I’ve created a caddy file using two modules: dynamic_dns and the cloudflare module. I’ve set everything up, after inspiring from other forum posts who got it working. However, when I try to access the website (from within my house) i get the following error in the browser: Error code: SSL_ERROR_INTERNAL_ERROR_ALERT.
I also am not sure if in Cloudflare I should create DNS records for each subdomain individually or if I can just use * as the name.
It looks like caddy cannot obtain certificates from letsencrypt. The Virtual Machine where Caddy Runs is named docker01. Caddy does not run in a docker environment.
May 08 22:30:40 docker01 caddy[420603]: {"level":"debug","ts":1715207440.940805,"logger":"tls.issuance.acme.acme_client","msg":"http request","method":"POST","url":"https://acme-v02.api.letsencrypt.org/acme/new-order","headers":{"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.8.0-beta.2 CertMagic acmez (linux; amd64)"]},"response_headers":{"Boulder-Requester":["1716261317"],"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["107"],"Content-Type":["application/problem+json"],"Date":["Wed, 08 May 2024 22:30:40 GMT"],"Link":["<https://acme-v02.api.letsencrypt.org/directory>;rel=\"index\""],"Replay-Nonce":["KBbvukTesQyt53KSul4U8-b_bPaRm4K_OQ-zWm_YDRGjPrFBoAk"],"Server":["nginx"]},"status_code":400}
May 08 22:30:40 docker01 caddy[420603]: {"level":"error","ts":1715207440.941141,"logger":"tls.obtain","msg":"could not get certificate from issuer","identifier":"snellius.gorgonea.nl","issuer":"acme-v02.api.letsencrypt.org-directory","error":"HTTP 400 urn:ietf:params:acme:error:malformed - JWS verification error"}
May 08 22:30:40 docker01 caddy[420603]: {"level":"debug","ts":1715207440.9412513,"logger":"events","msg":"event","name":"cert_failed","id":"4dae8ef3-8a90-411a-844b-e6802328775b","origin":"tls","data":{"error":{},"identifier":"snellius.gorgonea.nl","issuers":["acme-v02.api.letsencrypt.org-directory"],"renewal":false}}
May 08 22:30:40 docker01 caddy[420603]: {"level":"error","ts":1715207440.941296,"logger":"tls.obtain","msg":"will retry","error":"[snellius.gorgonea.nl] Obtain: [snellius.gorgonea.nl] creating new order: attempt 1: https://acme-v02.api.letsencrypt.org/acme/new-order: HTTP 400 urn:ietf:params:acme:error:malformed - JWS verification error (ca=https://acme-v02.api.letsencrypt.org/directory)","attempt":1,"retrying_in":60,"elapsed":0.569225729,"max_duration":2592000}
May 08 22:30:46 docker01 caddy[420603]: {"level":"info","ts":1715207446.6757905,"logger":"dynamic_dns","msg":"finished updating DNS","current_ips":["31.20.131.61"]}
May 08 22:30:51 docker01 caddy[420603]: {"level":"info","ts":1715207451.6427345,"logger":"admin.api","msg":"received request","method":"POST","host":"localhost:2019","uri":"/load","remote_ip":"127.0.0.1","remote_port":"41036","headers":{"Accept-Encoding":["gzip"],"Content-Length":["945"],"Content-Type":["application/json"],"Origin":["http://localhost:2019"],"User-Agent":["Go-http-client/1.1"]}}
May 08 22:30:51 docker01 caddy[420603]: {"level":"info","ts":1715207451.6428804,"msg":"config is unchanged"}
May 08 22:30:51 docker01 caddy[420603]: {"level":"info","ts":1715207451.6429079,"logger":"admin.api","msg":"load complete"}
May 08 22:31:40 docker01 caddy[420603]: {"level":"info","ts":1715207500.9424124,"logger":"tls.obtain","msg":"obtaining certificate","identifier":"snellius.gorgonea.nl"}
May 08 22:31:40 docker01 caddy[420603]: {"level":"debug","ts":1715207500.9424968,"logger":"events","msg":"event","name":"cert_obtaining","id":"ea787d09-64f0-43fe-989b-f0c5eb1e6bf0","origin":"tls","data":{"identifier":"snellius.gorgonea.nl"}}
May 08 22:31:40 docker01 caddy[420603]: {"level":"debug","ts":1715207500.9426737,"logger":"tls.obtain","msg":"trying issuer 1/1","issuer":"acme-v02.api.letsencrypt.org-directory"}
May 08 22:31:40 docker01 caddy[420603]: {"level":"info","ts":1715207500.94283,"logger":"tls.issuance.acme","msg":"using ACME account","account_id":"https://acme-staging-v02.api.letsencrypt.org/acme/acct/147515174","account_contact":["mailto:<REDACTED_EMAIL>"]}
May 08 22:31:40 docker01 caddy[420603]: {"level":"debug","ts":1715207500.9428473,"logger":"tls.issuance.acme.acme_client","msg":"creating order","account":"https://acme-staging-v02.api.letsencrypt.org/acme/acct/147515174","identifiers":["snellius.gorgonea.nl"]}
May 08 22:31:41 docker01 caddy[420603]: {"level":"debug","ts":1715207501.4330933,"logger":"tls.issuance.acme.acme_client","msg":"http request","method":"HEAD","url":"https://acme-staging-v02.api.letsencrypt.org/acme/new-nonce","headers":{"User-Agent":["Caddy/2.8.0-beta.2 CertMagic acmez (linux; amd64)"]},"response_headers":{"Cache-Control":["public, max-age=0, no-cache"],"Date":["Wed, 08 May 2024 22:31:41 GMT"],"Link":["<https://acme-staging-v02.api.letsencrypt.org/directory>;rel=\"index\""],"Replay-Nonce":["5RI07lRcFeMe_pVyXa4oB0-yIkIP-v-zRdx9oP9eZBvB0RH02ps"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]},"status_code":200}
May 08 22:31:41 docker01 caddy[420603]: {"level":"debug","ts":1715207501.6303957,"logger":"tls.issuance.acme.acme_client","msg":"http request","method":"POST","url":"https://acme-staging-v02.api.letsencrypt.org/acme/new-order","headers":{"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.8.0-beta.2 CertMagic acmez (linux; amd64)"]},"response_headers":{"Boulder-Requester":["147515174"],"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["357"],"Content-Type":["application/json"],"Date":["Wed, 08 May 2024 22:31:41 GMT"],"Link":["<https://acme-staging-v02.api.letsencrypt.org/directory>;rel=\"index\""],"Location":["https://acme-staging-v02.api.letsencrypt.org/acme/order/147515174/16397544664"],"Replay-Nonce":["5RI07lRcWu_VBcRloyN9-8NwW2GGqghNzwFQIudzp9P3wWtoFiM"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]},"status_code":201}
May 08 22:31:41 docker01 caddy[420603]: {"level":"debug","ts":1715207501.7933238,"logger":"tls.issuance.acme.acme_client","msg":"http request","method":"POST","url":"https://acme-staging-v02.api.letsencrypt.org/acme/authz-v3/12288793884","headers":{"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.8.0-beta.2 CertMagic acmez (linux; amd64)"]},"response_headers":{"Boulder-Requester":["147515174"],"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["522"],"Content-Type":["application/json"],"Date":["Wed, 08 May 2024 22:31:41 GMT"],"Link":["<https://acme-staging-v02.api.letsencrypt.org/directory>;rel=\"index\""],"Replay-Nonce":["5RI07lRclakc1JAtglyKg4u4RMGnSy4XjtZiotHmxPgB9Ld0d3U"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]},"status_code":200}
May 08 22:31:41 docker01 caddy[420603]: {"level":"debug","ts":1715207501.793617,"logger":"tls.issuance.acme.acme_client","msg":"skipping challenge initiation because authorization is not pending","identifier":"snellius.gorgonea.nl","authz_status":"valid"}
May 08 22:31:41 docker01 caddy[420603]: {"level":"info","ts":1715207501.7936597,"logger":"tls.issuance.acme.acme_client","msg":"authorization finalized","identifier":"snellius.gorgonea.nl","authz_status":"valid"}
May 08 22:31:41 docker01 caddy[420603]: {"level":"info","ts":1715207501.7936847,"logger":"tls.issuance.acme.acme_client","msg":"validations succeeded; finalizing order","order":"https://acme-staging-v02.api.letsencrypt.org/acme/order/147515174/16397544664"}
May 08 22:31:41 docker01 caddy[420603]: {"level":"debug","ts":1715207501.980057,"logger":"tls.issuance.acme.acme_client","msg":"http request","method":"POST","url":"https://acme-staging-v02.api.letsencrypt.org/acme/finalize/147515174/16397544664","headers":{"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.8.0-beta.2 CertMagic acmez (linux; amd64)"]},"response_headers":{"Boulder-Requester":["147515174"],"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["362"],"Content-Type":["application/json"],"Date":["Wed, 08 May 2024 22:31:41 GMT"],"Link":["<https://acme-staging-v02.api.letsencrypt.org/directory>;rel=\"index\""],"Location":["https://acme-staging-v02.api.letsencrypt.org/acme/order/147515174/16397544664"],"Replay-Nonce":["hqsVkgou_4KbgGRcz5-2Cz7mT19pXnnPnnzdOj2RiMfb4Y8tRfg"],"Retry-After":["3"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]},"status_code":200}
May 08 22:31:45 docker01 caddy[420603]: {"level":"debug","ts":1715207505.148249,"logger":"tls.issuance.acme.acme_client","msg":"http request","method":"POST","url":"https://acme-staging-v02.api.letsencrypt.org/acme/order/147515174/16397544664","headers":{"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.8.0-beta.2 CertMagic acmez (linux; amd64)"]},"response_headers":{"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["469"],"Content-Type":["application/json"],"Date":["Wed, 08 May 2024 22:31:45 GMT"],"Link":["<https://acme-staging-v02.api.letsencrypt.org/directory>;rel=\"index\""],"Replay-Nonce":["5RI07lRc1Uoqq1NuSnDD4KrVf2W7UdT1bnvqCCar7Mla1BYbXYA"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]},"status_code":200}
May 08 22:31:45 docker01 caddy[420603]: {"level":"debug","ts":1715207505.3170068,"logger":"tls.issuance.acme.acme_client","msg":"http request","method":"POST","url":"https://acme-staging-v02.api.letsencrypt.org/acme/cert/2b0bcf47f3bca5e15b1aaf82e4b2070043ad","headers":{"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.8.0-beta.2 CertMagic acmez (linux; amd64)"]},"response_headers":{"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["2994"],"Content-Type":["application/pem-certificate-chain"],"Date":["Wed, 08 May 2024 22:31:45 GMT"],"Link":["<https://acme-staging-v02.api.letsencrypt.org/directory>;rel=\"index\"","<https://acme-staging-v02.api.letsencrypt.org/acme/cert/2b0bcf47f3bca5e15b1aaf82e4b2070043ad/1>;rel=\"alternate\""],"Replay-Nonce":["5RI07lRc-Vumt-v2dojHYDxB49Y9R5TmbP6Nd2xclN47AN942gc"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]},"status_code":200}
May 08 22:31:45 docker01 caddy[420603]: {"level":"debug","ts":1715207505.317128,"logger":"tls.issuance.acme.acme_client","msg":"getting renewal info","names":["snellius.gorgonea.nl"]}
May 08 22:31:45 docker01 caddy[420603]: {"level":"debug","ts":1715207505.6393247,"logger":"tls.issuance.acme.acme_client","msg":"http request","method":"GET","url":"https://acme-staging-v02.api.letsencrypt.org/draft-ietf-acme-ari-02/renewalInfo//_EbRAUNfu3umPTBorhG64LxtydM.KwvPR_O8peFbGq-C5LIHAEOt","headers":{"User-Agent":["Caddy/2.8.0-beta.2 CertMagic acmez (linux; amd64)"]},"response_headers":{"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["101"],"Content-Type":["application/json"],"Date":["Wed, 08 May 2024 22:31:45 GMT"],"Link":["<https://acme-staging-v02.api.letsencrypt.org/directory>;rel=\"index\""],"Retry-After":["21600"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]},"status_code":200}
May 08 22:31:45 docker01 caddy[420603]: {"level":"info","ts":1715207505.6395576,"logger":"tls.issuance.acme.acme_client","msg":"got renewal info","names":["snellius.gorgonea.nl"],"window_start":1720302701,"window_end":1720475501,"selected_time":1720420747,"recheck_after":1715229105.6395473,"explanation_url":""}
May 08 22:31:45 docker01 caddy[420603]: {"level":"debug","ts":1715207505.8087447,"logger":"tls.issuance.acme.acme_client","msg":"http request","method":"POST","url":"https://acme-staging-v02.api.letsencrypt.org/acme/cert/2b0bcf47f3bca5e15b1aaf82e4b2070043ad/1","headers":{"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.8.0-beta.2 CertMagic acmez (linux; amd64)"]},"response_headers":{"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["2433"],"Content-Type":["application/pem-certificate-chain"],"Date":["Wed, 08 May 2024 22:31:45 GMT"],"Link":["<https://acme-staging-v02.api.letsencrypt.org/directory>;rel=\"index\"","<https://acme-staging-v02.api.letsencrypt.org/acme/cert/2b0bcf47f3bca5e15b1aaf82e4b2070043ad/0>;rel=\"alternate\""],"Replay-Nonce":["5RI07lRcerlhIEW0t6q4j2vRd65_wOYMz2gyr2eGG6qR5S4eXAY"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]},"status_code":200}
May 08 22:31:45 docker01 caddy[420603]: {"level":"debug","ts":1715207505.8091002,"logger":"tls.issuance.acme.acme_client","msg":"getting renewal info","names":["snellius.gorgonea.nl"]}
May 08 22:31:46 docker01 caddy[420603]: {"level":"debug","ts":1715207506.130292,"logger":"tls.issuance.acme.acme_client","msg":"http request","method":"GET","url":"https://acme-staging-v02.api.letsencrypt.org/draft-ietf-acme-ari-02/renewalInfo//_EbRAUNfu3umPTBorhG64LxtydM.KwvPR_O8peFbGq-C5LIHAEOt","headers":{"User-Agent":["Caddy/2.8.0-beta.2 CertMagic acmez (linux; amd64)"]},"response_headers":{"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["101"],"Content-Type":["application/json"],"Date":["Wed, 08 May 2024 22:31:46 GMT"],"Link":["<https://acme-staging-v02.api.letsencrypt.org/directory>;rel=\"index\""],"Retry-After":["21600"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]},"status_code":200}
May 08 22:31:46 docker01 caddy[420603]: {"level":"info","ts":1715207506.1304204,"logger":"tls.issuance.acme.acme_client","msg":"got renewal info","names":["snellius.gorgonea.nl"],"window_start":1720302701,"window_end":1720475501,"selected_time":1720319364,"recheck_after":1715229106.1304157,"explanation_url":""}
May 08 22:31:46 docker01 caddy[420603]: {"level":"info","ts":1715207506.130465,"logger":"tls.issuance.acme.acme_client","msg":"successfully downloaded available certificate chains","count":2,"first_url":"https://acme-staging-v02.api.letsencrypt.org/acme/cert/2b0bcf47f3bca5e15b1aaf82e4b2070043ad"}
May 08 22:31:46 docker01 caddy[420603]: {"level":"debug","ts":1715207506.130482,"logger":"tls.issuance.acme","msg":"selected certificate chain","url":"https://acme-staging-v02.api.letsencrypt.org/acme/cert/2b0bcf47f3bca5e15b1aaf82e4b2070043ad"}
May 08 22:31:46 docker01 caddy[420603]: {"level":"info","ts":1715207506.1308331,"logger":"tls.issuance.acme","msg":"waiting on internal rate limiter","identifiers":["snellius.gorgonea.nl"],"ca":"https://acme-v02.api.letsencrypt.org/directory","account":"<REDACTED_EMAIL>"}
May 08 22:31:46 docker01 caddy[420603]: {"level":"info","ts":1715207506.1308713,"logger":"tls.issuance.acme","msg":"done waiting on internal rate limiter","identifiers":["snellius.gorgonea.nl"],"ca":"https://acme-v02.api.letsencrypt.org/directory","account":"<REDACTED_EMAIL>"}
May 08 22:31:46 docker01 caddy[420603]: {"level":"info","ts":1715207506.1309032,"logger":"tls.issuance.acme","msg":"using ACME account","account_id":"https://acme-v02.api.letsencrypt.org/acme/acct/1716261317","account_contact":["mailto:<REDACTED_EMAIL>"]}
May 08 22:31:46 docker01 caddy[420603]: {"level":"debug","ts":1715207506.130923,"logger":"tls.issuance.acme.acme_client","msg":"creating order","account":"https://acme-v02.api.letsencrypt.org/acme/acct/1716261317","identifiers":["snellius.gorgonea.nl"]}
May 08 22:31:46 docker01 caddy[420603]: {"level":"debug","ts":1715207506.272741,"logger":"tls.issuance.acme.acme_client","msg":"http request","method":"HEAD","url":"https://acme-v02.api.letsencrypt.org/acme/new-nonce","headers":{"User-Agent":["Caddy/2.8.0-beta.2 CertMagic acmez (linux; amd64)"]},"response_headers":{"Cache-Control":["public, max-age=0, no-cache"],"Date":["Wed, 08 May 2024 22:31:46 GMT"],"Link":["<https://acme-v02.api.letsencrypt.org/directory>;rel=\"index\""],"Replay-Nonce":["KBbvukTeJ2_Lg4yE9oXtIIw3MYP1FvnuYE7_Ur2gw47AnGnIofE"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]},"status_code":200}
May 08 22:31:46 docker01 caddy[420603]: {"level":"debug","ts":1715207506.4081025,"logger":"tls.issuance.acme.acme_client","msg":"http request","method":"POST","url":"https://acme-v02.api.letsencrypt.org/acme/new-order","headers":{"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.8.0-beta.2 CertMagic acmez (linux; amd64)"]},"response_headers":{"Boulder-Requester":["1716261317"],"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["107"],"Content-Type":["application/problem+json"],"Date":["Wed, 08 May 2024 22:31:46 GMT"],"Link":["<https://acme-v02.api.letsencrypt.org/directory>;rel=\"index\""],"Replay-Nonce":["RHbEAk-Jo2s7UNXw0sALRVytazKxqONV73UMKHsLtVi5BiZCEws"],"Server":["nginx"]},"status_code":400}
May 08 22:31:46 docker01 caddy[420603]: {"level":"error","ts":1715207506.4084003,"logger":"tls.obtain","msg":"could not get certificate from issuer","identifier":"snellius.gorgonea.nl","issuer":"acme-v02.api.letsencrypt.org-directory","error":"HTTP 400 urn:ietf:params:acme:error:malformed - JWS verification error"}
May 08 22:31:46 docker01 caddy[420603]: {"level":"debug","ts":1715207506.4085228,"logger":"events","msg":"event","name":"cert_failed","id":"e21c8473-88e3-4058-b251-af64b266ef53","origin":"tls","data":{"error":{"Err":{}},"identifier":"snellius.gorgonea.nl","issuers":["acme-v02.api.letsencrypt.org-directory"],"renewal":false}}
May 08 22:31:46 docker01 caddy[420603]: {"level":"info","ts":1715207506.408604,"logger":"tls.obtain","msg":"releasing lock","identifier":"snellius.gorgonea.nl"}
May 08 22:31:46 docker01 caddy[420603]: {"level":"error","ts":1715207506.4088492,"logger":"tls","msg":"job failed","error":"snellius.gorgonea.nl: obtaining certificate: [snellius.gorgonea.nl] Obtain: [snellius.gorgonea.nl] creating new order: attempt 1: https://acme-v02.api.letsencrypt.org/acme/new-order: HTTP 400 urn:ietf:params:acme:error:malformed - JWS verification error (ca=https://acme-v02.api.letsencrypt.org/directory)"}
Installed the most recent version : 2.8.0-beta.2
This is because i needed to use the master keyword when building caddy, dynamic_dns has an open issue about this (Module not building with xcaddy · Issue #67 · mholt/caddy-dynamicdns · GitHub)
.-/+oossssoo+/-. agorgan@docker01
`:+ssssssssssssssssss+:` ----------------
-+ssssssssssssssssssyyssss+- OS: Ubuntu 22.04.4 LTS x86_64
.ossssssssssssssssssdMMMNysssso. Host: KVM/QEMU (Standard PC (i440FX + PIIX, 1996) pc-i440fx-8.1)
/ssssssssssshdmmNNmmyNMMMMhssssss/ Kernel: 5.15.0-102-generic
+ssssssssshmydMMMMMMMNddddyssssssss+ Uptime: 23 days, 10 hours, 47 mins
/sssssssshNMMMyhhyyyyhmNMMMNhssssssss/ Packages: 881 (dpkg), 5 (snap)
.ssssssssdMMMNhsssssssssshNMMMdssssssss. Shell: bash 5.1.16
+sssshhhyNMMNyssssssssssssyNMMMysssssss+ Resolution: 1280x800
ossyNMMMNyMMhsssssssssssssshmmmhssssssso Terminal: /dev/pts/6
ossyNMMMNyMMhsssssssssssssshmmmhssssssso CPU: QEMU Virtual version 2.5+ (4) @ 3.095GHz
+sssshhhyNMMNyssssssssssssyNMMMysssssss+ GPU: 00:02.0 Vendor 1234 Device 1111
.ssssssssdMMMNhsssssssssshNMMMdssssssss. Memory: 855MiB / 7937MiB
/sssssssshNMMMyhhyyyyhdNMMMNhssssssss/
+sssssssssdmydMMMMMMMMddddyssssssss+
/ssssssssssshdmNNNNmyNMMMMhssssss/
-+sssssssssssssssssyyyssss+-
.-/+oossssoo+/-.
### Editing /etc/systemd/system/caddy.service.d/override.conf
### Anything between here and the comment below will become the new contents of the file
Environment="CLOUDFLARE_API_TOKEN=realkeyhere"
### Lines below this comment will be discarded
### /etc/systemd/system/caddy.service
# # caddy.service
# # For using Caddy with a config file.
# # Make sure the ExecStart and ExecReload commands are correct
# # for your installation.
# # See https://caddyserver.com/docs/install for instructions.
# # WARNING: This service does not use the --resume flag, so if you
# # use the API to make changes, they will be overwritten by the
# # Caddyfile next time the service is restarted. If you intend to
# # use Caddy's API to configure it, add the --resume flag to the
# # `caddy run` command or use the caddy-api.service file instead.
# [Unit]
# Description=Caddy
# Documentation=https://caddyserver.com/docs/
# After=network.target network-online.target
# Requires=network-online.target
# [Service]
# Type=notify
# User=caddy
# Group=caddy
# ExecStart=/usr/bin/caddy run --environ --config /etc/caddy/Caddyfile
# ExecReload=/usr/bin/caddy reload --config /etc/caddy/Caddyfile --force
# TimeoutStopSec=5s
# LimitNOFILE=1048576
# LimitNPROC=512
# PrivateTmp=true
# ProtectSystem=full
# AmbientCapabilities=CAP_NET_ADMIN CAP_NET_BIND_SERVICE
# [Install]
# WantedBy=multi-user.target
#For Starting Caddy
systemctl start caddy
#To Reload the config
caddy reload
email <REDACTED>
acme_dns cloudflare {env.CLOUDFLARE_API_TOKEN}
dynamic_dns {
provider cloudflare {env.CLOUDFLARE_API_TOKEN}
domains {
gorgonea.nl @ www
dynamic_domains
versions ipv4
home.gorgonea.nl {
reverse_proxy 192.168.1.50:8123
snellius.gorgonea.nl {
reverse_proxy 192.168.1.50:8006
