Not sure why I didnt add logs but here : ● caddy.service - Caddy
Loaded: loaded (/usr/lib/systemd/system/caddy.service; enabled; preset: enabled)
Active: active (running) since Tue 2024-09-24 19:05:52 CEST; 26s ago
Docs: Welcome — Caddy Documentation
Main PID: 4235 (caddy)
Tasks: 12 (limit: 76964)
Memory: 12.0M (peak: 12.9M)
CPU: 66ms
└─4235 /usr/bin/caddy run --environ --config /etc/caddy/Caddyfile
Sep 24 19:05:52 frhb81859ds caddy[4235]: {“level”:“info”,“ts”:1727197552.1765106,“logger”:“tls”,“msg”:“storage cleaning happened too recently; skipping for now”,“storage”:“FileStorage:/var/lib/caddy/.local/share/caddy”,“instance”:"0206e>
Sep 24 19:05:52 frhb81859ds caddy[4235]: {“level”:“info”,“ts”:1727197552.1765602,“logger”:“tls”,“msg”:“finished cleaning storage units”}
Sep 24 19:06:03 frhb81859ds caddy[4235]: {“level”:“error”,“ts”:1727197563.9911563,“logger”:“http.log.error”,“msg”:“dial tcp 127.0.0.1:4020: connect: connection refused”,“request”:{“remote_ip”:“2607:fea8:a5a:6580:2591:c625:8ca0:e85c”,"re>
Sep 24 19:06:05 frhb81859ds caddy[4235]: {“level”:“error”,“ts”:1727197565.2605994,“logger”:“http.log.error”,“msg”:“dial tcp 127.0.0.1:4020: connect: connection refused”,“request”:{“remote_ip”:“46.255.204.193”,“remote_port”:“32826”,"clie>
Sep 24 19:06:05 frhb81859ds caddy[4235]: {“level”:“error”,“ts”:1727197565.6114075,“logger”:“http.log.error”,“msg”:“dial tcp 127.0.0.1:4020: connect: connection refused”,“request”:{“remote_ip”:“46.255.204.193”,“remote_port”:“32826”,"clie>
Sep 24 19:06:05 frhb81859ds caddy[4235]: {“level”:“error”,“ts”:1727197565.6167316,“logger”:“http.log.error”,“msg”:“dial tcp 127.0.0.1:4020: connect: connection refused”,“request”:{“remote_ip”:“46.255.204.193”,“remote_port”:“32826”,"clie>
Sep 24 19:06:05 frhb81859ds caddy[4235]: {“level”:“error”,“ts”:1727197565.920443,“logger”:“http.log.error”,“msg”:“dial tcp 127.0.0.1:4020: connect: connection refused”,“request”:{“remote_ip”:“2607:fea8:a5a:6580:2591:c625:8ca0:e85c”,"rem>
Sep 24 19:06:06 frhb81859ds caddy[4235]: {“level”:“error”,“ts”:1727197566.6181529,“logger”:“http.log.error”,“msg”:“dial tcp 127.0.0.1:4020: connect: connection refused”,“request”:{“remote_ip”:“2607:fea8:a5a:6580:2591:c625:8ca0:e85c”,"re>
Sep 24 19:06:07 frhb81859ds caddy[4235]: {“level”:“error”,“ts”:1727197567.0722024,“logger”:“http.log.error”,“msg”:“dial tcp 127.0.0.1:4020: connect: connection refused”,“request”:{“remote_ip”:“2607:fea8:a5a:6580:2591:c625:8ca0:e85c”,"re>
Sep 24 19:06:12 frhb81859ds caddy[4235]: {“level”:“error”,“ts”:1727197572.5774076,“logger”:“http.log.error”,“msg”:“dial tcp 127.0.0.1:4020: connect: connection refused”,“request”:{“remote_ip”:“51.195.47.67”,“remote_port”:“52118”,"clien
