I downloaded the caddy binary from the caddy website, and can either run it manually, or using the systemd .service file below.
CentOS Linux release 7.7.1908 (Core)
caddy run --config /path/to/caddy_conf/caddy.conf
After=network.target
User=nginx
Group=nginx
ExecStart=/path/to/caddy_bin/caddy run --environ --config /path/to/caddy_conf/caddy.conf
ExecReload=/path/to/caddy_bin/caddy reload --config /path/to/caddy_conf/caddy.conf
Restart=always
RestartSec=30
"apps": {
"http": {
"servers": {
"my_server": {
"listen": [":60000"],
"routes": [
"handle": [{
"handler": "reverse_proxy",
"upstreams": [
"dial": "192.168.199.12:80"
Right now, caddy works fine. It listens on port 60000, and sends connections to 192.168.199.12:80. That’s great for HTTP.
I have a certificate chain file, and a private key file on my server. All I want is to somehow enable SSL. For now, I do NOT want anything automatic. No LetsEncrypt, or anything. I just want it to use my existing SSL cert and key. Clients connecting to port 60000 should be presented with this certificate, so that the connection between clients, and port 60000 is encrypted.
Note: The upstream connection between caddy and 192.168.199.12:80 will remain HTTP (non-encrypted).
I tried doing this:
"apps": {
"http": {
"servers": {
"my_server": {
"routes": [
"handle": [{
"upstreams": [
"tls": {
"certificates": {
"load_files": [{
"certificate": "/path/to/cert/fullchain.pem",
"key": "/path/to/key/privkey.pem"
But that had no effect. The page is still being served as HTTP on port 60000.
As far as I can tell, that loads the cert chain and key, but doesn’t use it.
I then tried adding a host matcher like so:
"apps": {
"http": {
"servers": {
"my_server": {
"routes": [
"match": [{
"host": ["mydomain.com"]
"handle": [{
"upstreams": [
"tls": {
"certificates": {
"load_files": [{
where mydomain.com is my actual domain name.
The config validates with caddy validate --config /caddy.conf, but when I run it, I get this error:
run: loading initial config: loading new config: http app module: start: tcp: listening on :80: listen tcp :80: bind: address already in use
My port 80 is indeed in use (by nginx) for something unrelated. I’m not sure why caddy is trying to bind to port 80 though, since I’m still only telling it to listen on port 60000. My best guess is that it’s trying to acquire a cert from LetsEncrypt by using the HTTP challenge, and failing to bind to port 80.
What am I missing? Do I just need to somehow tell it to disable automatic HTTPS? Do I need to also tell it how to link my ssl cert/key with that particular handler? I figured it would match the “host” (mydomain.com) against the common name found inside the certificate, but maybe I’m wrong.
Update:
Adding
"automatic_https": {
"disable": true
Has stopped giving me the error, allowing caddy to actually start, but when I hit the page on port 60000, I get absolutely nothing. I get a 200 OK with a blank body.
