Reverse proxy works on domain, but not subdomain
I have a reverse proxy set up on my domain (elsebody.com), which points to an internal IP address (192.168.8.100) – and it works perfectly.
However, when I try to do the same with a subdomain (o.elsebody.com), the dns challenge fails with a tls.obtain bad request (400).
The API key from Ionos is associated with my customer account, not a specific domain, so should work on subdomains too.
DNS checker shows the A records for both parent and subdomain have propagated, and point to the same IP address.
Any thoughts on how to get reverse proxy working with my subdomain?
PS D:\Dropbox\JimBin\Caddy> caddy run --watch
2025/08/16 03:58:09.724 ←[34mINFO←[0m   maxprocs: Leaving GOMAXPROCS=8: CPU quota undefined
2025/08/16 03:58:09.725 ←[34mINFO←[0m   GOMEMLIMIT is updated   {"package": "github.com/KimMachineGun/automemlimit/memlimit", "GOMEMLIMIT": 15071322931, "previous": 9223372036854775807}
2025/08/16 03:58:09.725 ←[34mINFO←[0m   using adjacent Caddyfile
2025/08/16 03:58:09.726 ←[34mINFO←[0m   adapted config to JSON  {"adapter": "caddyfile"}
2025/08/16 03:58:09.727 ←[33mWARN←[0m   Caddyfile input is not formatted; run 'caddy fmt --overwrite' to fix inconsistencies    {"adapter": "caddyfile", "file": "Caddyfile", "line": 14}
2025/08/16 03:58:09.736 ←[34mINFO←[0m   admin   admin endpoint started  {"address": "localhost:2019", "enforce_origin": false, "origins": ["//localhost:2019", "//[::1]:2019", "//127.0.0.1:2019"]}
2025/08/16 03:58:09.736 ←[34mINFO←[0m   tls.cache.maintenance   started background certificate maintenance      {"cache": "0xc00051f700"}
2025/08/16 03:58:09.736 ←[34mINFO←[0m   http.auto_https server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS {"server_name": "srv0", "https_port": 443}
2025/08/16 03:58:09.736 ←[34mINFO←[0m   http.auto_https enabling automatic HTTP->HTTPS redirects        {"server_name": "srv0"}
2025/08/16 03:58:09.736 ←[35mDEBUG←[0m  http.auto_https adjusted config {"tls": {"automation":{"policies":[{"subjects":["o.elsebody.com"]},{}]}}, "http": {"servers":{"remaining_auto_https_redirects":{"listen":[":80"],"routes":[{},{}]},"srv0":{"listen":[":443"],"routes":[{"handle":[{"handler":"subroute","routes":[{"handle":[{"handler":"reverse_proxy","transport":{"protocol":"http","tls":{"insecure_skip_verify":true}},"upstreams":[{"dial":"192.168.8.211:443"}]}]}]}],"terminal":true}],"tls_connection_policies":[{}],"automatic_https":{}}}}}
2025/08/16 03:58:09.737 ←[35mDEBUG←[0m  http    starting server loop    {"address": "[::]:443", "tls": true, "http3": false}
2025/08/16 03:58:09.737 ←[34mINFO←[0m   http    enabling HTTP/3 listener        {"addr": ":443"}
2025/08/16 03:58:09.737 ←[34mINFO←[0m   http.log        server running  {"name": "srv0", "protocols": ["h1", "h2", "h3"]}
2025/08/16 03:58:09.737 ←[35mDEBUG←[0m  http    starting server loop    {"address": "[::]:80", "tls": false, "http3": false}
2025/08/16 03:58:09.737 ←[33mWARN←[0m   http    HTTP/2 skipped because it requires TLS  {"network": "tcp", "addr": ":80"}
2025/08/16 03:58:09.737 ←[33mWARN←[0m   http    HTTP/3 skipped because it requires TLS  {"network": "tcp", "addr": ":80"}
2025/08/16 03:58:09.737 ←[34mINFO←[0m   http.log        server running  {"name": "remaining_auto_https_redirects", "protocols": ["h1", "h2", "h3"]}
2025/08/16 03:58:09.738 ←[34mINFO←[0m   http    enabling automatic TLS certificate management   {"domains": ["o.elsebody.com"]}
2025/08/16 03:58:09.738 ←[35mDEBUG←[0m  events  event   {"name": "started", "id": "6d10e7bc-8d2d-465e-bc94-9915703829d6", "origin": "", "data": null}
2025/08/16 03:58:09.739 ←[34mINFO←[0m   autosaved config (load with --resume flag)      {"file": "C:\\Users\\Jim\\AppData\\Roaming\\Caddy\\autosave.json"}
2025/08/16 03:58:09.739 ←[34mINFO←[0m   serving initial configuration
2025/08/16 03:58:09.739 ←[34mINFO←[0m   watcher watching config file for changes        {"config_file": "Caddyfile"}
2025/08/16 03:58:09.740 ←[34mINFO←[0m   tls     storage cleaning happened too recently; skipping for now        {"storage": "FileStorage:C:\\Users\\Jim\\AppData\\Roaming\\Caddy", "instance": "b84f29cf-3e27-4800-8496-286b891c4f37", "try_again": "2025/08/17 03:58:09.740", "try_again_in": 86400}
2025/08/16 03:58:09.740 ←[34mINFO←[0m   tls     finished cleaning storage units
2025/08/16 03:58:09.750 ←[34mINFO←[0m   tls.obtain      acquiring lock  {"identifier": "o.elsebody.com"}
2025/08/16 03:58:09.752 ←[34mINFO←[0m   tls.obtain      lock acquired   {"identifier": "o.elsebody.com"}
2025/08/16 03:58:09.752 ←[34mINFO←[0m   tls.obtain      obtaining certificate   {"identifier": "o.elsebody.com"}
2025/08/16 03:58:09.753 ←[35mDEBUG←[0m  events  event   {"name": "cert_obtaining", "id": "0a8cefef-0a00-41cb-b7bf-ffb92de45603", "origin": "tls", "data": {"identifier":"o.elsebody.com"}}
2025/08/16 03:58:09.753 ←[35mDEBUG←[0m  tls     created CSR     {"identifiers": ["o.elsebody.com"], "san_dns_names": ["o.elsebody.com"], "san_emails": [], "common_name": "", "extra_extensions": 0}
2025/08/16 03:58:09.754 ←[35mDEBUG←[0m  tls.obtain      trying issuer 1/1       {"issuer": "acme-v02.api.letsencrypt.org-directory"}
2025/08/16 03:58:09.754 ←[35mDEBUG←[0m  tls.issuance.acme       using existing ACME account because key found in storage associated with email  {"email": "default", "ca": "https://acme-v02.api.letsencrypt.org/directory"}
2025/08/16 03:58:09.754 ←[35mDEBUG←[0m  tls.issuance.acme       using existing ACME account because key found in storage associated with email  {"email": "", "ca": "https://acme-v02.api.letsencrypt.org/directory"}
2025/08/16 03:58:09.755 ←[34mINFO←[0m   tls.issuance.acme       waiting on internal rate limiter        {"identifiers": ["o.elsebody.com"], "ca": "https://acme-v02.api.letsencrypt.org/directory", "account": ""}
2025/08/16 03:58:09.755 ←[34mINFO←[0m   tls.issuance.acme       done waiting on internal rate limiter   {"identifiers": ["o.elsebody.com"], "ca": "https://acme-v02.api.letsencrypt.org/directory", "account": ""}
2025/08/16 03:58:09.755 ←[34mINFO←[0m   tls.issuance.acme       using ACME account      {"account_id": "https://acme-v02.api.letsencrypt.org/acme/acct/2594289706", "account_contact": []}
2025/08/16 03:58:10.604 ←[35mDEBUG←[0m  http request    {"method": "GET", "url": "https://acme-v02.api.letsencrypt.org/directory", "headers": {"User-Agent":["Caddy/2.10.0 CertMagic acmez (windows; amd64)"]}, "response_headers": {"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["995"],"Content-Type":["application/json"],"Date":["Sat, 16 Aug 2025 03:58:11 GMT"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]}, "status_code": 200}
2025/08/16 03:58:10.605 ←[35mDEBUG←[0m  creating order  {"account": "https://acme-v02.api.letsencrypt.org/acme/acct/2594289706", "identifiers": ["o.elsebody.com"]}
2025/08/16 03:58:11.106 ←[35mDEBUG←[0m  http request    {"method": "HEAD", "url": "https://acme-v02.api.letsencrypt.org/acme/new-nonce", "headers": {"User-Agent":["Caddy/2.10.0 CertMagic acmez (windows; amd64)"]}, "response_headers": {"Cache-Control":["public, max-age=0, no-cache"],"Date":["Sat, 16 Aug 2025 03:58:11 GMT"],"Link":["<https://acme-v02.api.letsencrypt.org/directory>;rel=\"index\""],"Replay-Nonce":["9_RDYWV0wZ1Mftqg_nsI9O78u5jlIQOQUvXII2xKv3Ttl1k3v0E"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]}, "status_code": 200}
2025/08/16 03:58:11.271 ←[35mDEBUG←[0m  http request    {"method": "POST", "url": "https://acme-v02.api.letsencrypt.org/acme/new-order", "headers": {"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.10.0 CertMagic acmez (windows; amd64)"]}, "response_headers": {"Boulder-Requester":["2594289706"],"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["348"],"Content-Type":["application/json"],"Date":["Sat, 16 Aug 2025 03:58:11 GMT"],"Link":["<https://acme-v02.api.letsencrypt.org/directory>;rel=\"index\""],"Location":["https://acme-v02.api.letsencrypt.org/acme/order/2594289706/418362240357"],"Replay-Nonce":["trI9TC2kWPGJIXZ37maBLuq3Hf8iOTkzQZVpETmFWJz9aqQMaUc"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]}, "status_code": 201}
2025/08/16 03:58:11.357 ←[35mDEBUG←[0m  http request    {"method": "POST", "url": "https://acme-v02.api.letsencrypt.org/acme/authz/2594289706/569588950837", "headers": {"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.10.0 CertMagic acmez (windows; amd64)"]}, "response_headers": {"Boulder-Requester":["2594289706"],"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["822"],"Content-Type":["application/json"],"Date":["Sat, 16 Aug 2025 03:58:11 GMT"],"Link":["<https://acme-v02.api.letsencrypt.org/directory>;rel=\"index\""],"Replay-Nonce":["9_RDYWV0wDmpV5IQ3792xVD6hOMpMz9Nx_2kvI8BZJo7WvZxs0w"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]}, "status_code": 200}
2025/08/16 03:58:11.358 ←[34mINFO←[0m   trying to solve challenge       {"identifier": "o.elsebody.com", "challenge_type": "dns-01", "ca": "https://acme-v02.api.letsencrypt.org/directory"}
PS D:\Dropbox\JimBin\Caddy> caddy version
Downloaded Caddy v2.10.0 plus Ionos module v1.2.0 from downloads page
Windows 11 (no Docker, VM etc.)
n/a
	# Use Ionos API key for DNS challenges
	acme_dns ionos {redacted.redacted}
o.elsebody.com {
	reverse_proxy 192.168.8.211:443 {
			tls_insecure_skip_verify
This works fine with the parent domain.
Log file:
2025/08/18 20:44:42.879 ←[34mINFO←[0m   maxprocs: Leaving GOMAXPROCS=8: CPU quota undefined
2025/08/18 20:44:42.879 ←[34mINFO←[0m   GOMEMLIMIT is updated   {"package": "github.com/KimMachineGun/automemlimit/memlimit", "GOMEMLIMIT": 15071322931, "previous": 9223372036854775807}
2025/08/18 20:44:42.879 ←[34mINFO←[0m   using adjacent Caddyfile
2025/08/18 20:44:42.883 ←[34mINFO←[0m   adapted config to JSON  {"adapter": "caddyfile"}
2025/08/18 20:44:42.883 ←[33mWARN←[0m   Caddyfile input is not formatted; run 'caddy fmt --overwrite' to fix inconsistencies    {"adapter": "caddyfile", "file": "Caddyfile", "line": 14}
2025/08/18 20:44:42.894 ←[34mINFO←[0m   admin   admin endpoint started  {"address": "localhost:2019", "enforce_origin": false, "origins": ["//localhost:2019", "//[::1]:2019", "//127.0.0.1:2019"]}
2025/08/18 20:44:42.895 ←[34mINFO←[0m   tls.cache.maintenance   started background certificate maintenance      {"cache": "0xc00010ce00"}
2025/08/18 20:44:42.895 ←[34mINFO←[0m   http.auto_https server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS {"server_name": "srv0", "https_port": 443}
2025/08/18 20:44:42.895 ←[34mINFO←[0m   http.auto_https enabling automatic HTTP->HTTPS redirects        {"server_name": "srv0"}
2025/08/18 20:44:42.895 ←[35mDEBUG←[0m  http.auto_https adjusted config {"tls": {"automation":{"policies":[{"subjects":["elsebody.com"]},{}]}}, "http": {"servers":{"remaining_auto_https_redirects":{"listen":[":80"],"routes":[{},{}]},"srv0":{"listen":[":443"],"routes":[{"handle":[{"handler":"subroute","routes":[{"handle":[{"handler":"reverse_proxy","transport":{"protocol":"http","tls":{"insecure_skip_verify":true}},"upstreams":[{"dial":"192.168.8.211:443"}]}]}]}],"terminal":true}],"tls_connection_policies":[{}],"automatic_https":{}}}}}
2025/08/18 20:44:42.895 ←[35mDEBUG←[0m  http    starting server loop    {"address": "[::]:443", "tls": true, "http3": false}
2025/08/18 20:44:42.899 ←[34mINFO←[0m   http    enabling HTTP/3 listener        {"addr": ":443"}
2025/08/18 20:44:42.900 ←[34mINFO←[0m   http.log        server running  {"name": "srv0", "protocols": ["h1", "h2", "h3"]}
2025/08/18 20:44:42.900 ←[35mDEBUG←[0m  http    starting server loop    {"address": "[::]:80", "tls": false, "http3": false}
2025/08/18 20:44:42.900 ←[33mWARN←[0m   http    HTTP/2 skipped because it requires TLS  {"network": "tcp", "addr": ":80"}
2025/08/18 20:44:42.900 ←[33mWARN←[0m   http    HTTP/3 skipped because it requires TLS  {"network": "tcp", "addr": ":80"}
2025/08/18 20:44:42.900 ←[34mINFO←[0m   http.log        server running  {"name": "remaining_auto_https_redirects", "protocols": ["h1", "h2", "h3"]}
2025/08/18 20:44:42.900 ←[34mINFO←[0m   http    enabling automatic TLS certificate management   {"domains": ["elsebody.com"]}
2025/08/18 20:44:42.948 ←[33mWARN←[0m   tls     stapling OCSP   {"error": "no OCSP stapling for [elsebody.com]: no OCSP server specified in certificate", "identifiers": ["elsebody.com"]}
2025/08/18 20:44:42.949 ←[35mDEBUG←[0m  tls.cache       added certificate to cache      {"subjects": ["elsebody.com"], "expiration": "2025/11/12 08:55:24.000", "managed": true, "issuer_key": "acme-v02.api.letsencrypt.org-directory", "hash": "617348c0e1cfad92d8e319b0757ff84cd5ec8687f16cc195c3f76d3fe2f5b71c", "cache_size": 1, "cache_capacity": 10000}
2025/08/18 20:44:42.949 ←[35mDEBUG←[0m  events  event   {"name": "cached_managed_cert", "id": "cf751dbe-9973-4776-9e0d-ef068b03d962", "origin": "tls", "data": {"sans":["elsebody.com"]}}
2025/08/18 20:44:42.949 ←[35mDEBUG←[0m  events  event   {"name": "started", "id": "b3ba0e6b-d252-4a0c-b5d5-05106e68dd7c", "origin": "", "data": null}
2025/08/18 20:44:42.950 ←[34mINFO←[0m   autosaved config (load with --resume flag)      {"file": "C:\\Users\\Jim\\AppData\\Roaming\\Caddy\\autosave.json"}
2025/08/18 20:44:42.950 ←[34mINFO←[0m   serving initial configuration
2025/08/18 20:44:42.951 ←[34mINFO←[0m   watcher watching config file for changes        {"config_file": "Caddyfile"}
2025/08/18 20:44:42.984 ←[34mINFO←[0m   tls     cleaning storage unit   {"storage": "FileStorage:C:\\Users\\Jim\\AppData\\Roaming\\Caddy"}
2025/08/18 20:44:43.137 ←[34mINFO←[0m   tls     finished cleaning storage units
2025/08/18 20:44:44.064 ←[35mDEBUG←[0m  http request    {"method": "GET", "url": "https://acme-v02.api.letsencrypt.org/directory", "headers": {"User-Agent":["Caddy/2.10.0 CertMagic acmez (windows; amd64)"]}, "response_headers": {"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["995"],"Content-Type":["application/json"],"Date":["Mon, 18 Aug 2025 20:44:44 GMT"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]}, "status_code": 200}
2025/08/18 20:44:44.066 ←[35mDEBUG←[0m  getting renewal info    {"names": ["elsebody.com"]}
2025/08/18 20:44:44.308 ←[35mDEBUG←[0m  http request    {"method": "GET", "url": "https://acme-v02.api.letsencrypt.org/acme/renewal-info/nytfzzwhT50Et-0rLMTGcIvS1w0.BXArYA7mG0ET9odWvXeao3YL", "headers": {"User-Agent":["Caddy/2.10.0 CertMagic acmez (windows; amd64)"]}, "response_headers": {"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["101"],"Content-Type":["application/json"],"Date":["Mon, 18 Aug 2025 20:44:44 GMT"],"Link":["<https://acme-v02.api.letsencrypt.org/directory>;rel=\"index\""],"Retry-After":["21600"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]}, "status_code": 200}
2025/08/18 20:44:44.309 ←[34mINFO←[0m   got renewal info        {"names": ["elsebody.com"], "window_start": "2025/10/12 11:39:28.000", "window_end": "2025/10/14 06:50:17.000", "selected_time": "2025/10/13 08:21:47.000", "recheck_after": "2025/08/19 02:44:44.309", "explanation_url": ""}
2025/08/18 20:44:44.314 ←[34mINFO←[0m   tls     updated and stored ACME renewal information     {"identifiers": ["elsebody.com"], "cert_hash": "617348c0e1cfad92d8e319b0757ff84cd5ec8687f16cc195c3f76d3fe2f5b71c", "ari_unique_id": "nytfzzwhT50Et-0rLMTGcIvS1w0.BXArYA7mG0ET9odWvXeao3YL", "cert_expiry": "2025/11/12 08:55:23.000", "selected_time": "2025/10/13 13:53:56.000", "next_update": "2025/08/19 02:44:44.309", "explanation_url": ""}
And Caddyfile:
elsebody.com {
Is this all of the log? It ends with “trying to solve challenge” - there should be more. There’s no errors in there that I could see.
Sorry, thought I had it all. Here’s the full log, for the failing o.elsebody.com
2025/08/19 04:43:57.453 ←[34mINFO←[0m   maxprocs: Leaving GOMAXPROCS=8: CPU quota undefined
2025/08/19 04:43:57.453 ←[34mINFO←[0m   GOMEMLIMIT is updated   {"package": "github.com/KimMachineGun/automemlimit/memlimit", "GOMEMLIMIT": 15071322931, "previous": 9223372036854775807}
2025/08/19 04:43:57.454 ←[34mINFO←[0m   using adjacent Caddyfile
2025/08/19 04:43:57.456 ←[34mINFO←[0m   adapted config to JSON  {"adapter": "caddyfile"}
2025/08/19 04:43:57.456 ←[33mWARN←[0m   Caddyfile input is not formatted; run 'caddy fmt --overwrite' to fix inconsistencies    {"adapter": "caddyfile", "file": "Caddyfile", "line": 14}
2025/08/19 04:43:57.469 ←[34mINFO←[0m   admin   admin endpoint started  {"address": "localhost:2019", "enforce_origin": false, "origins": ["//localhost:2019", "//[::1]:2019", "//127.0.0.1:2019"]}
2025/08/19 04:43:57.470 ←[34mINFO←[0m   tls.cache.maintenance   started background certificate maintenance      {"cache": "0xc000617300"}
2025/08/19 04:43:57.470 ←[34mINFO←[0m   http.auto_https server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS {"server_name": "srv0", "https_port": 443}
2025/08/19 04:43:57.470 ←[34mINFO←[0m   http.auto_https enabling automatic HTTP->HTTPS redirects        {"server_name": "srv0"}
2025/08/19 04:43:57.470 ←[35mDEBUG←[0m  http.auto_https adjusted config {"tls": {"automation":{"policies":[{"subjects":["o.elsebody.com"]},{}]}}, "http": {"servers":{"remaining_auto_https_redirects":{"listen":[":80"],"routes":[{},{}]},"srv0":{"listen":[":443"],"routes":[{"handle":[{"handler":"subroute","routes":[{"handle":[{"handler":"reverse_proxy","transport":{"protocol":"http","tls":{"insecure_skip_verify":true}},"upstreams":[{"dial":"192.168.8.211:443"}]}]}]}],"terminal":true}],"tls_connection_policies":[{}],"automatic_https":{}}}}}
2025/08/19 04:43:57.471 ←[35mDEBUG←[0m  http    starting server loop    {"address": "[::]:443", "tls": true, "http3": false}
2025/08/19 04:43:57.471 ←[34mINFO←[0m   http    enabling HTTP/3 listener        {"addr": ":443"}
2025/08/19 04:43:57.472 ←[34mINFO←[0m   http.log        server running  {"name": "srv0", "protocols": ["h1", "h2", "h3"]}
2025/08/19 04:43:57.472 ←[35mDEBUG←[0m  http    starting server loop    {"address": "[::]:80", "tls": false, "http3": false}
2025/08/19 04:43:57.473 ←[33mWARN←[0m   http    HTTP/2 skipped because it requires TLS  {"network": "tcp", "addr": ":80"}
2025/08/19 04:43:57.473 ←[33mWARN←[0m   http    HTTP/3 skipped because it requires TLS  {"network": "tcp", "addr": ":80"}
2025/08/19 04:43:57.473 ←[34mINFO←[0m   http.log        server running  {"name": "remaining_auto_https_redirects", "protocols": ["h1", "h2", "h3"]}
2025/08/19 04:43:57.473 ←[34mINFO←[0m   http    enabling automatic TLS certificate management   {"domains": ["o.elsebody.com"]}
2025/08/19 04:43:57.474 ←[35mDEBUG←[0m  events  event   {"name": "started", "id": "45a45150-4c1b-4a1e-aa20-42e5bdfef85c", "origin": "", "data": null}
2025/08/19 04:43:57.475 ←[34mINFO←[0m   autosaved config (load with --resume flag)      {"file": "C:\\Users\\Jim\\AppData\\Roaming\\Caddy\\autosave.json"}
2025/08/19 04:43:57.475 ←[34mINFO←[0m   serving initial configuration
2025/08/19 04:43:57.476 ←[34mINFO←[0m   watcher watching config file for changes        {"config_file": "Caddyfile"}
2025/08/19 04:43:57.480 ←[34mINFO←[0m   tls     storage cleaning happened too recently; skipping for now        {"storage": "FileStorage:C:\\Users\\Jim\\AppData\\Roaming\\Caddy", "instance": "b84f29cf-3e27-4800-8496-286b891c4f37", "try_again": "2025/08/20 04:43:57.480", "try_again_in": 86400}
2025/08/19 04:43:57.481 ←[34mINFO←[0m   tls     finished cleaning storage units
2025/08/19 04:43:57.495 ←[34mINFO←[0m   tls.obtain      acquiring lock  {"identifier": "o.elsebody.com"}
2025/08/19 04:43:57.501 ←[34mINFO←[0m   tls.obtain      lock acquired   {"identifier": "o.elsebody.com"}
2025/08/19 04:43:57.501 ←[34mINFO←[0m   tls.obtain      obtaining certificate   {"identifier": "o.elsebody.com"}
2025/08/19 04:43:57.502 ←[35mDEBUG←[0m  events  event   {"name": "cert_obtaining", "id": "cf5f2d9a-9f02-4a93-8a30-7db9d7a91641", "origin": "tls", "data": {"identifier":"o.elsebody.com"}}
2025/08/19 04:43:57.502 ←[35mDEBUG←[0m  tls     created CSR     {"identifiers": ["o.elsebody.com"], "san_dns_names": ["o.elsebody.com"], "san_emails": [], "common_name": "", "extra_extensions": 0}
2025/08/19 04:43:57.502 ←[35mDEBUG←[0m  tls.obtain      trying issuer 1/1       {"issuer": "acme-v02.api.letsencrypt.org-directory"}
2025/08/19 04:43:57.503 ←[35mDEBUG←[0m  tls.issuance.acme       using existing ACME account because key found in storage associated with email  {"email": "default", "ca": "https://acme-v02.api.letsencrypt.org/directory"}
2025/08/19 04:43:57.504 ←[35mDEBUG←[0m  tls.issuance.acme       using existing ACME account because key found in storage associated with email  {"email": "", "ca": "https://acme-v02.api.letsencrypt.org/directory"}
2025/08/19 04:43:57.504 ←[34mINFO←[0m   tls.issuance.acme       waiting on internal rate limiter        {"identifiers": ["o.elsebody.com"], "ca": "https://acme-v02.api.letsencrypt.org/directory", "account": ""}
2025/08/19 04:43:57.504 ←[34mINFO←[0m   tls.issuance.acme       done waiting on internal rate limiter   {"identifiers": ["o.elsebody.com"], "ca": "https://acme-v02.api.letsencrypt.org/directory", "account": ""}
2025/08/19 04:43:57.504 ←[34mINFO←[0m   tls.issuance.acme       using ACME account      {"account_id": "https://acme-v02.api.letsencrypt.org/acme/acct/2594289706", "account_contact": []}
2025/08/19 04:43:57.921 ←[35mDEBUG←[0m  http request    {"method": "GET", "url": "https://acme-v02.api.letsencrypt.org/directory", "headers": {"User-Agent":["Caddy/2.10.0 CertMagic acmez (windows; amd64)"]}, "response_headers": {"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["995"],"Content-Type":["application/json"],"Date":["Tue, 19 Aug 2025 04:43:58 GMT"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]}, "status_code": 200}
2025/08/19 04:43:57.921 ←[35mDEBUG←[0m  creating order  {"account": "https://acme-v02.api.letsencrypt.org/acme/acct/2594289706", "identifiers": ["o.elsebody.com"]}
2025/08/19 04:43:58.041 ←[35mDEBUG←[0m  http request    {"method": "HEAD", "url": "https://acme-v02.api.letsencrypt.org/acme/new-nonce", "headers": {"User-Agent":["Caddy/2.10.0 CertMagic acmez (windows; amd64)"]}, "response_headers": {"Cache-Control":["public, max-age=0, no-cache"],"Date":["Tue, 19 Aug 2025 04:43:58 GMT"],"Link":["<https://acme-v02.api.letsencrypt.org/directory>;rel=\"index\""],"Replay-Nonce":["9_RDYWV0KdAa_ZIMt2MvUV1HeQRvPLs5PytuU9ilYDGqk10-0bI"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]}, "status_code": 200}
2025/08/19 04:43:58.190 ←[35mDEBUG←[0m  http request    {"method": "POST", "url": "https://acme-v02.api.letsencrypt.org/acme/new-order", "headers": {"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.10.0 CertMagic acmez (windows; amd64)"]}, "response_headers": {"Boulder-Requester":["2594289706"],"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["348"],"Content-Type":["application/json"],"Date":["Tue, 19 Aug 2025 04:43:58 GMT"],"Link":["<https://acme-v02.api.letsencrypt.org/directory>;rel=\"index\""],"Location":["https://acme-v02.api.letsencrypt.org/acme/order/2594289706/419371985697"],"Replay-Nonce":["9_RDYWV0EoZVqEuRzXt88y_YDunHeaKr7jO2EH5Ppla0W8m4sug"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]}, "status_code": 201}
2025/08/19 04:43:58.320 ←[35mDEBUG←[0m  http request    {"method": "POST", "url": "https://acme-v02.api.letsencrypt.org/acme/authz/2594289706/571051566907", "headers": {"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.10.0 CertMagic acmez (windows; amd64)"]}, "response_headers": {"Boulder-Requester":["2594289706"],"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["822"],"Content-Type":["application/json"],"Date":["Tue, 19 Aug 2025 04:43:58 GMT"],"Link":["<https://acme-v02.api.letsencrypt.org/directory>;rel=\"index\""],"Replay-Nonce":["trI9TC2kGro3ny1V5JjrNJ8xCc6rk_Ee_4q_7FXhz7LxK2j7xOo"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]}, "status_code": 200}
2025/08/19 04:43:58.320 ←[34mINFO←[0m   trying to solve challenge       {"identifier": "o.elsebody.com", "challenge_type": "dns-01", "ca": "https://acme-v02.api.letsencrypt.org/directory"}
2025/08/19 04:44:00.578 ←[31mERROR←[0m  cleaning up solver      {"identifier": "o.elsebody.com", "challenge_type": "dns-01", "error": "no memory of presenting a DNS record for \"_acme-challenge.o.elsebody.com\" (usually OK if presenting also failed)"}
github.com/mholt/acmez/v3.(*Client).solveChallenges.func1
        github.com/mholt/acmez/v3@v3.1.2/client.go:318
        github.com/mholt/acmez/v3@v3.1.2/client.go:363
github.com/mholt/acmez/v3.(*Client).ObtainCertificate
        github.com/mholt/acmez/v3@v3.1.2/client.go:136
github.com/caddyserver/certmagic.(*ACMEIssuer).doIssue
        github.com/caddyserver/certmagic@v0.23.0/acmeissuer.go:489
github.com/caddyserver/certmagic.(*ACMEIssuer).Issue
        github.com/caddyserver/certmagic@v0.23.0/acmeissuer.go:382
github.com/caddyserver/caddy/v2/modules/caddytls.(*ACMEIssuer).Issue
        github.com/caddyserver/caddy/v2@v2.10.0/modules/caddytls/acmeissuer.go:288
github.com/caddyserver/certmagic.(*Config).obtainCert.func2
        github.com/caddyserver/certmagic@v0.23.0/config.go:626
github.com/caddyserver/certmagic.doWithRetry
        github.com/caddyserver/certmagic@v0.23.0/async.go:104
        github.com/caddyserver/certmagic@v0.23.0/config.go:700
github.com/caddyserver/certmagic.(*Config).ObtainCertAsync
        github.com/caddyserver/certmagic@v0.23.0/config.go:505
github.com/caddyserver/certmagic.(*Config).manageOne.func1
        github.com/caddyserver/certmagic@v0.23.0/config.go:415
github.com/caddyserver/certmagic.(*jobManager).worker
        github.com/caddyserver/certmagic@v0.23.0/async.go:73
2025/08/19 04:44:00.697 ←[35mDEBUG←[0m  http request    {"method": "POST", "url": "https://acme-v02.api.letsencrypt.org/acme/authz/2594289706/571051566907", "headers": {"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.10.0 CertMagic acmez (windows; amd64)"]}, "response_headers": {"Boulder-Requester":["2594289706"],"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["826"],"Content-Type":["application/json"],"Date":["Tue, 19 Aug 2025 04:44:01 GMT"],"Link":["<https://acme-v02.api.letsencrypt.org/directory>;rel=\"index\""],"Replay-Nonce":["trI9TC2kTfrFHk2MRZ0lqZy2mbZAerz4OClYz9hiC3-FZsfdP8c"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]}, "status_code": 200}
2025/08/19 04:44:00.698 ←[31mERROR←[0m  tls.obtain      could not get certificate from issuer   {"identifier": "o.elsebody.com", "issuer": "acme-v02.api.letsencrypt.org-directory", "error": "[o.elsebody.com] solving challenges: presenting for challenge: adding temporary record for zone \"elsebody.com.\": find zone: get all zones: Bad Request (400) (order=https://acme-v02.api.letsencrypt.org/acme/order/2594289706/419371985697) (ca=https://acme-v02.api.letsencrypt.org/directory)"}
2025/08/19 04:44:00.699 ←[35mDEBUG←[0m  events  event   {"name": "cert_failed", "id": "50176870-5d27-4037-9b33-f3f42dc943b4", "origin": "tls", "data": {"error":{},"identifier":"o.elsebody.com","issuers":["acme-v02.api.letsencrypt.org-directory"],"renewal":false}}
2025/08/19 04:44:00.700 ←[31mERROR←[0m  tls.obtain      will retry      {"error": "[o.elsebody.com] Obtain: [o.elsebody.com] solving challenges: presenting for challenge: adding temporary record for zone \"elsebody.com.\": find zone: get all zones: Bad Request (400) (order=https://acme-v02.api.letsencrypt.org/acme/order/2594289706/419371985697) (ca=https://acme-v02.api.letsencrypt.org/directory)", "attempt": 1, "retrying_in": 60, "elapsed": 3.1989418, "max_duration": 2592000}
