    reverse_proxy /daxx/* host.docker.internal:8759
    reverse_proxy /tool/* host.docker.internal:8755
    reverse_proxy /uxxx/* host.docker.internal:8756
    reverse_proxy /msxxx/* host.docker.internal:8754
An EOF error essentially means that either the request body no longer had anything left to read when Caddy was expecting to have something to read, or the response body didn’t have anything to read.
That doesn’t really give us much to go on here. It could be because your upstream app, or the client, was misbehaving.
