Reverse Proxy with Dynamic Upstream URL Path
I am desperately trying to setup custom user domains to map to full path url of my product. (and I’m very new to Caddy)
For example: User types in the browser a url with subdomain that they control, and sees a page that is hosted elsewhere with a full path url.
https://blog.userdomain.com → https://app.myproduct.com/user/blog-123/hello-world
I understand that reverse_proxy upstream addresses cannot contain paths or query strings and I should use rewrite and this is something I am unable to figure out.
There is one nuance, the path/segment blog-123 will need to be dynamically retrieved from a backend/storage based on the host. To make that happen I put a NodeJS/Express server that Caddy calls to retrieve that dynamic piece of information, but from then on I am unable to route the user the page using NodeJS/Express. I’m getting series of issues when I try that as I need to handle each request browser makes, like js, css, fonts, assets etc. I think I’m approaching this incorrectly.
One other thing I tried was just to retrieve the dynamic id/path in NodeJS/Express side and return that back to Caddy as a header to then use it to rewrite the full url, which I’m failing to do so as well.
Overall I’m a bit lost, I’m not even sure if I’m trying the impossible or what am I missing to make this happen.
Another thought I am having is to put the NodeJS/Express server first, retrieve the dynamic value and then pass it onto Caddy, but I am afraid I’ll have issues eventually with on_demand_ssl as Caddy will be the second layer in line.
I don’t necessarily have error messages, I’m just unable to figure out the approach.
When I try NodeJS to proxy all the requests, I get mime types errors, though irrelevant I assume.
Failed to load module script: Expected a JavaScript module script but the server responded with a MIME type of "text/html". Strict MIME type checking is enforced for module scripts per HTML spec.
brew install caddy
macOS 15.3.2
Eventually I’ll use Docker but I’m trying to make this work end to end locally first before I move on.
Not using Docker yet.
I’m sorry I don’t have a config that adds any value, I’m trying to figure out what I am supposed to do.
Take a look at rewrite to see if it might help with what you’re trying to do - or at least part of it.
For example:
https://blog.userdomain.com {
    reverse_proxy https://app.myproduct.com {
        rewrite /user/blog-123/hello-world{uri}
You’d need to adjust the rewrite directive to fit your situation.
Hello, thank you for your reply!
I’m trying this to test it out using my localhost, accessing via http://localhost in my browser and I all see is a white page.
	reverse_proxy https://caddyserver.com {
		rewrite /support{uri}
What curl returns
➜  ~ curl http://localhost -v
* Host localhost:80 was resolved.
* IPv6: ::1
* IPv4: 127.0.0.1
*   Trying [::1]:80...
* Connected to localhost (::1) port 80
> GET / HTTP/1.1
> Host: localhost
> User-Agent: curl/8.7.1
* Request completely sent off
< HTTP/1.1 200 OK
< Content-Length: 0
< Date: Fri, 21 Mar 2025 17:19:38 GMT
< Server: Caddy
< Server: Caddy
Removing rewrite and adding header_up, loads the page as expected.
Rewrite works when used inside handle, not sure why it didn’t work for me when nested in reverse_proxy
	handle / {
		rewrite * /support
And eventually even if this were to work, coming back to my original issue, I need to dynamically retrieve an id from a server based on the host. I think the problem starts when I proxy the requests to a backend/nodejs server to and try to return to Caddy so that it continues its flow.
This:
is not the same as this:
	handle / {
		rewrite * /support
That would actually be this:
		rewrite /support
Notice the missing {uri}. When you had {uri} in there and did this:
your curl request sent http://localhost/ to the server. That trailing / is what got assigned to {uri}. So in the end, you were requesting https://caddyserver.com/support/, but that page doesn’t exist - it’s just https://caddyserver.com/support.
That’s why I said you’d need to adjust the rewrite directive to fit your situation. In your case, that means removing {uri}.
And you’re absolutely right - adding
is always a good idea because if the remote server hosts multiple sites on the same IP:PORT, you might end up on the wrong one.
You might need to write your own Caddy plugin for that.
Please don’t test against our server
