Reverse Proxy with rewrite of path, stripping parts
1. Caddy version (caddy version): 2.4.1
Docker 20.10.7 on Ubuntu 18.04
docker-compose -f docker-compose.yml -f docker-compose.azurevm-highperf-caddy.yml up
docker-compose.yml:
version: "2"
  elasticsearch:
    build:
      context: elasticsearch/
      - elasticsearch-data:/usr/share/elasticsearch/data
      - ./elasticsearch/config/elasticsearch.yml:/usr/share/elasticsearch/config/elasticsearch.yml:ro
      node.name: elasticsearch
      cluster.initial_master_nodes: elasticsearch
      ES_CLUSTER_NAME: search-cluster
      ES_DATA_DIR: /usr/share/elasticsearch/data
      - elk
  elasticsearch-data:
    driver: local
  elk:
    driver: bridge
docker-compose.azurevm-highperf-caddy.yml:
version: "2"
  elasticsearch:
    restart: always
      ES_JAVA_OPTS: "-Xmx4000m -Xms4000m"
    image: caddy:2.4.1
    restart: always
      - ./caddy/Caddyfile:/etc/caddy/Caddyfile:ro
      - ./caddy-config:/config
      - ./caddy-data:/data
      - DOMAIN=adv-es-https-test-1.westeurope.cloudapp.azure.com
      - EMAIL=a@skwar.me
      - LOG_FILE=/data/access.log
      - 443:443
      - elk
    depends_on:
      - elasticsearch
{$DOMAIN}:443
route {
        rewrite /es/ /
        reverse_proxy http://elasticsearch:9200
I’d like Caddy to be a reverse proxy to Elasticsearch. It should only reverse proxy paths beginning with /es/ and it should remove the /es/ from the path when it gets send to http://elasticsearch:9200. So, when eg. https://adv-es-https-test-1.westeurope.cloudapp.azure.com/es/foo is called, it should be proxied to http://elasticsearch:9200/foo.
With the above Caddyfile, going to https://adv-es-https-test-1.westeurope.cloudapp.azure.com/es/ seems to work. I get a response from Elasticsearch.
$ curl https://adv-es-https-test-1.westeurope.cloudapp.azure.com:443/es/foo
{"error":"Incorrect HTTP method for uri [/es/foo] and method [GET], allowed: [POST]","status":405}
$ curl https://adv-es-https-test-1.westeurope.cloudapp.azure.com:443/foo
{"error":{"root_cause":[{"type":"index_not_found_exception","reason":"no such index [foo]","resource.type":"index_or_alias","resource.id":"foo","index_uuid":"_na_","index":"foo"}],"type":"index_not_found_exception","reason":"no such index [foo]","resource.type":"index_or_alias","resource.id":"foo","index_uuid":"_na_","index":"foo"},"status":404}
When I compare these two invocations, it seems that in the first invocation (with /es/foo), the /es did not get stripped.
It seems that the route { ... } part isn’t required. Leaving it out doesn’t seem to make a difference.
I also tried simplyfying the Caddyfile to this:
{$DOMAIN}:443
reverse_proxy /es/* http://elasticsearch:9200
It then does the reverse proxy fine, but doesn’t remove the /es/ from the beginning of the path:
{"error":{"root_cause":[{"type":"index_not_found_exception","reason":"no such index [es]","resource.type":"index_or_alias","resource.id":"es","index_uuid":"_na_","index":"es"}],"type":"index_not_found_exception","reason":"no such index [es]","resource.type":"index_or_alias","resource.id":"es","index_uuid":"_na_","index":"es"},"status":404}
You’re either looking for uri (Caddyfile directive) — Caddy Documentation or for handle_path (Caddyfile directive) — Caddy Documentation to strip the path prefix.
But generally, I’d recommend using subdomains for each service, instead of subpaths. See this article for an explanation:
Thanks a lot. It works quite well using handle_path, like so:
handle_path /elasticsearch/* {
        basicauth bcrypt Elasticsearch {
                Bob JDJhJDEwJEVCNmdaNEg2Ti5iejRMYkF3MFZhZ3VtV3E1SzBWZEZ5Q3VWc0tzOEJwZE9TaFlZdEVkZDhX
While I agree that subdomains might be better, this isn’t feasible in the current situation for me.
Oh, I just noticed, that https://adv-es-https-test-1.westeurope.cloudapp.azure.com/elasticsearch does not work. It only works with a trailing slash.
I changed the Caddyfile to this:
handle_path /elasticsearch {
But then https://adv-es-https-test-1.westeurope.cloudapp.azure.com/elasticsearch works, but https://adv-es-https-test-1.westeurope.cloudapp.azure.com/elasticsearch/foo-bar does not.
Do I need to have two handle_path blocks?
You still need the * even if you remove the /. Path matching is exact in Caddy, so /elasticsearch only matches exactly /elasticsearch and nothing else.
Great!
This works:
handle_path /elasticsearch* {
