1. Output of caddy version
v2.5.2 h1:eCJdLyEyAGzuQTa5Mh3gETnYWDClo1LjtQm2q9RNZrs= via the official Docker container
Official Docker image from here: Docker Hub
Docker on Debian 11
version: "3.7"
image: caddy:<version>
- $PWD/site:/srv
- caddy_data:/data
- caddy_config:/config
caddy_data:
external: true
caddy_config:
https://myapp.localdomain {
reverse_proxy 192.168.10.5:8443
tls /etc/caddy/certs/localdomain.crt /etc/caddy/certs/localdomain.key
tls_insecure_skip_verify
When using a basic config to the HTTP port in the app and my custom certificate everything works.
reverse_proxy 192.168.10.5:8000
However when I try to then proxy to the HTTPS port on the backend which has a self signed cert, ‘caddy verify’ tells me unrecognized directive: transport
and subsequently Caddy will not start. I can indeed connect to 192.168.10.5:8443 manually, so the service is alive and working and showing its self signed cert.
/etc/caddy # caddy validate
2022/07/31 16:26:44.091 INFO using adjacent Caddyfile
validate: adapting config using caddyfile: Caddyfile:52: unrecognized directive: transport
I have tried many multiple permutations based on forums posts. The docs indicate my configuration is correct. reverse_proxy (Caddyfile directive) — Caddy Documentation I have tried with both with and without the ‘tls’ directive within the transport section though without seems adequate as the docs state " * tls uses HTTPS with the backend. This will be enabled automatically if you specify backends using the https://
scheme or port :443
, or if any of the below tls_*
options are configured.
Also variations on this
reverse_proxy 192.168.10.5:8443 {
or
This instead gives the error validate: decoding config: unexpected end of JSON input
Inspired by this:https://pydio.com/en/docs/kb/deployment/running-cells-behind-caddy2-reverse-proxy
