I am running caddy on a Rpi4 2GB. Installed with sudo apt install caddy.
OS: Raspbian buster Lite
uname -a : Linux homepi 5.10.17-v7l+ #1403 SMP Mon Feb 22 11:33:35 GMT 2021 armv7l GNU/Linux
d. My complete Caddyfile:
example.duckdns.org {
handle_path /overseerr* {
reverse_proxy 192.168.29.2:5055
I have overseer running on docker at 192.168.29.2:5055
Overseerr doesn’t support configuring the base_url and hence I cannot simply use
reverse_proxy /overseerr/* 192.168.29.2:5055
I found the following issues on github #3266 and #2813 and as suggested I am using the above Caddyfile.
handle_path seems to strip the /overseerr in the request properly as the page is redirected to login, but the problem is that it is being redirected to https://example.duckdns.org/login instead of https://example.duckdns.org/overseerr/login. I get a blank page.
What should I do to make sure the response also contains the /overseerr subpath?
This is the response I get using curl -v https://example.duckdns.org/overseerr
< HTTP/2 307
< date: Tue, 11 May 2021 07:08:57 GMT
< location: /login
< server: Caddy
< x-powered-by: Express
< content-length: 0
I tried using handle and route with uri strip_prefix /overseerr but the same problem arises.
