Reverse Proxy with Cloudflare: Connection timed out (522)
I have 3 services (plex, jellyfin and nextcloud) running in docker and using caddy as a reverse proxy. I’ve had this setup for a few months now and it worked fine until about ~2 weeks ago.
Now if I try any of them I just get a Connection timed out ( Error 552) -
curl vL:
* Host jelly.domain.xyz:80 was resolved.
* IPv6:2606:23232:446b, 2606:23232::ac43:c248
* IPv4: 104.99.99.107, 172.00.00.72
*   Trying [2606:22222815:446b]:80...
* Connected to jelly.domain.xyz (2606:4700:2323:446b port 80
> GET / HTTP/1.1
> Host: jelly.domain.xyz
> User-Agent: curl/8.5.0
* Empty reply from server
* Closing connection
curl: (52) Empty reply from server
This is mostly the same response for all 3 of them, only difference is the IP based on if I have Cloudflare proxy ON or OFF
Caddy log shows no hits, so for some reason even if I can see the correct IP in the response it does not reach Caddy.
This is basically the only error I get, in a bowser.
Connection timed out Error code 522
Startup log:
Jan 07 17:18:47 HostName caddy[95377]: {"level":"info","ts":1704647927.622949,"logger":"http.log","msg":"server running","name":"srv0","protocols":["h1","h2","h3"]}
Jan 07 17:18:47 HostName caddy[95377]: {"level":"info","ts":1704647927.6231134,"logger":"http.log","msg":"server running","name":"remaining_auto_https_redirects","protocols":["h1","h2","h3"]}
Jan 07 17:18:47 HostName caddy[95377]: {"level":"info","ts":1704647927.6231434,"logger":"http","msg":"enabling automatic TLS certificate management","domains":["plex.domainname.xyz","cloud.domainname.xyz","jelly.domainname.xyz"]}
Jan 07 17:18:47 HostName caddy[95377]: {"level":"info","ts":1704647927.6232333,"logger":"http","msg":"servers shutting down with eternal grace period"}
Jan 07 17:18:47 HostName caddy[95377]: {"level":"info","ts":1704647927.628054,"msg":"autosaved config (load with --resume flag)","file":"/var/lib/caddy/.config/caddy/autosave.json"}
Jan 07 17:18:47 HostName caddy[95377]: {"level":"info","ts":1704647927.628848,"logger":"admin.api","msg":"load complete"}
Jan 07 17:18:47 HostName caddy[95377]: {"level":"info","ts":1704647927.6305325,"logger":"admin","msg":"stopped previous server","address":"localhost:2019"}
Jan 07 17:21:16 HostName caddy[95377]: {"level":"info","ts":1704648076.6227636,"logger":"admin.api","msg":"received request","method":"POST","host":"localhost:2019","uri":"/load","remote_ip":"127.0.0.1","remote_port":"38946","headers":{"Accept-Encoding":["gzip"],"Content-Length":["1696"],"Content-Type":["application/json"],"Origin":["http://localhost:2019"],"User-Agent":["Go-http-client/1.1"]}}
Jan 07 17:21:16 HostName caddy[95377]: {"level":"info","ts":1704648076.6237512,"msg":"config is unchanged"}
Jan 07 17:21:16 HostName caddy[95377]: {"level":"info","ts":1704648076.6239383,"logger":"admin.api","msg":"load complete"}
apt install caddy
Running on Raspberry Pi 4
Operating System: Debian GNU/Linux 12 (bookworm)
          Kernel: Linux 6.1.0-rpi7-rpi-v8
    Architecture: arm64
caddy start / sudo systemctl start caddy
Type=notify
https://cloud.domain.xyz {
                level Debug
        header Strict-Transport-Security max-age=31536000;
        reverse_proxy localhost:11443
                dns cloudflare cloudflare-key
                resolvers 1.1.1.1
https://plex.domain.xyz {
                level Debug
        reverse_proxy localhost:32400
                resolvers 1.1.1.1
https://jelly.domain.xyz {
        reverse_proxy localhost:8096
                resolvers 1.1.1.1
Some extra stuff:
All 3 services(plex, nextcloud and jellyfin) run in docker, while caddy is run a normal systemd service.
First time I noticed they were down the issue was that ddclient was trying to set ipv6 as a A record on cloudflare. So I assume I received an ipv6 from network provider. Once I fixed that everything was back to normal for a few days.
IP Tables:
ACCEPT     tcp  --  anywhere             172.25.0.2           tcp dpt:19080
ACCEPT     tcp  --  anywhere             172.28.0.2           tcp dpt:https
ACCEPT     tcp  --  anywhere             172.25.0.2           tcp dpt:9117
ACCEPT     tcp  --  anywhere             172.25.0.2           tcp dpt:8888
ACCEPT     tcp  --  anywhere             192.168.224.2        tcp dpt:3001
ACCEPT     tcp  --  anywhere             172.25.0.2           tcp dpt:8388
ACCEPT     tcp  --  anywhere             172.30.0.2           tcp dpt:5230
ACCEPT     tcp  --  anywhere             172.26.0.2           tcp dpt:9443
ACCEPT     tcp  --  anywhere             192.168.192.2        tcp dpt:7575
ACCEPT     udp  --  anywhere             172.25.0.2           udp dpt:8388
ACCEPT     tcp  --  anywhere             172.25.0.2           tcp dpt:6881
ACCEPT     udp  --  anywhere             172.25.0.2           udp dpt:6881
ACCEPT     tcp  --  anywhere             192.168.144.2        tcp dpt:2468
ACCEPT     tcp  --  anywhere             172.22.0.7           tcp dpt:11443
ACCEPT     tcp  --  anywhere             172.19.0.2           tcp dpt:http-alt
Ports 443 and 80 forwarded in router and UPnP enabled (these have not been changed in a long time, long before using caddy and everything worked as intended)
sudo lsof -nP -iTCP -sTCP:LISTEN:
docker-pr  2207      root    4u  IPv4  22603      0t0  TCP *:19080 (LISTEN)
docker-pr  2212      root    4u  IPv4  20915      0t0  TCP *:4443 (LISTEN)
docker-pr  2236      root    4u  IPv6  21752      0t0  TCP *:19080 (LISTEN)
docker-pr  2240      root    4u  IPv6  22612      0t0  TCP *:4443 (LISTEN)
docker-pr  2287      root    4u  IPv4  20000      0t0  TCP *:9117 (LISTEN)
docker-pr  2289      root    4u  IPv4  22634      0t0  TCP *:4080 (LISTEN)
docker-pr  2295      root    4u  IPv6  20003      0t0  TCP *:9117 (LISTEN)
docker-pr  2305      root    4u  IPv6  20943      0t0  TCP *:4080 (LISTEN)
docker-pr  2324      root    4u  IPv4  21801      0t0  TCP *:8888 (LISTEN)
docker-pr  2332      root    4u  IPv6  21804      0t0  TCP *:8888 (LISTEN)
docker-pr  2355      root    4u  IPv4  20972      0t0  TCP *:9081 (LISTEN)
docker-pr  2366      root    4u  IPv6  22658      0t0  TCP *:9081 (LISTEN)
docker-pr  2382      root    4u  IPv4  21846      0t0  TCP *:8388 (LISTEN)
docker-pr  2384      root    4u  IPv4  20994      0t0  TCP *:5230 (LISTEN)
docker-pr  2399      root    4u  IPv6  22682      0t0  TCP *:8388 (LISTEN)
docker-pr  2406      root    4u  IPv6  22687      0t0  TCP *:5230 (LISTEN)
docker-pr  2423      root    4u  IPv4  22696      0t0  TCP *:9443 (LISTEN)
docker-pr  2442      root    4u  IPv4  21867      0t0  TCP *:7575 (LISTEN)
docker-pr  2456      root    4u  IPv6  21008      0t0  TCP *:9443 (LISTEN)
docker-pr  2459      root    4u  IPv6  20082      0t0  TCP *:7575 (LISTEN)
docker-pr  2507      root    4u  IPv4  22731      0t0  TCP *:6881 (LISTEN)
docker-pr  2513      root    4u  IPv6  21916      0t0  TCP *:6881 (LISTEN)
jellyfin   3126 justme  313u  IPv4  34989      0t0  TCP *:8096 (LISTEN)
Plex\x20M  4141 justme   10u  IPv6  27274      0t0  TCP *:32400 (LISTEN)
Plex\x20M  4141 justme   11u  IPv4  27276      0t0  TCP 127.0.0.1:32401 (LISTEN)
Plex\x20S  5093 justme    4u  IPv4  32837      0t0  TCP 127.0.0.1:41451 (LISTEN)
docker-pr  5498      root    4u  IPv4  30259      0t0  TCP *:2468 (LISTEN)
docker-pr  5505      root    4u  IPv6  29378      0t0  TCP *:2468 (LISTEN)
Plex\x20T  5929 justme   10u  IPv4  32987      0t0  TCP 127.0.0.1:32600 (LISTEN)
docker-pr 77973      root    4u  IPv4 302746      0t0  TCP 127.0.0.1:11443 (LISTEN)
docker-pr 87261      root    4u  IPv4 337110      0t0  TCP *:8080 (LISTEN)
docker-pr 87271      root    4u  IPv6 338007      0t0  TCP *:8080 (LISTEN)
caddy     95377     caddy    3u  IPv6 409135      0t0  TCP *:443 (LISTEN)
caddy     95377     caddy   11u  IPv4 409134      0t0  TCP 127.0.0.1:2019 (LISTEN)
caddy     95377     caddy   12u  IPv6 409136      0t0  TCP *:80 (LISTEN)
Are you sure your IP address didn’t change?
ddclient updates it and I checked myself multiple times. I’ve been trying to fix this for a few days now. Went through all the suggestions I found on google.
I suspect there’s some issue on my side, from what I can tell cloudflare is working as intended especially since I have other apps using tunnel and those work.
I’m thinking something is blocking those requests before they reach caddy.
Any suggestions ??
If you share your domain, I could take a look at some things. But since you omitted it, there’s not much we can do to help. There’s not enough clear evidence of the problem.
